05-21-9 Whine/whistle Noise - 6.0l - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 0 replies and been viewed 4386 times.
post #1 of 1 (permalink) Old 03-23-2007, 12:40 PM Thread Starter
Squatch's Avatar
Printable View (51 KB)
TSB
05-21-9 WHINE/WHISTLE NOISE - 6.0L
Publication Date: October 12, 2005
FORD: 2003-2005 Excursion
2003-2006 F-Super Duty
2004-2006 E-Series
This article supersedes TSB 05-20-5 to update the Service Procedure.
ISSUE:
Some 2003-2006 F-Super Duty, 2003-2005 Excursion and 2004-2006 E-Series built with the 6.0L diesel engine may exhibit a whine/whistle noise coming from the turbocharger area.
ACTION:
Refer to the following Service Procedure to isolate and repair the source of the noise.
SERVICE PROCEDURE
If a whine/whistle is present, use WDS datalogger active command function to open the EGR valve, or unplug the variable geometry turbo (VGT) control solenoid. This will reduce the exhaust back pressure.
If the whine/whistle noise is still present continue with normal diagnostics.
If the whine/whistle noise is not present continue with this TSB.
Use one of the following to verify the source of whine/whistle noise at the EGR Cooler connection.
Listening device (vacuum hose, etc).
Smoke from a smoke machine (Rotunda 218-00001 or equivelent) introduced into the exhaust pressure (EP) sensor tube.
NOTE: CALIBRATING THE SMOKE MACHINE IS NOT NECESSARY.
Replace the EGR cooler to Y-pipe gasket following Workshop Manual, Section 309-00 and tighten ERG Cooler V-clamp nut to 53 lb-in (6 N-m), or replace the EGR cooler to intake manifold gasket following Workshop Manual, Section 303-08.
PART NUMBER PART NAME
3C3Z-9E933-AA EGR Cooler To Y-Pipe Gasket
3C3Z-9E933-BA EGR Cooler To Intake Gasket
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
OPERATION DESCRIPTION TIME
052109A 2003-2005 Excursion, 2003-2006 F-Super Duty 6.0L: Replace The EGR Cooler To Y-Pipe Gasket Includes Time To Use The WDS, And Smoke Machine (Do Not Use With 12650D, 12650D30, 9000D, 9000D1, 9000D2, 9424A, 6005F20, 6005F25) 3.3 Hrs.
052109B 2003-2005 Excursion, 2003-2006 F-Super Duty 6.0L: Replace The EGR Cooler To Intake Manifold Gasket Includes Time To Remove And Install The Intake Manifold, Use The WDS, And Smoke Machine (Do Not Use With 12650D, 12650D30, 9000D, 9000D1, 9000D2, 9424A, 6005F20, 6005F25) 5.2 Hrs.
052109C 2004-2006 Econoline 6.0L: Replace The EGR Cooler To Y-Pipe Gasket Includes Time To Use The WDS, And Smoke Machine (Do Not Use With 12650D, 12650D30, 9000D, 9000D1, 9000D2, 9424A, 6005F20, 6005F25) 1.2 Hrs.
052109D 2004-2006 Econoline 6.0L: Replace The EGR Cooler To Intake Manifold Gasket Includes Time To Remove And Install The Intake Manifold Use The WDS, And Smoke Machine (Do Not Use With 12650D, 12650D30, 9000D, 9000D1, 9000D2, 9424A, 6005F20, 6005F25) 6.9 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
9e933 D8
Copyright 2005 Ford Motor Company
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
