Oasis on early 03 6.0:) - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Hybrid_4x4_Superduty, this thread has received 4 replies and been viewed 1585 times.
post #1 of 5 (permalink) Old 03-30-2007, 04:11 AM Thread Starter
TDG Mafia Member #64!
Hybrid_4x4_Superduty's Avatar
Send a message via Yahoo to Hybrid_4x4_Superduty
PLEASE
1FTSW31P03ED71039
Thank ya
-ADAM-
2008 Ford F-350 King Ranch, 4x4, 6.4L, Powerstroke Diesel, Torqueshift, Spartan Tuned, 4in FloPro Straight Duals, Afe Stg 2 Intake, Chromed & Tinted out!!! 115k Miles!
Hybrid_4x4_Superduty is offline
post #2 of 5 (permalink) Old 04-07-2007, 01:57 AM Thread Starter
:secret: ?
-ADAM-
post #3 of 5 (permalink) Old 04-13-2007, 04:42 AM Thread Starter
a little friendly.....*bump*...:
-ADAM-
post #4 of 5 (permalink) Old 04-13-2007, 04:48 AM
Squatch's Avatar
OASIS RESULT:
1FTSW31P03ED71039
04/12/2007
23:48:08
FCXWS447
Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 06-23-02
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/12/2003 BUILD DATE
06/11/2003 SALE MILEAGE
00112
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0736 - USA 2005 USED 48/48,000 PREMIUMCARE W/ROADSIDE ASSIST
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: AJ JOHNSON
OPTIONS:
EXPIRATION DATE: 10/14/2009
DISTANCE: 100,554
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 02762
ESP CONTRACT START DATE: 10/14/2005
WARRANTY REPAIR HISTORY
12/26/2006
DEALER: Northern Motor Company
WARRANTY CLAIM NUMBER: 124068 ODOMETER: 074236M
LABOR OP
CONDITION CODE
CONDITION DESC
F2UZ 14526P FUSE-ELECTRICAL CIRC 001 7000A 69 FROZEN/SEIZED/BINDING
3C3Z 7000GKRM TRANSMISSION ASY-AUT 001 7000AXQ
3C3Z 7B155BA FLTR&HD ASY TRNS OIL 001 7000AZJ
XT 5QM 013 MT7000A2
87034S94 001 7000A2ZG
7A103 FRONT PUMP ASY-TRANS 000 7000F
CHECKED SVC CODES P0720 OSS SENSOR P1744 TORQUE CONVERTER CL UTCH P2701 TRAN S FICTION 3 P0730 CONTROL MALF P2700 FRICT A ELEMENT P2702 FRICTON C CHECK ED LINE PRESSURE HAS 0 LINE PRE SSURE REMOVED AND DIASSEMBLED TRANSMISSION R EMOVED TORQUE CONVERTER FRONT PUMP BUSHING WAS SEIZED ON TORQUE CONVERTER RE MOVED FRONT PUMP PUMP GEARS BROKE AND SCARRED REMOVED REAR PLANET ASSY REAR
10/20/2006
WARRANTY CLAIM NUMBER: 122623 ODOMETER: 071043M
LABOR OP
CONDITION CODE
CONDITION DESC
F81Z 4800EA SUPPORT-CPL SHFT BRG 001 4602A4F 42 DOES NOT OPERATE PROPERLY
000 1007D
CHECKED GROWLING NOISE SOUNDS LIKE FROM FRONT END CHECKED FRONT WHEEL BEARIN GS CHECKED END PLAY CHECKED WHEEL RUN OUT CHECKED FRONT DIFF SIDE AND PINION BEARINGS CHECKED REAR AXLE AND DIFF USED CHASSIS EARS TO PINPOINT NOISE TO DRIVESHAFT CARRIER BEARING REMOVED REAR DRIVESHAFTS REPLACED CARRIER BEARING ASSEMBLY
09/23/2006
WARRANTY CLAIM NUMBER: 121952 ODOMETER: 069852M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 7A098AA SCREEN ASY - OIL PAN 001 7000F 42 DOES NOT OPERATE PROPERLY
3C3Z 7N134BA BLT ASY-TRANS BREA 009 7000F2
5C3Z 7A095CB COOLER-TRANS OIL 001 7000A
3C3Z 7B164DA PLT ASY-CLTCH IN SPL 004 7000AXQ
5C3Z 7B442CA PLATE-REAR CLUTCH DR 003 7000AZJ
3C3Z 7B442AA PLATE-REAR CLUTCH DR 003 7000A2
3C3Z 7B164AA PLT ASY-CLTCH IN SPL 003 7000A2ZG
3C3Z 7B164FA PLT ASY-CLTCH IN SPL 003 7000A11
3C3Z 7153AD GASKET TRANSMISSION 001 7000F13
XT 6QSP 016 7095C
3C3Z 7902ABRM CONVERTER ASY 001
3C3Z 7J136AA SOL ASY-TRANS DIR EL 001
3C3Z 7J136BA SOL ASY-TRANS DIR EL 001
