07-7-2 Rear Of Vehicle Is Too High/low - 5th Wheel And Goose Neck Applications - 4x4 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 0 replies and been viewed 1824 times.
post #1 of 1 (permalink) Old 03-28-2007, 02:49 AM Thread Starter
Squatch's Avatar
Printable View (470 KB)
TSB
07-7-2 REAR OF VEHICLE IS TOO HIGH/LOW - 5TH WHEEL AND GOOSE NECK APPLICATIONS - 4X4 VEHICLES ONLY
Publication Date: March 26, 2007
FORD: 2005-2008 F-Super Duty
ISSUE:
Some 2005-2008 F-Super Duty vehicles my exhibit a clearance concern when using the vehicle to tow some goose neck and 5th wheel trailer applications.
ACTION:
Follow the Service Procedure steps to change the rear ride height.
SERVICE PROCEDURE
Rear ride height may be reduced or increased by:
Lower - vehicles that have the 4" (10 cm) spacer block by installing a new 2" (5 cm) spacer block along with the other rear suspension hardware
Raise - vehicles that are perceived as riding too low (no spacer block installed) by installing a new 2" (5 cm) spacer block along with other rear suspension hardware
LOWER VEHICLES WITH 4" (10 cm) SPACER IN PLACE
Raise vehicle on hoist and support rear axle.
Remove rear axle U-bolts and nuts.
Lower rear axle and remove 4X4 rear axle spacer blocks.
Place new spacer blocks (Figure 1) on axle and raise axle to bottom of springs, seating springs in axle seat.
Install new rear axle U-bolts and nuts (Figure 1). Torque nuts to 185 28 lb-ft (250 38 N-m).
Remove rear axle shock absorber bolts and nuts, and remove rear shock absorbers.
CAUTION: DO NOT OVER TORQUE SHOCK ATTACHING FASTENERS.
Install new rear shock absorbers (refer to Figure 4 and 5 for correct application). Torque both upper and lower shock nuts to 62.5 9.5 N-m (46 7 lb-ft).
NOTE: FAILURE TO UPDATE THE CENTER BEARING BRACKET (FIGURE 2 AND 3), IF REQUIRED, MAY RESULT IN DRIVELINE SHUDDER.
If necessary, install new center bearing and/or shim (refer to Figure 2 and 3 for correct application) assembly as required.
For checking driveline angles, refer to the Workshop Manual (WSM), Section 205-00.
Adjust headlamp aim by referring to the WSM, Section 417-01.
RAISE VEHICLES WITHOUT 4" (10 CM) SPACER
Install new rear axle U-bolts and nuts (Figure 1). Torque nuts to185 28 lb-ft (250 38 N-m).
Replace rear axle brake jounce hose assembly with new assembly, refer to the WSM, Section 206-00.
If vehicle is equipped with a rear suspension stabilizer bar, replace rear stabilizer bar links with new stabilizer bar links. Torque stabilizer link nuts to 70 15 N-m (52 11 lb-ft).
Bleed rear brake system by referring to the WSM, Section 206-00.
For checking driveline angles, refer to WSM, Section 205-00.
NOTE: RIDE HEIGHT ISSUES RELATED TO A CUSTOMER'S TRAILER ARE NOT COVERED UNDER WARRANTY.
PART NUMBER PART NAME
F81Z-5K484-CA Stabilizer Bar Links (2 Required)
5C3Z-2282-AA Brake Jounce Hose Asy
WARRANTY STATUS:
Information Only - Not Warrantable
Figure 1 - Article 07-7-2
Figure 2 - Article 07-7-2
Figure 3 - Article 07-7-2
Figure 4 - Article 07-7-2
Figure 5 - Article 07-7-2
Copyright 2007 Ford Motor Company
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
The Following User Says Thank You to Squatch For this addition to TDG:
NF Rover (10-10-2010)
