04-14-12 Front End Accessory Drive (fead) Belt Noise - Vehicles Built Prior To 6/1/20 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 0 replies and been viewed 1078 times.
post #1 of 1 (permalink) Old 03-23-2007, 12:58 PM Thread Starter
Squatch's Avatar
Printable View (6 KB)
TSB
04-14-12 FRONT END ACCESSORY DRIVE (FEAD) BELT NOISE - VEHICLES BUILT PRIOR TO 6/1/2004 - 6.0L ENGINE
Publication Date: July 13, 2004
FORD: 2003-2004 Excursion, F-Super Duty
ISSUE:
Some 6.0L equipped vehicles built before 6/1/2004 may exhibit excessive front end accessory drive (FEAD) belt noise when starting the engine cold. The noise is typically described as a squeal or squawk.
ACTION:
To service, replace the FEAD belt.
PART NUMBER APPLICATION
3C3Z-8620-BC F-Series - Dual Generator (1 OF 2)
3C2Z-8620-HB F-Series - Dual Generator (2 OF 2)
3C3Z-8620-DB F-Series - Single Generator
3C7Z-8620-AC Excursion
WARRANTY STATUS:
OPERATION DESCRIPTION TIME
041412A Replace Front End Accessory Drive Belt (FEAD) Single or Dual Generator 1.2 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
8620 14
Copyright 2004 Ford Motor Company
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
