05-16-6 Misfire, Lack Of Power, Smoke, Slow Crank In Cold Weather On Initial Start Up - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 0 replies and been viewed 1481 times.
post #1 of 1 (permalink) Old 03-23-2007, 12:45 PM Thread Starter
Squatch's Avatar
Printable View (29 KB)
TSB
05-16-6 MISFIRE, LACK OF POWER, SMOKE, SLOW CRANK IN COLD WEATHER ON INITIAL START UP - 6.0L ENGINE
Publication Date: August 2, 2005
FORD: 2003-2005 Excursion
2003-2006 F-Super Duty
2004-2006 E-Series, F-650, F-750
ISSUE:
Some 6.0L equipped 2003-2006 F-Super Duty, 2003-2005 Excursion, 2004-2006 F-650/750 and E-Series vehicles may exhibit a misfire, lack of power, smoke, or slow crank in cold weather on initial start up. This may be due to the oil viscosity being too high. The use of high viscosity multi-grade oil can slow cranking speed more than 30% at -20 F (-29 C), resulting in longer crank times. High viscosity multi-grade oil may delay fuel injection timing by slowing reaction of high-pressure oil control system integral to each injector.
ACTION:
Refer to the oil viscosity chart provided in this TSB. It has been updated and is recommended for all 6.0L DI Diesel model years. Apply the vehicle operating conditions to the oil viscosity chart and select the appropriate viscosity oil grade. Use Motorcraft or equivalent oil conforming to Ford specification WSS-M2C171-D or API service categories CI-4 PLUS, CI-4/SL or DHD-1. If CI-4 PLUS oil is not available, CH-4 is acceptable.
NOTE: ALSO INCLUDED IN THE CHART IS CLARIFICATION OF THE RECOMMENDED OIL VISCOSITY GRADE TO USE WHEN TOWING A TRAILER.
Figure 1 - Article 05-16-6
WARRANTY STATUS:
Information Only - Not Warrantable
Copyright 2005 Ford Motor Company
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
