06-21-10 6.0l - Revised Cylinder Head Flatness Check Procedure And Specification - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 0 replies and been viewed 4691 times.
post #1 of 1 (permalink) Old 03-22-2007, 03:59 AM Thread Starter
Squatch's Avatar
Printable View (71 KB)
TSB
06-21-10 6.0L - REVISED CYLINDER HEAD FLATNESS CHECK PROCEDURE AND SPECIFICATION
Publication Date: October 10, 2006
FORD: 2003-2005 Excursion
2003-2007 F-Super Duty
2004-2006 E-350, E-450, F-650, F-750
ISSUE:
Some vehicles equipped with a 6.0L engine may require the cylinder head to be removed and a new cylinder head flatness check has been developed. This check is to ensure the component part is not out of factory specification prior to installation. The surface quality (finish) of the cylinder head gasket surface is machined to close tolerances which enable an effective sealing joint for the multi-layered steel (MLS) gasket.
ACTION:
Follow the Service Procedure steps to verify cylinder head flatness meets new specification.
SERVICE PROCEDURE
Preparation
Ensure all head gasket surfaces are clear of any gasket debris, RTV, oil, and coolant using Motorcraft® Silicone Gasket Remover (ZC-30) and Motorcraft® Metal Surface Prep (ZC-31). Use a lint free rag to mop up the deck surfaces. Shop vacuums are unacceptable for mop up as the surface cleaning material is volatile. The head surface must be clean and dry before running a flatness check
NOTE: DO NOT MEASURE FLATNESS IN THE LENGTHWISE (LONGITUDINAL) DIRECTION! THE OVERALL END-TO-END FLATNESS OF THE CYLINDER HEAD IS NOT AS CRITICAL AS THE LOCALIZED FLATNESS CHECKS. LONGITUDINAL MEASUREMENTS ARE NOT AN ACCURATE INDICATION OF FLATNESS WHEN INSTALLED DUE TO THE CLAMP LOAD OF THE HEAD TO BLOCK BOLTED ASSEMBLY. THE BOLTED CONDITION CAUSES AN OVERALL FLATNESS CONDITION THAT DIFFERS FROM THE FREE STATE CONDITION OF THE HEAD.
Use a straight edge that is calibrated by the manufacturer to be flat within 0.0002 inches (0.005 mm) per running foot length. For example, the straight edge may be 24" (61 cm) long. That means the machined edge must be flat within 0.0004" (0.010 mm) from end to end
Use Snap-On straight edge, Precision, 24" Stock number: GA438A or equivalent. All Ford dealers were provided this precision straight edge in 2001, it came in a red plastic case and is marked Central Tools
Use Snap-on Feeler Gauge stock number FB310B (.001" through .015") or equivalent. The feeler gauge must contain a .002" blade
Special care is required to ensure the tool is not damaged in handling or storage. A straight edge should be stored by hanging it vertically, or in its supplied protective case. Be sure the machined surface is free of nicks and dents. If these properties are found, the cost of tool re-calibration most likely will exceed the cost of a new straightedge. Machine shops may not be able to hold the specified tolerance within the original cost of the straight edge
When checking for flatness, avoid running the feeler gauge butt end against the straight edge. This action will curl or warp the feeler gauge leaf and prevent entry under the straight edge. Erroneous readings will result. Instead, lay the feeler gauge leaf on the point of inspection, placing the straight edge on top of the leaf. If the leaf is pulled out easily or is loose, the head is locally out of flat
13 Point Check System
Use the following 13 point check system to identify cylinder head flatness. Depressions in the cylinder head that are greater than 0.002" deep do not seal properly when using a MLS gasket.
To measure the cylinder head for flatness, set the 0.002" feeler gauge on each measurement point with the straight edge transverse or perpendicular to the head. (Figure 1) Set the straight edge on top of the feeler gauge.
NOTE: INSPECT POINTS 2 AND 3 FIRST. THESE TWO POINTS ARE THE MOST SUSCEPTIBLE TO FAIL.
While protecting the straight edge from tipping over, allow the straight edge to stand up on top of the feeler gauge.
Pull lightly on the feeler gauge.
The head is locally out of flat, and needs to be replaced if the 0.002". feeler gauge is loose or slides out from under the straight edge.
NOTE: DO NOT MACHINE THE HEAD.
Repeat for all 13 points. (Figure 1)
PART NUMBER PART NAME
ZC-30 Motorcraft® Silicone Gasket Remover
ZC-31 Motorcraft® Metal Surface Prep
WARRANTY STATUS:
DEALER CODING
BASIC PART NO. CONDITION CODE
6049 14
Figure 1 - Article 06-21-10
Copyright © 2006 Ford Motor Company
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
