I need a report - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by o37point3, this thread has received 2 replies and been viewed 526 times.
post #1 of 3 (permalink) Old 05-04-2007, 05:36 PM Thread Starter
I need a report
VIN 1ftsw31f83ea77413
2003 7.3 f-350
o37point3 is offline
post #2 of 3 (permalink) Old 05-05-2007, 02:28 AM
Squatch's Avatar
OASIS RESULT:
1FTSW31F83EA77413
05/04/2007
21:28:13
FCXWS447
Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
D1 ENGINE CALIBRATION
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
10/31/2002 BUILD DATE
09/23/2002 SALE MILEAGE
00117
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
10/18/2006
DEALER: Langford Ford, Inc.
WARRANTY CLAIM NUMBER: 120891 ODOMETER: 094699M
LABOR OP
CONDITION CODE
CONDITION DESC
9A543 PUMP ASY-FUEL INJECT 000 040404A D8 FAILED GASKET/SEAL
2C3Z 9G804AB O-RING KIT 001
XO 15W40QSD 002
HIGH PRESSURE OIL PUMP FITTINGS DIAG AND CONFIRMED CUSTOMERS CONCERN,REMO VED AND REPLACED HIGH PRESSURE OIL PUMP O-RINGS.VERIFIED REPAIR AND OPERATIO N ALL PASSED-.
10/18/2006
LABOR OP
CONDITION CODE
CONDITION DESC
XC3Z 9E527AARM NOZZLE ASY-FUEL INJE 001 6005F 42 DOES NOT OPERATE PROPERLY
F81Z 9E527CRM NOZZLE ASY-FUEL INJE 001 6005F1
PM 15 001 6005F1X1
000 6005F2
000 6005F6
000 6005F7
000 6005F8
000 6005F9
000 6005F10
000 6005F14
000 6005F16
000 6005F18
000 6005F19
000 12650D45
000 6051A11
000 9527AL
000 6005F13
#2 AND #8 INJECTORS FAULTY DIAG AND CONFIRMED CUSTOMERS CONCERN,PERFORMED ENGINE COMPRESSIONTEST,REMOVED AND REPLACED #2 AND #8 INJECTORS.. VERIFIED REPAIR AND OPERATION,ROAD TESTED AND PASSED., PERFORM STEPS ONE THROUGH TWEL VE 7.3 PERFORMANCE DIAGNOSIS SHEET, RETRIEVE DTC P0266 P0284, PERFORM PINPOI NT TESTS, ADD FUEL LUBRICITY ADDITIVE, CLEAR CODES, RETEST, COMPRESSION 1-42
04/27/2006
DEALER: Ford Lincoln Mercury of Sebrin
WARRANTY CLAIM NUMBER: 001617 ODOMETER: 078852M
LABOR OP
CONDITION CODE
CONDITION DESC
F7TZ 12K073A TRNSDC ASY-C/SHT PSN 001 6005E2 42 DOES NOT OPERATE PROPERLY
000 6005F
000 6005F1X1
000 6005F10
000 6005F12
000 12650D60
ROAD TEST PERFORM DIESEL DIAG CHECK FUEL AND OIL LEVEL PERFORM SELF TEST ( KOEO PASS KOER PASS CONT P0344) PERFORM INJ TEST TEST ICP AND LOW IDLE STA BILITY PERFORM CYL CONTRIBUTION AND BOOST PRES TESTS PINPOINT TEST REMO VE AND REPLACE CAM SENSOR ROAD TEST AND RETEST (PASS)
END OF OASIS REPORT FOR 1FTSW31F83EA77413
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #3 of 3 (permalink) Old 05-05-2007, 04:03 AM Thread Starter
Thanks a million
