OASIS Request Please- - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by MikeSD, this thread has received 2 replies and been viewed 495 times.
post #1 of 3 (permalink) Old 04-05-2007, 09:42 PM Thread Starter
Hello-
The VIN of the truck I am looking at is 1FTWW32P53EB99073.
Carfax shows it's been in to the dealer for repairs in the past, I'd like to know how severe.
Thanks for any help!
MikeSD is offline
post #2 of 3 (permalink) Old 04-11-2007, 04:09 AM
Squatch's Avatar
OASIS RESULT:
1FTWW32P53EB99073
04/10/2007
23:08:19
FCXWS446
Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 CREW CAB 4X2 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
F2 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 06-23-02
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/30/2003 BUILD DATE
01/13/2003 SALE MILEAGE
00359
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
10/11/2006
DEALER: Adamson Ford, L.L.C.
WARRANTY CLAIM NUMBER: 171286 ODOMETER: 055813M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 7902ABRM CONVERTER ASY 001 7000F 82 FREIGHT/POSTAGE/MAINTENANCE
5C3Z 7A103C FRONT PUMP ASY-TRANS 001 7000A
3C3Z 7A098AA SCREEN ASY - OIL PAN 001 7000A11
3C3Z 7B164FA PLT ASY-CLTCH IN SPL 001 7000A2
3C3Z 7B164DA PLT ASY-CLTCH IN SPL 004 7000AXQ
3C3Z 7B164EB PLT ASY-CLTCH IN SPL 004 7000AZJ
3C3Z 7B164CA PLT ASY-CLTCH IN SPL 006 7000A13
3C3Z 7B164BA PLT ASY-CLTCH IN SPL 004 7000A43
XT 6QSP 032
F6PZ 7153AA GASKET TRANSMISSION 001
E9TZ 7B442A PLATE-REAR CLUTCH DR 003
F81Z 7B164BA PLT ASY-CLTCH IN SPL 003
3C3Z 7J136BA SOL ASY-TRANS DIR EL 002
5C3Z 7G391C SOLENOID ASSY 001
MISC FOR REPAIRS NOT COVE 000
PERFORMED DIAGNOSTICS, DETERMINED THERE WAS EXCESSIVE INTERNAL WEAR, THE *** EMBLY WAS OVERHAULED AS NEEDED
10/11/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
55823 59B01 FINAL ROAD TEST FOR CUSTOMER ASSURANCE AFTER DRIVEABILITY REPAI R 432
10/11/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 06E17B
55823 06E17 REPROGRAM PCM, TCM, FICM 432
10/07/2006
DEALER: Ernest McCarty Ford Inc
WARRANTY CLAIM NUMBER: 206176 ODOMETER: 055633M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6F089A ACTUATOR ASSY 001 6005F 28 OPEN CIRCUIT
000 6005F13
000 6005F1
000 6005F2
000 6005F14
000 6005F20
000 6005F11
000 6005F18
000 6005F19
000 6005F21
000 6005F6
000 6005F8
000 6005F22
000 6005F12
000 6005F9
000 6005F23
000 6089A
000 VERIFY60
PERFORMANCE DIAG KOER P0237 PERFORM PINPOINT TEST KA FOUND VGT SOLENOID SHOR TED TO POWER INTERNALLY R AND R VGT ACTUATOR RETEST TEST DRIVE VERIFIED REPA IR.
