04-23-6 Vehicle Lean/sag When Observed From Rear Of Vehicle - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 0 replies and been viewed 1251 times.
post #1 of 1 (permalink) Old 03-23-2007, 12:51 PM Thread Starter
Squatch's Avatar
Printable View (54 KB)
TSB
04-23-6 VEHICLE LEAN/SAG WHEN OBSERVED FROM REAR OF VEHICLE
Publication Date: November 10, 2004
FORD: 1999-2005 F-250, F-350
ISSUE:
Some 1999-2005 F-Super Duty 250/350 vehicles may exhibit a vehicle lean or sag, to the right or left, when looking at the vehicle from the rear.
ACTION:
It may be necessary to install Ford approved shims to correct vehicle lean condition. Refer to the following Service Procedure.
SERVICE PROCEDURE
NOTE: WHEN VERIFYING THE VEHICLE LEAN ALL EQUIPMENT MUST BE REMOVED FROM THE VEHICLE SUCH AS TOOL BOXES, CAPS, BED FUEL TANKS, ETC. THE VEHICLE MUST BE PARKED ON A LEVEL SURFACE.
NOTE: THIS REPAIR MAY ONLY BE PERFORMED ON THE REAR OF THE VEHICLE. DO NOT ATTEMPT THIS PROCEDURE ON THE FRONT OF THE VEHICLE.
Check for fractured or broken springs, both front and rear.
If a spring is fractured, replace the spring and re-evaluate the vehicle. If the condition is corrected return the vehicle to the customer, if not proceed to Step 2.
NOTE: IF SPRING REPLACEMENT IS NECESSARY, REFER TO PART CATALOG FOR PROPER APPLICATION AND PART NUMBER INFORMATION.
If springs are found to be OK, proceed to Step 2.
Check tire pressures and adjust if necessary.
Measure the vehicle ride height from wheel lip to top of wheel well opening, at all four corners, Figure 1.
Figure 1 - Article 04-23-6
Calculate the difference between left to right (Worksheet 1).
Worksheet 1 (Wheel Lip To Wheel Well Opening)
LF RF Difference Left To Right LR RR Difference Left To Right
Measure chassis ride height per Workshop Manual Section 204-00 (Description And Operation; Ride Height) at all four corners and calculate the difference between left to right (Worksheet 2).
Worksheet 2 (Chassis Ride Height Per Workshop Manual Procedure)
Refer to the following chart for repair action to take.
Repair Action Chart
Wheel Lip To Wheel Well Difference Left To Right Chassis Ride Height Difference Left To Right Action
0 to 3/4" (19 mm) N/A No action to be taken
Greater than 3/4" (19 mm) Less than 3/4" (19 mm) No chassis correction authorized, investigate frame and body systems
Greater than 3/4" (19 mm) 3/4" to 1" (19 to 25 mm) Install shim 3C4Z-5A300-AA on low side of vehicle
Greater than 3/4" (19 mm) Greater than 1" to 1 3/4" (25 to 44 mm) Install shim 5C3Z-5742-AA on low side of vehicle
Greater than 3/4" (19 mm) 2" and Greater (51 mm and Greater) Replace spring
If shim installation is needed, install the shim as shown in Figures 2 and 3.
Figure 2 - Article 04-23-6
Figure 3 - Article 04-23-6
Inspect U-bolts and replace if necessary.
NOTE: IF U-BOLT REPLACEMENT IS NECESSARY, REFER TO PART CATALOG FOR PROPER APPLICATION AND PART NUMBER INFORMATION.
After shim installation re-measure the vehicle ride height per Workshop Manual Section 204-00. If the ride height is now greater than 200 mm for a single rear wheel vehicle, or 210 mm for a dual rear wheel vehicle replace the spring.
CAUTION: IF NECESSARY INSTALL NEW SUSPENSION FASTENERS. ALWAYS REPLACE FASTENERS WITH THE SAME PART NUMBER, OR AN EQUIVALENT PART. DO NOT USE A REPLACEMENT FASTENER OF LESSER QUALITY OR DIFFERENT DESIGN. TORQUE VALUES MUST BE USED AS SPECIFIED IN THE WORKSHOP MANUAL FOR CORRECT RETENTION OF COMPONENT.
PART NUMBER PART NAME
3C4Z-5A300-AA 1/2" Shim
5C3Z-5742-AA 1" Shim
WARRANTY STATUS:
DEALER CODING
BASIC PART NO. CONDITION CODE
5560 63
Copyright 2004 Ford Motor Company
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
