Oasis Report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by maxxis_mudder, this thread has received 1 replies and been viewed 521 times.
post #1 of 2 (permalink) Old 05-09-2007, 09:29 PM Thread Starter
Oasis Report Please
2004 F250 6.0L
VIN# 1FTNW21P74ED87120
Thanks.
maxxis_mudder is offline
post #2 of 2 (permalink) Old 05-16-2007, 01:47 AM
Squatch's Avatar
OASIS RESULT:
1FTNW21P74ED87120
05/15/2007
20:46:56
FCXWS447
Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
CUDL - THIS VEHICLE HAS AN OPEN CUDL CONTACT
ARN MESSAGES
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 06-23-02
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/07/2004 BUILD DATE
06/25/2004 SALE MILEAGE
00025
59B01
ELIGIBLE FOR ONE-TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIONS RECALL 05E15 OR 06E17 FOR DETAILS.
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
02/07/2007
DEALER: Maibach Ford, Inc.
WARRANTY CLAIM NUMBER: 083763 ODOMETER: 069817M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 6051AT 02 BENT/BUCKLED/KINKED
4C3Z 9P456AF COOLER - EGR 001 6051A11
3C3Z 6731AA ELEMENT ASY OIL FILT 001 6051A20
3C3Z 6691AA GSKT-OIL FLTR RTN PI 001 6731A
3C3Z 6A831AA GSKT-OIL FLTR ELEM S 001 MT9E527
W302725 001
VC 7B 002
3C3Z 9N184CA WATER-FUEL SEP ELEM 001
W300965 008
3C3Z 6754BA TUBE OIL LEVEL INDIC 001
6C3Z 6049C CYLINDER HEAD 002
3C3Z 6753AA GASKET OIL LEVEL IND 001
3C3Z 9229AA GASKET CARB FUEL INL 008
OSP 001
ZC 30 001
ZC 31 MOTORCRAFT BATTERY 001
XO 15W405QSD 003
VC 7B 002
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 003
4C3Z 9T287AA KIT-MANF FU/ING FUL 001
REPLACED EBP & REPROGRAMED FICM, TCM, PCM-COOLANT ODOR STILL PRESENT-DID TSB 06-21-02 & SET COOLANT LEVEL-INSTALLED GAUGES ON COOLANT TANK & DROVE-PRESSU RE JUMPED TO 18 PSI ON HARD ACCL.-DID EGR COOLER TEST & FOUND LEAK IN COOLER -REPLACED EGR COOLER & VALVE-RETESTED ON ROAD. PRESSURE GAUGE STILL SHOWS CO OLANT LEAK COMPRESSION INTO COOLANT SYSTEM-R&R HEADS & CLEANED & FOUND HEADS
02/07/2007
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15F
REPLACED EBP SENSOR REPROGRAMMED PCM FICM TCM PER RECALL
END OF OASIS REPORT FOR 1FTNW21P74ED87120
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
