05-13-9 Diesel Exhaust Smell In Cab - 6.0l Engine - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 1 replies and been viewed 3410 times.
post #1 of 2 (permalink) Old 03-23-2007, 12:46 PM Thread Starter
Squatch's Avatar
Printable View (10 KB)
TSB
05-13-9 DIESEL EXHAUST SMELL IN CAB - 6.0L ENGINE
Publication Date: June 21, 2005
FORD: 2003-2005 Excursion
2003-2006 F-Super Duty
2004-2006 E-Series
ISSUE:
Some vehicles equipped with a 6.0L engine may exhibit a diesel odor in the cab.
ACTION:
It may be necessary to replace the exhaust manifold gasket. Refer to the following Service Procedure.
SERVICE PROCEDURE
Start the engine and warm it to normal operating temperature.
Remove the exhaust pressure (EP) sensor.
NOTE: SOME BUBBLING OF MOISTURE/SOOT BETWEEN THE EXHAUST MANIFOLD AND HEAD WHEN THE ENGINE AND MANIFOLD ARE COLD IS NORMAL. ONCE THE ENGINE AND MANIFOLD ARE AT OPERATING TEMPERATURE, THEY SHOULD BE SEALED.
Using the Rotunda Smoke Machine (218-00001) induce smoke into the EP tube. Inspect for leaks around the exhaust manifolds and y-pipe. If a leak is found at the exhaust manifold, replace only the exhaust manifold gasket that is leaking.
NOTE: EXHAUST MANIFOLD GASKETS ARE NOT REUSABLE.
PART NUMBER PART NAME
5C4Z-9448-A Exhaust Gasket
WARRANTY STATUS:
OPERATION DESCRIPTION TIME
051309A 2004-2006 Econoline 6.0L: Install Exhaust Manifold Gasket, Includes Time To Diagnose Using Smoke Machine: Right Exhaust Manifold (Do Not Use With 9430A) 1.9 Hrs.
051309B 2004-2006 Econoline 6.0L: Install Exhaust Manifold Gasket Includes Time To Diagnose Using Smoke Machine: Left Exhaust Manifold (Do Not Use With 9430A) 1.6 Hrs.
051309C 2004-2006 Econoline 6.0L: Install Exhaust Manifold Gaskets Includes Time To Diagnose Using Smoke Machine: Both Exhaust Manifolds (Do Not Use With 9430A) 2.6 Hrs.
051309D 2003-2006 Super Duty 2003-2005 Excursion 4X2 6.0L: Install Exhaust Manifold Gasket Includes Time To Diagnose Using Smoke Machine: Right Exhaust Manifold (Do Not Use With 9430A) 1.9 Hrs.
051309E 2003-2006 Super Duty 2003-2005 Excursion 4X2 6.0L: Install Exhaust Manifold Gasket Includes Time To Diagnose Using Smoke Machine: Left Exhaust Manifold (Do Not Use With 9430A) 1.2 Hrs.
051309F 2003-2006 Super Duty 2003-2005 Excursion 4X2 6.0L: Install Exhaust Manifold Gaskets Includes Time To Diagnose Using Smoke Machine: Both Exhaust Manifolds (Do Not Use With 9430A) 2.5 Hrs.
051309G 2003-2006 Super Duty 2003-2005 Excursion 4X4 6.0L: Install Exhaust Manifold Gasket Includes Time To Diagnose Using Smoke Machine: Right Exhaust Manifold (Do Not Use With 9430A) 1.9 Hrs.
051309H 2003-2006 Super Duty 2003-2005 Excursion 4X4 6.0L: Install Exhaust Manifold Gasket Includes Time To Diagnose Using Smoke Machine: Left Exhaust Manifold (Do Not Use With 9430A) 1.6 Hrs.
051309I 2003-2006 Super Duty 2003-2005 Excursion 4X4 6.0L: Install Exhaust Manifold Gasket Includes Time To Diagnose Using Smoke Machine: Both Exhaust Manifold (Do Not Use With 9430A) 2.9 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
9430 14
Copyright 2005 Ford Motor Company
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #2 of 2 (permalink) Old 03-23-2007, 03:41 PM
Old Geezer-TDG Mafia #19
LargeCar's Avatar
Images: 9
Actually, there is no gaskets on the 6.0 engine now, so this just installs the gaskets.
I have the leaks and plan on either have the tech put them in or have him hand them to me so I can put them in.
I'll let you know what happens.
LargeCar :mafia
LargeCar
Mafia # 19 The Dually Club # 19
If a country does not remember and honor its fallen heroes of the past, in the future that country will not be honored or remembered.
G.R. Wemmer
A veteran is someone who, at one point in his/her life wrote a blank check made payable to 'The United States of America' for an amount of 'up to and including their life.' That is Honor, and there are way too many people in this country who no longer understand it.
LargeCar is offline
