04-25-4 Hard Start Or No Start - 7.3l - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 0 replies and been viewed 921 times.
post #1 of 1 (permalink) Old 03-23-2007, 12:49 PM Thread Starter
Squatch's Avatar
Printable View (33 KB)
TSB
04-25-4 HARD START OR NO START - 7.3L
Publication Date: December 2, 2004
FORD: 2000-2003 E-Series, Excursion, F-Super Duty
This article supersedes TSB 04-22-8 to update Figure 1.
ISSUE:
Some 7.3L vehicles equipped with the glow plug control module (GPCM), may exhibit a hard start or no start condition. This may be due to the GPCM connector.
ACTION:
A new GPCM connector service kit, available for the 6.0L engine, can now be adapted to the 7.3L engine. Refer to the following Service Procedure.
SERVICE PROCEDURE
Inspect the GPCM connector for pin conditions such as; pin fit, pull out, bent, corrosion, etc.
If a concern is found, replace the GPCM connector with the kit. The kit contains a replacement connector with pigtail to be spliced into the existing harness. DISREGARD THE INSTRUCTIONS INCLUDED IN THE KIT (WHICH ONLY APPLY TO 6.0L) AND REFER TO FIGURE 1 FOR WIRE SPLICING.
If no concerns are present, proceed with normal diagnosis.
Figure 1 - Article 04-25-4
PART NUMBER PART NAME
4C3Z-12B568-AA GPCM Connector Kit
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
DEALER CODING
BASIC PART NO. CONDITION CODE
12B568 X2
Copyright 2004 Ford Motor Company
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
