06-22-6 Buck/jerk Steady Throttle Or Slight Tip In - 6.0l - Built On Or Before 3/15/2 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 0 replies and been viewed 1130 times.
post #1 of 1 (permalink) Old 03-28-2007, 02:52 AM Thread Starter
Squatch's Avatar
Printable View (47 KB)
TSB
06-22-6 BUCK/JERK STEADY THROTTLE OR SLIGHT TIP IN - 6.0L - BUILT ON OR BEFORE 3/15/2006
Publication Date: October 23, 2006
FORD: 2005-2006 F-Super Duty
This article supersedes TSB 06-5-11 to add a production fix date.
ISSUE:
Some 2005-2006 F-Super Duty vehicles built on or before 3/15/2006 equipped with a 6.0L engine may exhibit a buck/jerk condition in Low (L), first (1st), or second (2nd) in manual transmission vehicles, or in manual 1st, manual 2nd, or in tow-haul mode in first (1st) or second (2nd) on automatic transmission vehicles. This concern occurs anywhere from 1800-2500 RPM at steady throttle or slight tip in. Concern will be more evident under a load, or while pulling a trailer. This concern is more noticeable in manual transmission equipped vehicles.
ACTION:
Reprogram the powertrain control module (PCM) to the latest calibration using IDS release B41.11 and higher or B42.1 and higher. This new calibration is not included in the B42 CD. Calibration files may also be obtained at www.motorcraft.com.
WARRANTY STATUS:
OPERATION DESCRIPTION TIME
062206A 2005-2006 F-Super Duty 6.0L: Check For Diagnostic Trouble Codes And Reprogram The Powertrain Control Module (Do Not Use With 12650D, 12650D84) 0.7 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
recal 04
Copyright 2006 Ford Motor Company
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
