05-20-3 Oil Pan Corrosion - 7.3l Or 6.0l - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 4 replies and been viewed 1384 times.
post #1 of 5 (permalink) Old 03-23-2007, 12:41 PM Thread Starter
Squatch's Avatar
Printable View (8 KB)
TSB
05-20-3 OIL PAN CORROSION - 7.3L OR 6.0L
Publication Date: September 22, 2005
FORD: 1999-2006 E-Series, F-Super Duty
2000-2005 Excursion
2000-2006 F-650, F-750
This article supersedes TSB 03-21-46 to update the affected engines and vehicle model years.
ISSUE:
Some vehicles equipped with the 7.3L or 6.0L Diesel Engine may exhibit engine oil pan corrosion when operated in high salt content/corrosive environments. If the customer is concerned with this cosmetic issue, the following procedure may be used to resolve the condition.
ACTION:
Inspect the oil pan. If corrosion is detected use Motorcraft High Temp Anti-Corrosion Coating, Part Number PM-13-A, to service. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
Clean the oil pan off with a solvent to remove any dirt and oil. Using a 3" angle grinder with a 36 grit disc, grind off all loose corrosion. Blow off with air. Wash the pan with soap and water and let dry. Brush the anti-corrosion coating on the oil pan. Allow coating to dry fully before operating the vehicle.
PART NUMBER PART NAME
PM-13-A Motorcraft High Temp Anti-Corrosion Coating
WARRANTY STATUS:
Information Only - Not Warrantable
Copyright 2005 Ford Motor Company
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #2 of 5 (permalink) Old 07-06-2007, 05:19 AM
TDG Mafia Member # 37
01blkf250's Avatar
Squatch, first off thanks for all the TSB's. Would Ford be obligated to do this to my truck with 103,068 miles on it? Gene :mafia
2001 F-250 XLT, cc sb 4X4, 3.73 LS,auto, Ported ATS shroud housing 1.00 exhaust housing Banks wicked wheel adjustable wastegated turbo,Non Ebpv pedestal and gutted Ebpv, DI Performance regulated fuel return kit, Dieselsites' 203* thermostat and billet housing, MBRP 4" ss turbo back exhaust system, AFE Stage 1 air intake, Jody Tiptons' F5 chip with no start,stock, 60hp tow,and 120hp race tune for now til I get big oil and injectors. Sonnax kit, Dieselsites' A/C heater core bypass valve, Autometer Boost, Pyro, and Trans temp guages in A pillar, Regulator in MAP line set at 20psi, boost tube, wastgate adjusted real tight, Aih delete, and Zoodad'ed. Amsoil fluids, Monroe Reflex shocks, and Ironman APR 265/75/16R tires.
01blkf250 is offline
post #3 of 5 (permalink) Old 07-10-2007, 08:03 PM
"WARRANTY STATUS:
Information Only - Not Warrantable" guess that means for paying customers only
blindviper is offline
post #4 of 5 (permalink) Old 07-11-2007, 12:28 AM
TSB
2000-2005 Excursion
ISSUE:
ACTION:
SERVICE PROCEDURE
WARRANTY STATUS:
yeah says not warranty. I like how it says not to be done by the do it yourselfers, real indepth process. Personally id sand it the best I could, and use por 15, never have another problem.
#23 Singles Club
thejdman04 is offline
post #5 of 5 (permalink) Old 07-11-2007, 03:33 PM
01blkf250's Avatar
Thanks guys for the replies, I guess I'll have to do it myself. It's just with my back still giving me fits, was hoping to get it done while it didn't require anything from me but driving it to the dealer. Thejdman04, I was actually planning on using POR15, that there is some good stuff. Gene ;mafia