END OF OASIS REPORT FOR 1FTWW32P53EB99073
Standard Claims List For Model Year 2003
1FTWW32P53EB99073 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 30-APR-2003 121359 USA 0 7S12 120303 * 19C603 * C05 X2 158
AWS Claim Key: 958502 Trx Code: 1 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 03056 - * Name: NOR-WOOD FORD LINCOLN MERCURY Ph: 910-5926056 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:17-APR-2003 Doc #:03978901
Cust Comments: CUST STATES AC IS INOP
Tech Comments: AC SYST DIAG. COMPRESSOR NOT ENGAGIN. CHECKED FOR VOLTAGE AT CYCLING SWITCH. VOLTAGE PRESENT. FOUND AC COMPRESSOR FIELD DISCONNECTED. CONNECTED FIELD AND VERIFIED OPERATION
1FTWW32P53EB99073 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 30-APR-2003 121359 USA 28 * * * * * * * 23371
AWS Claim Key: 11443811 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 00262 - * Name: ERNEST MCCARTY FORD INC Ph: 205-6633831 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:21-JUL-2005 Doc #:18242703
Cust Comments: RECALL 04S15 NEGATIVE BATTERY TERMINAL TO ENGINE BLOCK CONNECTION
Tech Comments: COMPLETED RECALL REPLACED NEGATIVE BATTERY TERMINAL ENGINE BLOCK STUD
1FTWW32P53EB99073 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 30-APR-2003 121359 USA 28 2E01 * * * * * * 23371
AWS Claim Key: 11443810 Trx Code: 03B05 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00262 - * Name: ERNEST MCCARTY FORD INC Ph: 205-6633831 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:21-JUL-2005 Doc #:18242704
Cust Comments: RECALL 03B05 INJECTION CONTROL PRESSURE (ICP) SENSOR REPLACEMENT
Tech Comments: COMPLETED RECALL 03B05 REPLACED ICP SENSOR
1FTWW32P53EB99073 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 30-APR-2003 121359 USA 28 2G05 * * * * * * 23371
AWS Claim Key: 11443809 Trx Code: 03B06 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00262 - * Name: ERNEST MCCARTY FORD INC Ph: 205-6633831 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:21-JUL-2005 Doc #:18242705
Cust Comments: RECALL 03B06 COLD OPERATION CALIBRATION PRODUCT ENHANCEMENT
Tech Comments: 1 COMPLETED
1FTWW32P53EB99073 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 30-APR-2003 121359 USA 42 2H02 030008 5C3Z 6F089 A E29 28 55633
AWS Claim Key: 14490992 Trx Code: E72 Labor Hrs: 5
Dlr Cd-Sub Cd: 00262 - * Name: ERNEST MCCARTY FORD INC Ph: 205-6633831 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:07-OCT-2006 Doc #:20617602
Cust Comments: CUST STATES CHECK ENGINE LIGHT IS ON
Tech Comments: PERFORMANCE DIAG KOER P0237 PERFORM PINPOINT TEST KA FOUND VGT SOLENOID SHORTED TO POWER INTERNALLY R AND R VGT ACTUATOR RETEST TEST DRIVE VERIFIED REPAIR.
1FTWW32P53EB99073 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 30-APR-2003 121359 USA 43 6Y20 000001 * MISC * A98 82 55813
AWS Claim Key: 14856100 Trx Code: P01 Labor Hrs: 12.1
Dlr Cd-Sub Cd: 00417 - * Name: ADAMSON FORD, L.L.C. Ph: 205-3242553 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:11-OCT-2006 Doc #:171286A
Cust Comments: THE TRANSMISSION WILL NOT PULL
Tech Comments: PERFORMED DIAGNOSTICS, DETERMINED THERE WAS EXCESSIVE INTERNAL WEAR, THE ASSEMBLY WAS OVERHAULED AS NEEDED
1FTWW32P53EB99073 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 30-APR-2003 121359 USA 43 * * * * * * * 55813
AWS Claim Key: 14672585 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00417 - * Name: ADAMSON FORD, L.L.C. Ph: 205-3242553 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:11-OCT-2006 Doc #:171286B
Cust Comments: 59B01 CUSTOMER ASSURANCE TEST DRIVE
Tech Comments: 55823 59B01 FINAL ROAD TEST FOR CUSTOMER ASSURANCE AFTER DRIVEABILITY REPAIR 432
AWS Claim Key: 14672586 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00417 - * Name: ADAMSON FORD, L.L.C. Ph: 205-3242553 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:11-OCT-2006 Doc #:171286C
Cust Comments: 06E17 MODULE CALIBRATION RECALL
Tech Comments: 55823 06E17 REPROGRAM PCM, TCM, FICM 432
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #3 of 3 (permalink) Old 04-15-2007, 11:03 PM Thread Starter
Thank You!
MikeSD is offline
