oasis report please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by outlawcrewcab, this thread has received 3 replies and been viewed 563 times.
post #1 of 4 (permalink) Old 03-30-2007, 09:42 PM Thread Starter
oasis report please
1FTWW32P54EA84457
Please looking at a 04 f350 with the 6.0 not sure if i should buy it or keep looking for a 7.3
outlawcrewcab is offline
post #2 of 4 (permalink) Old 03-30-2007, 09:42 PM Thread Starter
Thanks in advance
post #3 of 4 (permalink) Old 03-31-2007, 02:07 PM
Standard Claims List For Model Year 2004
1FTWW32P54EA84457 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 16-SEP-2003 08-OCT-2003 152303 USA 4 2E05 100106 3C3Z 9B249 AB D21 49 7581
AWS Claim Key: 307207 Trx Code: 2 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 03042 - * Name: COVERT FORD OF TAYLOR, INC. Ph: 512-3658000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-JAN-2004 Doc #:02710201
Cust Comments: D21 PER CUST, THE ENG WILL LOSE POWER AND IDLES ROUGH. AT TIMES FEELS LIKE THE ENG WANTS TO STALL.
Tech Comments: EEC TEST REPLACE HFCM MANIFOLD PER SSM 17076 REPROGRAM TCM PCM FICM PER TSB RETEST AND PASS
1FTWW32P54EA84457 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 16-SEP-2003 08-OCT-2003 152303 USA 15 2E05 100106 3C3Z 9B249 AB G29 42 24467
AWS Claim Key: 2863179 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 04465 - * Name: LEIF JOHNSON FORD Ph: 512-4543711 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:02-DEC-2004 Doc #:61854301
Cust Comments: G29 WATER IN FUEL LIGHT STAYS ON
Tech Comments: VERIFY CONCERN REPLACED WATER IN FUEL SEPERATOR RETEST
1FTWW32P54EA84457 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 16-SEP-2003 08-OCT-2003 152303 USA 17 2H01 030008 3C3Z 6K854 DA E41 42 32476
AWS Claim Key: 3711932 Trx Code: E84 Labor Hrs: 4
Dlr Cd-Sub Cd: 03042 - * Name: COVERT FORD OF TAYLOR, INC. Ph: 512-3658000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:09-FEB-2005 Doc #:03878502
Cust Comments: E41 PER CUST, CAN SMELL AN EXHAUST ODOR WHILE DRIVING. CAN SMELL IN THE CAB.
Tech Comments: SMOKE TEST EXHAUSST SYSTEM FOUND EXHAUST Y PIPE LEAKING R AND I TORSO FOR ACCESS REPLACED EXHAUST Y PIPE
1FTWW32P54EA84457 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 16-SEP-2003 08-OCT-2003 152303 USA 18 2A01 031202 5C3Z 6C646 AA L65 D8 33240
AWS Claim Key: 4641030 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 02588 - * Name: GOLDING MOTORS, INC. Ph: 325-3725707 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:28-MAR-2005 Doc #:00519351
Cust Comments: FOUND ON CHECK IN, ENGINE OIL LEAK
Tech Comments: FOUND ON CK IN OIL LEAKS REPALCED CAC TUBE AND O RINGS
1FTWW32P54EA84457 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 16-SEP-2003 08-OCT-2003 152303 USA 32 * * * * * * * 51764
AWS Claim Key: 9522704 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02506 - * Name: GLOFF FORD-MERCURY Ph: 254-6758369 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:19-MAY-2006 Doc #:0050601
Cust Comments: FIELD SERVICE ACTIONS 06E17
Tech Comments: COMPLETED 06E17
AWS Claim Key: 9522705 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02506 - * Name: GLOFF FORD-MERCURY Ph: 254-6758369 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:19-MAY-2006 Doc #:0050602
Cust Comments: FIELD SERVICE ACTIONS 59B01
Tech Comments: COMPLETED 59B01
1FTWW32P54EA84457 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 16-SEP-2003 08-OCT-2003 152303 USA 39 1A01 030102 3C3Z 6049 BA E23 01 64590
AWS Claim Key: 10869915 Trx Code: E72 Labor Hrs: 21.7
Dlr Cd-Sub Cd: 02506 - * Name: GLOFF FORD-MERCURY Ph: 254-6758369 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:05-DEC-2006 Doc #:0053051
Cust Comments: CUST STATE ENG IS OVERHEATING AND MISSING
Tech Comments: PERFORMED DIAG AND PRESSURE TEST.FOUND WATER GETTING IN TO CYL.R/R ENG AND FOUND BOTH CYL HEAD CRACKED.REPLACED HEAD AND RECHECK OK.
Hitechredneck is offline
post #4 of 4 (permalink) Old 03-31-2007, 02:23 PM Thread Starter
THANK YOU!!!
Looks like i want to stay away from this one i guess im just going to mark 6.0's of my list and either go with a 7.3 or duramax
Thanks again!!
