05-19-14 Long Crank Or Runs Rough At Factory Delivery Or After High Pressure Oil Syst - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 0 replies and been viewed 940 times.
post #1 of 1 (permalink) Old 03-23-2007, 12:42 PM Thread Starter
Squatch's Avatar
Printable View (8 KB)
TSB
05-19-14 LONG CRANK OR RUNS ROUGH AT FACTORY DELIVERY OR AFTER HIGH PRESSURE OIL SYSTEM REPAIR - 6.0L
Publication Date: September 19, 2005
FORD: 2003-2005 Excursion
2003-2006 F-Super Duty
2004-2006 E-Series, F-650, F-750
ISSUE:
Some 2003-2006 model year vehicles equipped with a 6.0L diesel engine may exhibit a crank time longer than 2.5 seconds in ambient temperatures above 32 F (0 C) and/or during hot restarts, or may exhibit a runs rough condition with no diagnostic trouble codes (DTCs). These conditions may be noticed at factory delivery or after a repair involving removal of high-pressure oil system components. This may be caused by air trapped in the high-pressure oil system.
ACTION:
To purge the air, drive the vehicle through at least 12 short, high-demand cycles, or until crank-time has improved (Example: 12 aggressive accelerations 25 MPH to 50 MPH (32 Km/h to 80 Km/h)). Turn off the engine for 5 minutes following the drive cycle, then restart the engine. If crank time remains above 2.5 seconds, perform normal hard start diagnostics per the PC/ED manual.
NOTE: A THREE TO FIVE (3-5) SECOND CRANK TIME MAY BE CONSIDERED NORMAL IN COLDER TEMPERATURES.
NOTE: IF THIS PROCEDURE IS NOT FOLLOWED, IT MAY TAKE MORE THAN 100 MILES OF NORMAL DRIVING TO REMOVE ALL OF THE TRAPPED AIR.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
DEALER CODING
BASIC PART NO. CONDITION CODE
9A543 53
Copyright 2005 Ford Motor Company
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
