Oasis Report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by centennial60, this thread has received 1 replies and been viewed 615 times.
post #1 of 2 (permalink) Old 04-20-2007, 11:04 PM Thread Starter
Diesel Enthusiast
centennial60's Avatar
Send a message via Yahoo to centennial60
Oasis Report Please
I have a friend that is looking at buying this truck and would like to know the history on it. If someone could run an Oasis report it would be greatly appreciated. TIA. :Thumbup: :bow: :bow:
Adam
VIN: 1FDAW57P04EB98926
08 F250, CC, SB, FX4, Black, Alpine navi Stock for now
centennial60 is offline
post #2 of 2 (permalink) Old 04-24-2007, 02:33 AM
Squatch's Avatar
OASIS RESULT:
1FDAW57P04EB98926
04/23/2007
21:32:37
FCXWS446
Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-550 CC CHASIS 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
6 SPEED MANUAL AXLE CODE
98 ENGINE CALIBRATION
WARNING MESSAGES
OTHER WTYS MAY APPLY/REACQUIRED VEH WTY EXP 09-25-2006 DISTANCE 29476
ARN MESSAGES
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 06-23-02
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
01/28/2004 BUILD DATE
01/07/2004 SALE MILEAGE
00006
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
01/04/2007
DEALER: Lewis Ford Sales, Inc.
WARRANTY CLAIM NUMBER: 043292 ODOMETER: 053731M
LABOR OP
CONDITION CODE
CONDITION DESC
YC3Z 12B533AA MODULE-GLOW PLUG CTL 001 6051AT 42 DOES NOT OPERATE PROPERLY
3C3Z 9229AA GASKET CARB FUEL INL 006 6051A11
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 002 6051A20
6C3Z 6049C CYLINDER HEAD 002 6051AZN
3C3Z 6A642AA COOLER CRANKCASE OI 001 9438AZW
6C3Z 8A080B COOLANT O/FLO BOTTLE 001 12650D84
6C3Z 9T515A KIT-TUBE TRBCH OIL R 001 6731A
4C3Z 9P456AF COOLER - EGR 001 8575B
4C3Z 8A616AA CLUTCH ASY-FAN A/C 001 8005D
4C3Z 6K682CBRM TURBO CHG-EXH DRIVE 001 MT8000
3C3Z 6C683AA FLTER-ENG OIL 001
F6DZ 8100A CAP ASY RADIATOR 001
3C3Z 9A375AA GSKT F/P DISC HOS RE 001
VC 7B 003
3C3Z 6731AA ELEMENT ASY OIL FILT 001
XO 15W40QSD 015
53731 DIAG AND REPLACED FAILING INJECTORS #5,7 AND FOUND HEAD GASKET LEAKRE MOVED HEADS AND INSPECT FOUND SEVERAL POINTS THAT FAIL FLATNESS TEST REPLA CED BOTH HEADS,OIL COOLER,EGR COOLER AND TURBO TURBINE SHAFT BEARING DRAGIN G,TEST DRIVE AND RETEST FLUSHED COOLING SYSTEM AND CHANGED OIL AND FILTER TSB 06-21-2
01/04/2007
WARRANTY CLAIM NUMBER: 043925 ODOMETER: 053731M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 003 9527AL 42 DOES NOT OPERATE PROPERLY
000 MT6005
REPLACE FAILED INJECTORS. M TIME FOR EXTENSIVE DIAG
11/09/2006
WARRANTY CLAIM NUMBER: 041424 ODOMETER: 050470M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 061906C 42 DOES NOT OPERATE PROPERLY
3C3Z 9P455AB SE E/G/R VLV 001
50470 DIAG AND FOUND EGR STICKING CLEANED AS OUTLINED IN TSB 06-19-6,STILL STICKS REPLACED EGR VALVE AND REPROGAMED FICM AS OUTLINED IN TSB 06- 22-3
09/25/2006
WARRANTY CLAIM NUMBER: 039843 ODOMETER: 048110M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 001 MT9E527 42 DOES NOT OPERATE PROPERLY
VC 7B 002
48110 DIAGNOSE AND FOUND CYLINDER SIX INJECTOR FAILED POWER BALANCE TEST. N O SOUND ON INJECTOR TEST REPLACED #SIX INJECTOR AND RETEST, PASS. RO 38269 REPLACED DIFFERENT INJECTORS #2,4 &8.
09/25/2006
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6079C GASKET SET-VALVE GRI 001 6051AT 42 DOES NOT OPERATE PROPERLY
6051 GASKET CYL HEAD 000
48110 DIAG COOLING SYSTEM PER TSB 06-3-8 AND REPLACED EGR COOLER AND HEAD G ASKETS
08/15/2006
WARRANTY CLAIM NUMBER: 038269 ODOMETER: 045773M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 003 9527AT 42 DOES NOT OPERATE PROPERLY
000 6005F
000 6005F1
000 6005F2
000 6005F13
000 6005F11
000 6005F18
000 6005F20
000 6005F22
000 6005F8
000 6005F12
45773 DIAG AND FOUND INJECTORS #2,4,8 FAILING REPLACED INJECTORS,RETESTED A ND TEST DRIVE RO 36289 REPLACE INJECTORS 1,5&7.
06/22/2006
WARRANTY CLAIM NUMBER: 036289 ODOMETER: 041526M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 003 9527AR 42 DOES NOT OPERATE PROPERLY
6C3Z 9G282AA PMP & FLTR ASY-FUL 001 6005F
6C3Z 9F759A WIRE ASY FUEL VAPOR 001 6005F1
000 6005F2
000 6005F13
000 6005F14
000 6005F18
000 6005F19
000 6005F6
000 6005F8
000 6005F22
000 MT9E527
000 MT9282
41526 SEPERATE PUNCH FOR HYDRAULIC PUMP 745AM TO 817AM. DIAG AND FOUND THAT HAS LOW FUEL PRESURE,AND BAD INJECTORS #1,5,7 REPLACED FUEL PUMP,REPLACED I NJECTORS 1,5,7 TEST DRIVE AND RETEST SPIN CODE 6005F18
04/24/2006
DEALER: Starr Motor Company
WARRANTY CLAIM NUMBER: 023992 ODOMETER: 035496M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 19D850CA SUCTION/DISCHARGE AS 001 19700A14 42 DOES NOT OPERATE PROPERLY
F7AZ 19589DA A/C COMPRESSOR OIL 001 19700A
YN 19 042 19700A3
ROUTINE A/C DIAG FOUND NO REFRIGERANT IN SYS DUE TO A/C LINE FAILURE REPLACE D SUCTION /DISCHARGE MANIFOLDLINE ASSY EVAC & CHARGE SYS RETEST RESOLV
04/24/2006
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AC COOLER - EGR 001 9456A 42 DOES NOT OPERATE PROPERLY
VC 7B 003 8005D
ROUTINE COOLING SYS DIAG PRESSURE TEST SYS FOUND EGR COOLER FAILURE REPLACED EGR COOLER
04/24/2006
LABOR OP
CONDITION CODE
CONDITION DESC
2523942 PNL ASY-FT DR TRIM 000 23943A2 42 DOES NOT OPERATE PROPERLY
000 23943A
RIGHT SIDE WINDOW CHATTERS WHEN GOING UP CLEANED & LUBRICATE WINDOW REGULATO R & WINDOW RUN
END OF OASIS REPORT FOR 1FDAW57P04EB98926
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
