05-5-7 Low Battery Voltage - Snow Plow Equipped Vehicles - 6.0l Diesel With Single Ge - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 0 replies and been viewed 1170 times.
post #1 of 1 (permalink) Old 03-23-2007, 12:47 PM Thread Starter
Squatch's Avatar
Printable View (6 KB)
TSB
05-5-7 LOW BATTERY VOLTAGE - SNOW PLOW EQUIPPED VEHICLES - 6.0L DIESEL WITH SINGLE GENERATOR
Publication Date: March 4, 2005
FORD: 2003-2005 F-Super Duty
ISSUE:
Some 2003-2005 Super Duty F-Series equipped with a 6.0L diesel engine and a single generator, may exhibit low battery voltage when plowing for an extended period, and while using a salt spreader and/or other lighting accessories added on by the customer.
ACTION:
If the charging system only exhibits the condition with all of the aftermarket accessories in use, there is a 140 AMP service generator available for customer purchase. This is the same generator used in the factory installed snow plow package.
NOTE: THIS REPAIR MAY NOT BE 100% EFFECTIVE ON ALL VEHICLES FOR VARIOUS REASONS. EXAMPLES: AS SNOW PLOW, SANDER/SALTER AND OTHER EQUIPMENT AGE, THEIR ELECTRICAL LOAD DEMAND MAY INCREASE. ALSO, THE TYPE OF PLOWING (SHORT DISTANCE PLOWING) MAY IMPACT THE ABILITY OF THE CHARGING SYSTEM TO COMPENSATE FOR THE DRAW.
PART NUMBER PART NAME
4C3Z-10346-BA Generator - 140 Amp
WARRANTY STATUS:
Information Only - Not Warrantable
Copyright 2005 Ford Motor Company
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
