04-24-11 Momentary Return To Idle During Aggressive Acceleration - Diagnostic Trouble - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 0 replies and been viewed 689 times.
post #1 of 1 (permalink) Old 03-23-2007, 12:50 PM Thread Starter
Squatch's Avatar
Printable View (7 KB)
TSB
04-24-11 MOMENTARY RETURN TO IDLE DURING AGGRESSIVE ACCELERATION - DIAGNOSTIC TROUBLE CODE (DTC) P0123 - 7.3L ENGINE
Publication Date: November 24, 2004
FORD: 2001-2003 Excursion, F-Super Duty
ISSUE:
Some 2001-2003 F-Series Super Duty and Excursion vehicles equipped with the 7.3L engine and a non-adjustable (fixed) accelerator pedal, may exhibit the malfunction indicator lamp (MIL) illuminated intermittently, and a momentary return to idle during aggressive acceleration. Diagnostic trouble code (DTC) P0123 will be stored in the powertrain control module (PCM) when the condition occurs, but may be cleared after forty (40) vehicle warm up cycles if no repeat conditions occur.
ACTION:
If normal PC/ED Manual diagnostics do not identify a root cause, install a revised fixed accelerator pedal. Refer to Workshop Manual Section 310-02.
PART NUMBER PART NAME
1C3Z-9F836-BA Pedal - Accelerator
WARRANTY STATUS:
OPERATION DESCRIPTION TIME
042411A Replace Accelerator Pedal (Includes Time To Check And Clear Diagnostic Trouble Codes) 0.4 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
9F836 42
Copyright 2004 Ford Motor Company
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
