oasis request please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by COTTS4x4, this thread has received 2 replies and been viewed 569 times.
post #1 of 3 (permalink) Old 05-09-2007, 02:04 AM Thread Starter
COTTS4x4's Avatar
my good buddy is looking at an 04 6.0 crew longbox and i would like to get the oasis on it.
1FTNW21P34EA14835
thanks alot
2004 F350 XLT Sport - 6.0 - 12.5" DR Lift
17x14 Weld Sidewinders - 39.5"x16.5" Pitbull Rockers
Custom SCT By Doug At Direct Injection Performance
Farmboy Fabrications Traction Bars & Steering Components
COTTS4x4 is offline
post #2 of 3 (permalink) Old 05-09-2007, 03:12 AM
Squatch's Avatar
OASIS RESULT:
1FTNW21P34EA14835
05/08/2007
22:12:25
FCXWS446
Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
ARN MESSAGES
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 06-23-02
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
11/15/2003 BUILD DATE
07/31/2003 SALE MILEAGE
00020
59B01
ELIGIBLE FOR ONE-TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIONS RECALL 05E15 OR 06E17 FOR DETAILS.
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
11/07/2006
DEALER: Jarrett-Gordon Ford of Winter
WARRANTY CLAIM NUMBER: 099787 ODOMETER: 070412M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9E527AE NOZZLE ASY-FUEL INJE 003 6005F 69 FROZEN/SEIZED/BINDING
3C3Z 9C623AA AIR CLEANER OUTLET T 001 6005F1
3C3Z 6766BA CAP ASY OIL FILLER 001 6005F2
000 6005F6
000 6005F8
000 6005F9
000 6005F11
000 6005F12
000 6005F13
000 6005F14
000 6005F18
000 6005F19
000 6005F20
000 6005F21
000 6005F22
000 6005F23
000 6005F33
000 9527AT
ROAD TESTED VEHICLE VERIFIED CONCERN PERFORMED DEISEL DIAG SHEET FOUND MASS AIR OUT OF SPECS #2,#5,#6 INJECTORS HANGING UP PERFORMED INHANCEN INJECTOR TEST SMOKE TEST INTAKE AND CAC FOUND TURBO INLET BOOT RIPPED R&R R&R ALL INJ ECTORS REASSEMBLED RETESTED VERIFIED REPAIR COMPLETE
11/07/2006
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9F836BA PEDAL & SENSOR ASY 001 9735A 42 DOES NOT OPERATE PROPERLY
VERIFIED CONCERN PERFORMED PIN-POINT TEST FOUND THROTTLE PEDAL OPEN CIRCUIT R&R PEDAL RETESTED RETEST OK AT THIS TIME
07/24/2006
WARRANTY CLAIM NUMBER: 095470 ODOMETER: 069414M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9F838EA SENSR ASY F/I TIMING 001 9838A 42 DOES NOT OPERATE PROPERLY
5C3Z 12224A 3 WAY VACUUM CONNECT 001 6007D
000 MT9F838
VERIFIED OIL DRIPPING JUST RESIDIAL PERFORMED OIL LEAK TEST REPLACE ICP C LEANED UNDERSIDE OF VEH
07/24/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 06E17B
06E17B--0.7 HRS CONTROL MODULES RECALIBRATED RECALL COMPLETE
07/11/2006
WARRANTY CLAIM NUMBER: 094965 ODOMETER: 069107M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6A642AA COOLER CRANKCASE OI 001 6005F 42 DOES NOT OPERATE PROPERLY
3C3Z 9P456AE COOLER - EGR 001 6005F13
W301638 002 6005F2
W301333 002 6005F14
VC 7B 002 6005F20
VC 8 MOTORCRAFT BATTERY 001 6005F11
3C3Z 6766BA CAP ASY OIL FILLER 001 6005F18
3C3Z 6C683AA FLTER-ENG OIL 001 6005F19
3C3Z 8255AA GASKET WATER OUTLET 002 6005F21
000 6005F8
000 6005F22
000 6005F12
000 6005F9
000 6005F23
VERIFIED CONCERN FOR OIL IN COOLANT AND LOW POWER PERFORMED DIESEL DIAG SHEE T EGR TEST VGT TEST FOUND OIL COOLER LEAKING AND EGR COOLER LEAKING AS WELL PERFORMED R&R DRILLED AND TAPPED 2 TURBO BOLTS AND FLUSHED SYSTEM SEVERAL T IMES RETEST VEHICLE MUST RETURN TO BE FLUSHED MORE IN FEW DAYS
06/06/2006
WARRANTY CLAIM NUMBER: 093526 ODOMETER: 067369M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9P458AA KIT - VLV EGR 001 9456A 42 DOES NOT OPERATE PROPERLY
4C3Z 1K106AA SNP RNG/SCRW-WARN HU 002 8005D
3C3Z 6K854DA PIPE (TURBO INLET LO 001 6005F
000 6005F1
000 6005F2
000 6005F8
000 6005F20
000 6005F22
000 6005F25
000 9438A2
000 6005F12
000 6005F18
VERIFIED ALL 3 CONCERNS-DIAG SHEET FOR NO POWER-REPLACED VGT O-RING-EXHAUST SMELL REPLACED LEAKING Y PIPE AND PRESS TEST COOLANT SYSTEM-FOUND EGR COOL ER LEAKING-REPL O-RINGS AND COVER AND HOSE-RECHECK ALL 3 CONCERNS-ALL CORREC TED
END OF OASIS REPORT FOR 1FTNW21P34EA14835
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #3 of 3 (permalink) Old 05-09-2007, 04:56 AM Thread Starter
COTTS4x4's Avatar
Thanks Squatch -
How does that report look to you? Any red flags that you see or anything that he should worry about?
Thanks.
COTTS4x4 is offline
