Oasis Request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by F350MX, this thread has received 2 replies and been viewed 360 times.
post #1 of 3 (permalink) Old 04-06-2007, 09:58 PM Thread Starter
Oasis Request
2003 F-350 1FTSW31P53ED62207
Thanks!
F350MX is offline
post #2 of 3 (permalink) Old 04-11-2007, 04:05 AM
Squatch's Avatar
OASIS RESULT:
1FTSW31P53ED62207
04/10/2007
23:05:13
FCXWS447
Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 06-23-02
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
06/14/2003 BUILD DATE
06/03/2003 SALE MILEAGE
00006
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0701 - USA 2005 NEW 60/75,000 PREMIUMCARE W/ROADSIDE ASSIST
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: MARK BOSHART
OPTIONS:
EXPIRATION DATE: 06/14/2008
DISTANCE: 75,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 48996
ESP CONTRACT START DATE: 06/14/2003
WARRANTY REPAIR HISTORY
02/19/2007
DEALER: Legacy Ford Lincoln Mercury
WARRANTY CLAIM NUMBER: 158192 ODOMETER: 072712M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 6C640C CONNECTION A/C DUCT 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6646AH
VERIFIED CONCERN, CHECKED OIL, AIR, FOUND INNERCOOLER HOSE HOT SIDE TORN. CO DE P0401 REPLACED HOT SIDE UPPER INNER COOLER HOSE, CLEARED CODES RETEST OK , ROAD TEST OK
07/26/2006
WARRANTY CLAIM NUMBER: 148297 ODOMETER: 056451M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 6005F 69 FROZEN/SEIZED/BINDING
3C3Z 9E527AE NOZZLE ASY-FUEL INJE 001 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F11
000 6005F12
000 6005F13
000 6005F18
000 6005F20
000 6005F21
000 6005F33
000 9527AR
000 12650D30
000 6005F25
1 VERIFIED CUSTOMER CONCERN RAN ENGINE PERFORMANCE PINTEST 1-33 FOUND NUM BER 5 INJECTOR INTERNALLY DAMAGED AND EGR VALVE STICKING. REPLACED NUMBER 5 INJECTOR AND EGR VALVE,. RETEST OK. TURBO LOCKED UP WHILE DRIVING. CC69
07/26/2006
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6K682BARM TURBO CHG-EXH DRIVE 001 9438A 42 DOES NOT OPERATE PROPERLY
TURBO LOCKED UP. REPLACED TURBO
06/23/2006
WARRANTY CLAIM NUMBER: 146726 ODOMETER: 054378M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9C968AA FUEL PRESSURE REG 001 6005E 42 DOES NOT OPERATE PROPERLY
000 6005E2
000 6005E3
000 6005E4
000 6005E5
000 6005E6
000 6005E7
000 6005E8
000 6005F1X1
000 6005F8
000 6005F22
000 9968B
1 VERIFIED CONCERN. RAN ENGINE. HARD START DIAG. PINTEST 1-8 CODE P2623. RAN ICP & IPR TEST. IPR STICKING. REPLACED IPR AND RETEST OK.
06/13/2006
WARRANTY CLAIM NUMBER: 146162 ODOMETER: 054378M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6K854DA PIPE (TURBO INLET LO 001 6005F 01 BROKEN/CRACKED
3C3Z 6N640AA GASKET TURBO TO MANI 001 6005F1
000 6005F2
000 6005F1X1
000 6005F6
000 6005F8
000 6005F11
000 6005F12
000 6005F13
000 6005F14
000 6005F18
000 6005F20
000 6005F25
000 9438A
000 9438A2
1 VERIFIED CONCERN, RAN ENGINE PERFORMANCE DIAG. PIN TEST 1- WDS CODE P04 01. FOUND EXHAUST LEAKING FROM CRACKED Y PIPE. R AND I TURBO TO REPLACE Y PI PE. RETEST OK CC01.
06/08/2006
WARRANTY CLAIM NUMBER: 145887 ODOMETER: 053890M
LABOR OP
CONDITION CODE
CONDITION DESC
000 06E17B
1 REPROGRAMMED MODULES
06/08/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
1 COMPLETED TEST DRIVE
06/08/2006
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6K682BARM TURBO CHG-EXH DRIVE 001 6005F 69 FROZEN/SEIZED/BINDING
3C3Z 9F838EA SENSR ASY F/I TIMING 001 6005F1
5C3Z 12224A 3 WAY VACUUM CONNECT 001 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F11
000 6005F12
000 6005F13
000 6005F18
000 6005F20
000 14200A
000 9838A
000 9438A
1 VERIFIED CONCERN RAN ENGINE PERFORMENCE PINTEST CODES P0401 P2285 FOUND ICP LEAKING AND TURBO STICKING REPLACED ICP SENS OR AND CONVERTOR AND TURBO RETESTED OK
06/08/2006
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 9F759A WIRE ASY FUEL VAPOR 001 12651D 28 OPEN CIRCUIT
6C3Z 9B249A HEADER-FUEL FILTER 001 12651DX1
000 12651D2
000 9249A
CC28 RAN WDS CODE P2269. PINPOINT TEST TO FUEL MANIFOLD SHORTED REPLACED FUEL MANIFOLD AND HARNESS. RETEST.OK
END OF OASIS REPORT FOR 1FTSW31P53ED62207
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #3 of 3 (permalink) Old 04-12-2007, 11:37 PM Thread Starter
Thanks for the info.
F350MX is offline
