oasis report please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bootcamp, this thread has received 1 replies and been viewed 375 times.
post #1 of 2 (permalink) Old 03-29-2007, 04:50 PM Thread Starter
bootcamp's Avatar
oasis report please
Had this truck since late 05 ,it is and 05vin#1ftsw21p45ec11632
thanks bootcamp
USMC 87-90 MOTOR-T
Build Date 01/05 05 F250 4x4 swb cc lariat
SCT XCAL3 Tune by DFuser,fluid damper,MBRP exhaust-no kitty, crossover fuel line, Coolant filter, CFM Intake elbow, Pro Comp 6" stage 2 lift and traction bars,ccv reroute, Gauges-trans,pyro,fuel,bbreg mod, B&W goose neck and companion hitch, firestone airbags, Earls anplumbing-6 hose and fittings to upgrade fuel lines,T/P stage I fuel line kit,Welded up pipe and welded egr cooler install, 4.10 yukon gears, ceramic coated manifolds install with new head gaskets and ARP's, PML trans pan, AEM brute air filter, AirDogII 165 sucking it straight off the bottom of the tank with Hellmans sump and Strictly Diesel RR kit
2010 Honda VFR1200 for when I really want to go FAST My newest collection to the armada, 2004 VW R32 and its all wheel drive
SINGLES CLUB MEMBER #259
bootcamp is offline
post #2 of 2 (permalink) Old 03-30-2007, 02:51 AM
Squatch's Avatar
OASIS RESULT:
1FTSW21P45EC11632
03/29/2007
21:51:18
FCXWS44
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-17-06
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 06-23-02
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/09/2005 BUILD DATE
01/27/2005 SALE MILEAGE
00583
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
12/08/2006
DEALER: Gray Ford Mercury
WARRANTY CLAIM NUMBER: 174963 ODOMETER: 026250M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 8213AA ORN ASSY 001 16098A 81 TARNISHED/FADED
PEELING REMOVED GRILLE. REPLACED EMBLEM.
12/08/2006
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9C064DA FUEL FILTER "O"RING 001 12650D57 D8 FAILED GASKET/SEAL
3C3Z 6700BA OIL SEAL CYL FRT COV 001 12650D60
3C3Z 9N693HA RING-SEALING 001 6700A
3C3Z 9N693JA RING-SEALING 001 6007D
FRONT CRANK SHAFT SEAL FAILED, O-RINGS ON CAM AND CRANK SENSORS ARE LEAKING REPLACED FRONT CRANKSHAFT SEAL AND O-RINGS ON SENSORS.
05/19/2006
WARRANTY CLAIM NUMBER: 170596 ODOMETER: 015307M
LABOR OP
CONDITION CODE
CONDITION DESC
6007 ENGINE ASSY 000 6007D 42 DOES NOT OPERATE PROPERLY
OSP 002
ADDED SYE TO SYSTEM AND TESTED WITH BLACK LIGHT..NO LEAKS FOUND AT THIS TIME ..
END OF OASIS REPORT FOR 1FTSW21P45EC11632
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
