07-8-4 Diesel Engine - Overheating With A Snow Plow Installed On Vehicles Without The - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 0 replies and been viewed 1029 times.
post #1 of 1 (permalink) Old 04-17-2007, 03:57 AM Thread Starter
Squatch's Avatar
Printable View (47 KB)
TSB
07-8-4 DIESEL ENGINE - OVERHEATING WITH A SNOW PLOW INSTALLED ON VEHICLES WITHOUT THE FACTORY INSTALLED SNOW PLOW PACKAGE
Publication Date: April 11, 2007
FORD: 2005-2008 F-Super Duty
This article supersedes TSB 06-24-12 to update the vehicle model years and engines.
ISSUE:
Some 2005-2008 F-Super Duty vehicles with a diesel engine, that are not equipped with the factory snow plow package, may exhibit an engine overheat condition if a snow plow is installed on the vehicle. The condition typically will occur during normal highway driving. This is due to the snow plow blade disrupting airflow to the engine, causing the cooling fan to stop turning or to spin in reverse.
ACTION:
A new clutch fan (only for snow plow applications) may be installed to correct the condition. Cost of the new clutch fan and its installation is the responsibility of the customer. Refer to Workshop Manual Section 303-03 for removal and installation.
PART NUMBER PART NAME
4C3Z-8A616-SA 6.0L Fan Clutch
8C3Z-8A616-A 6.4L Fan Clutch
WARRANTY STATUS:
Information Only - Not Warrantable
Copyright 2007 Ford Motor Company
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
