07-9-1 2008 F-super Duty- Lighting On Snow Plow Equipped Vehicles - Built Before 04/1 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 0 replies and been viewed 1484 times.
post #1 of 1 (permalink) Old 05-16-2007, 02:11 AM Thread Starter
Squatch's Avatar
Printable View (47 KB)
TSB
07-9-1 2008 F-SUPER DUTY- LIGHTING ON SNOW PLOW EQUIPPED VEHICLES - BUILT BEFORE 04/18/2007
Publication Date: April 19, 2007
FORD: 2008 F-Super Duty
ISSUE:
2008 F-Super Duty vehicles are equipped with a smart junction box (SJB) and it's function is to provide protection against excessive current loads, typical of a short circuit, by shutting down circuit operation. The SJB strategy may interpret the switching between Ford headlamps and aftermarket snowplow headlamps, and vice-versa, as a short-to-ground, causing the power feeding a headlamp circuit through the SJB to be turned off.
ACTION:
Reprogram the SJB to the latest calibration using IDS release 48.9 patch 9 and higher or 49.1 patch 1 and higher. This new calibration is not included in the VCM 2007.5 DVD. Calibration files may also be obtained at www.motorcraft.com.
WARRANTY STATUS:
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
070901A 2008 Super Duty: Reprogram The SJB (Do Not Use With 12650D, 12651D, 12651D4) 0.3 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
15604 04
Copyright 2007 Ford Motor Company
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
