04-25-16 Mil Illuminated With Dtc P0756, P0761 Or P0771 After Overhaul Or Installatio - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 0 replies and been viewed 2381 times.
post #1 of 1 (permalink) Old 03-23-2007, 12:48 PM Thread Starter
Squatch's Avatar
Printable View (6 KB)
TSB
04-25-16 MIL ILLUMINATED WITH DTC P0756, P0761 OR P0771 AFTER OVERHAUL OR INSTALLATION OF 2005 TORQSHIFT TRANSMISSION
Publication Date: December 14, 2004
FORD: 2003-2004 Excursion, F-Super Duty
2004 E-Series
ISSUE:
Some vehicles equipped with a 6.0L diesel and the Torqshift transmission, may exhibit the malfunction indicator lamp (MIL) illuminated with diagnostic trouble code (DTC) P0756, P0761 or P0771. This condition will occur if the powertrain control module (PCM) and transmission control module (TCM) are not reprogrammed after installing a 2005-level replacement transmission, installing transmission rebuild kit 5C3Z-7A398-SA, or after overhauling the transmission with 2005-level components.
ACTION:
Reprogram the PCM and TCM to the latest calibration using WDS release B34.2 or higher. Calibration files may also be obtained at www.motorcraft.com. Clear KAM, DTCs and verify repair.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
OPERATION DESCRIPTION TIME
042516A Check For Diagnostic Trouble Codes And Reprogram The Powertrain Control Module (PCM) And The Transmission Control Module (TCM) 0.7 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
RECALEM 42
Copyright 2004 Ford Motor Company
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
