06-16-2 Front Wheel Bearing Noise - F-250/350 4x2 Vehicles Built Prior To 7/21/2006 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 0 replies and been viewed 2022 times.
post #1 of 1 (permalink) Old 03-22-2007, 04:03 AM Thread Starter
Squatch's Avatar
Printable View (47 KB)
TSB
06-16-2 FRONT WHEEL BEARING NOISE - F-250/350 4X2 VEHICLES BUILT PRIOR TO 7/21/2006
Publication Date: July 26, 2006
FORD: 2005-2007 F-250, F-350
This article supersedes TSB 06-12-9 to update model years and to add a production fix date.
ISSUE:
Some 2005-2007 F-Super Duty 250/350 4X2 vehicles built prior to 07/21/2006 may exhibit front wheel bearings that are noisy. This may be caused by bearing contamination due to road debris or water.
ACTION:
Use the following Service Procedure to resolve the concern.
SERVICE PROCEDURE
Replace bearings and related parts as necessary.
Install a revised brake disc shield which includes a foam seal to help reduce bearing contamination from road debris and water. Remove brake disc shields per Workshop Manual, Section 206-03 "Removal and Installation" "Brake Disc Shield" and replace.
PART NUMBER PART NAME
7C3Z-2B159-B Dust Shield Assy RH
7C3Z-2B159-A Dust Shield Assy LH
WARRANTY STATUS:
OPERATION DESCRIPTION TIME
061602A 2005-2007 F-Super Duty 250/350 4X2: Install Front Brake Dust Shields, Includes Time To Remove Wheel Bearings, Inspect And Replace If Necessary: Both Sides (Do Not Use With 3105A, 3049A, 2134A, 1107A) 1.8 Hrs.
MT061602 Claim Additional Labor Required As Actual Time Or Use SLTS Operation If Available Actual Time
DEALER CODING
BASIC PART NO. CONDITION CODE
2K005 49
Copyright 2006 Ford Motor Company
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
