04-17-13 Hard Start Or No Start - Gpcm Connector Service Kit Available - 6.0l Engine - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 0 replies and been viewed 4177 times.
post #1 of 1 (permalink) Old 03-23-2007, 12:55 PM Thread Starter
Squatch's Avatar
Printable View (7 KB)
TSB
04-17-13 HARD START OR NO START - GPCM CONNECTOR SERVICE KIT AVAILABLE - 6.0L ENGINE
Publication Date: August 24, 2004
FORD: 2003-2004 Excursion, F-Super Duty
ISSUE:
Some 6.0L equipped vehicles may exhibit a hard start or no start condition due to a glow plug control module (GPCM) connector.
ACTION:
Inspect the GPCM connectors for pin related concerns such as pin fit, pull out, bending, corrosion, etc. If a concern is found, replace the green or black GPCM connector using the new GPCM connector service kit. The kit contains an instruction sheet and a replacement connector with a pigtail that can be spliced into the existing harness. If no pin related concerns are present, proceed with normal diagnosis.
PART NUMBER PART NAME
4C3Z-12B568-AA GPCM Connector Kit
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
OPERATION DESCRIPTION TIME
041713A Inspect The GPCM Connectors And Replace The Green Connector (Includes Time To Perform A Pin To Pin Continuity Check) 1.7 Hrs.
041713B Inspect The GPCM Connectors And Replace The Black Connector (Includes Time To Perform A Pin To Pin Continuity Check And Access The ICP Sensor) 2.1 Hrs.
041713C Inspect The GPCM Connectors And Replace Both Connectors (Includes Time To Perform A Pin To Pin Continuity Check And Access The ICP Sensor) 2.9 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
12B568 X2
Copyright 2004 Ford Motor Company
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