OF COMMUNICTION BETWEEN PCM FICM P P TST A51 THRU A56 ALSO A T1 TRRU AT4 FIC M MOUDLE PLUGGED IN BETWEEN FICM MGP SENOSR C LEARED CODES ROAD TST SLIPPS IN 4 GEAR HAS DELAY ENGAGEMENT IN REVERSE PREFORM SSM 17643 STILL SHIFTS TH E SAME R I TRANS AND INSPECT FOUND CLUTCHES BURNT AND METAL IN PAN DIRECT AN D OD CLUTCH BURNT CONTAMINATED SYS RESEAL TRANS REPLACED PISTO NS AND BURNT
08/08/2006
WARRANTY CLAIM NUMBER: 120761 ODOMETER: 066494M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 1007FA WHEEL ASSY 003 1007AT 42 DOES NOT OPERATE PROPERLY
CK ALL FOUR RIMS ARE PEELING AND HAVE COROSION ON THEM REPLA CED RIMS AND BA LANCED CK OK NOW
08/08/2006
LABOR OP
CONDITION CODE
CONDITION DESC
3F2Z 15K859BA SENSOR - PARKING AID 001 MT15K859 X2 CONNECTION POOR/NOT MADE
1C3Z 15K868AA WIRE-SENSOR PARKING 001 MT15K868
000 12651D
000 12651DX1
000 12651D2
CK BACK UP SENSOR OPS TST FOR CODES C1704 RT OUTER SENSOR AN D HARNESS IS CO RRODED NEEDS SENSOR AND HARNESS P P TST B1 B 7 REPALCED SENSOR AND HARNESS CLEARED CODES CK SYS PASS
04/14/2006
WARRANTY CLAIM NUMBER: 117704 ODOMETER: 060170M
LABOR OP
CONDITION CODE
CONDITION DESC
2C3Z 5484AA INSULATOR STABILIZER 002 5493AF 33 LOOSE PART
5C3Z 3050A KIT-FRT SUSP LWR SPD 002 3049AT
4C3Z 3049DA JOINT ASY-FRT SUSP L 002 3001A
F81Z 3254CB OIL SEAL-FRONT AXLE 002
F81Z 4A322AA SEAL FRT WHL HUB 002
F81Z 1S175HCA BEARING-AXLE REAR 002
4C3Z 1K106AA SNP RNG/SCRW-WARN HU 001
C6TZ 3123A BEARING ASY-SPINDLE 002
FOUND FRONT SWAY BAR BUSHINGS ARE RELAXED REPLACED BUSHINGS CHECK BOTH LOWER BALL JOINTS ARE LOOSE NEED TO REPLACE BALL JOINTS REPLACED ALL FOUR BALL JO INT GREASE SEALS AND PIN BEARINGS
04/14/2006
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9T516A KIT-TUBE TRBCH OIL S 001 6005E 42 DOES NOT OPERATE PROPERLY
3C3Z 6K682BARM TURBO CHG-EXH DRIVE 001 6005E2
W300020 001 6005E3
3C3Z 6766BA CAP ASY OIL FILLER 001 6005F12
000 6005F25
000 9438A
000 9438AZW
CHECKED SVC CODES P0297 VEHICLE OVER SPEED PERFORMED PP TST KA1 THRU KA10 RO AD TESTED FOUND TURBO CHARGER VGT AT 85% AND EBP READING AT 15PSI AND BOOS T AT 3PSI AT 3-4 THROTTLE AFTER A BRIEF ACCELERATION THEN CRUISE FOR APROX 1 -2 MILE THEN ACCELL AGAIN WHEN THROTTLE REACHES NEAR WOT TRANS SHIFTS AND TU RBO MAKES BOOST R&R AIR CLEANER ASSY OIL SEPERATOR COOLANT DEGAS BOTTLE CAC
04/14/2006
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 12A690BA WIRING ASY EC SENSOR 001 MT12A690 42 DOES NOT OPERATE PROPERLY
3C3Z 12A690AA WIRING ASY EC SENSOR 001
CHECKED OIL LEAKING FROM GLOW PLUG BUSHING BAR ASSEMBLY NEED TO REPLACED BUS BARS REPLACED GLO PLUG WIRE HARNESSES O N BOTH SIDES
04/14/2006
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 7G383AA EPC SOLENOID 001 7000F 42 DOES NOT OPERATE PROPERLY
3C3Z 7B155BA FLTR&HD ASY TRNS OIL 001 7191A1
XT 6QSP 012
PERFORMED LINE PRESSURE TEST ROAD TEST SLIPS DELAY IN REVERSE CHECK INLINE F ILTER GRAY IN COLOR METAL REMOVED PAN INSPECT FOR METAL CALL HOTLINE REPLACE D PRESSURE CONTROL SOLENOID CLEANED ALL SOLENOIDS CLEAR KEEP ALIVE MEMORY RO AD TEST SHIFTS GOOD
04/14/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 06E17B
1 PERFORM RECALL
04/14/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
1 PERFORM RECALL
END OF OASIS REPORT FOR 1FTSW31P03ED71039
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #5 of 5 (permalink) Old 04-19-2007, 03:35 AM Thread Starter
Thanks so much!
-ADAM-
