Oasis Report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by coreystroke02, this thread has received 1 replies and been viewed 599 times.
post #1 of 2 (permalink) Old 05-04-2007, 05:29 PM Thread Starter
coreystroke02
coreystroke02's Avatar
Oasis Report Please
My uncle bought this truck a few months back and its been in the shop now 4 different times. Vin # is:1FTWX33P85EA34732 By the way the truck is a 2005 F-350 Ext. Cab
2002 F-250 Crew Cab 4x4, DP-Tuner 60 tow, 80 eco, 120 race, and 140 smoke, Banks wastegate, Banks Transcommand(bypassed), 4" SS exhaust, AFE stage 2 intake, Superlift 6" lift, 37" Nitto Terra Grapplers, 18" Motto wheels, EGT and Boost gauges.
coreystroke02 is offline
post #2 of 2 (permalink) Old 05-05-2007, 02:29 AM
Squatch's Avatar
OASIS RESULT:
1FTWX33P85EA34732
05/04/2007
21:29:21
FCXWS446
Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 S/CAB PICKUP 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
4N ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-17-06
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 06-23-02
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
11/22/2004 BUILD DATE
08/11/2004 SALE MILEAGE
00012
05B32
DE-GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
03/21/2007
DEALER: Dan Wachtel Ford-Linc-Merc Inc
WARRANTY CLAIM NUMBER: 201557 ODOMETER: 046997M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001 061906C 42 DOES NOT OPERATE PROPERLY
46997 PERFORM DIAG FOUND CODE P0404 REPLACE EGR VALUE PER TSB 06-19-06
03/21/2007
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AF COOLER - EGR 001 9456A 42 DOES NOT OPERATE PROPERLY
VC 7B 003
46997 FOUND EX LEAK AT EGR COOLER REPLACE EGR COOLER
02/16/2007
WARRANTY CLAIM NUMBER: 200741 ODOMETER: 046518M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6608B ROTOR & SHAFT-OIL PU 001 6600B 42 DOES NOT OPERATE PROPERLY
3C3Z 6626AA SCREEN OIL PUMP 001 9350B
5C3Z 6710AA GASKET SET-OIL PAN 001 6642A
3C3Z 6A642AA COOLER CRANKCASE OI 001 6600A
3C3Z 9433AA GASKET SET-MANIFOLD 001 6781ALW
3C3Z 6731AA ELEMENT ASY OIL FILT 001
XO 15W405QSD 003
VC 7B 004
46518 VECH CAME IN NO STARTING PERFORM VISUAL INSP HAD GOOD SUPPLY OF FUEL CK BASE OIL PRESSURE NO OIL PRESSURE REMOVE LOW PRESSURE PUMP FOUND DAMAGED PUMP CALL TECH OASIS # 217 350 132 FOR INSPECTION TO LOCATE PART. NO PARTS IN OIL PAN RECALLED TECH # 111 524 974 TECH ADVISED TO REPLACE FRONT C OVER& OIL PUMP ASSY, REPLACE OIL COOLER REINSTALL OIL PAN & FILL
02/16/2007
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 6K682CBRM TURBO CHG-EXH DRIVE 001 9438A 42 DOES NOT OPERATE PROPERLY
5C3Z 6F089BA ACTUATOR ASSY 001 6089A
46518 AFTER STARTING ENGINE FROM LINE A REPAIR HAD TUBRO VGT NOT WORKING RE PLACE TUBRO AFTER TUBROI REPLACEMENT VGT ACCUATOR MAKE SCRE ACH SOUND UNPL UG VGT ACCU. NOISE WENT AWAY REPLACE ACCUATOR
11/24/2006
DEALER: Joe Sartain Ford, Inc.
WARRANTY CLAIM NUMBER: 236418 ODOMETER: 044118M
LABOR OP
CONDITION CODE
CONDITION DESC
9E527 NOZZLE ASY-FUEL INJE 000 062203A 42 DOES NOT OPERATE PROPERLY
PERFORMED DIAG. PERFORMED TSB #06-22-03
END OF OASIS REPORT FOR 1FTWX33P85EA34732
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
