Oasis request please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Mustang50, this thread has received 2 replies and been viewed 470 times.
post #1 of 3 (permalink) Old 06-07-2007, 02:56 PM Thread Starter
I'm buying this truck tomorrow, could you please run a report on it?
1FTSX31F03EA07756
Thank You.
Mustang50 is offline
post #2 of 3 (permalink) Old 06-07-2007, 03:23 PM Thread Starter
Sorry, I just realized I put this in the wrong area.
post #3 of 3 (permalink) Old 06-15-2007, 03:25 AM
Squatch's Avatar
Standard Claims List For Model Year 2003
1FTSX31F03EA07756 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 19-JUL-2002 26-JUL-2003 158015 USA 0 7S22 1801XX * 14526 * P82 33 39
AWS Claim Key: 79651 Trx Code: S07 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 08677 - * Name: WOLF MOTOR CO., INC. Ph: *-* St:MN Ctry Cd: USA Reg Cd: NA Repr Date:30-AUG-2002 Doc #:01671302
Cust Comments: CK.4X4 IN OP
Tech Comments: LOOSE FUSE REINSTALL FUSE ROAD TEST OK.
1FTSX31F03EA07756 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 19-JUL-2002 26-JUL-2003 158015 USA 8 2E06 030008 F6TZ 9F838 A E29 42 24744
AWS Claim Key: 5140159 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 09491 - * Name: SWANT GRABER FORD Ph: 715-5379500 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:10-MAR-2004 Doc #:05936501
Cust Comments: CHECK ENGINE LIGHT COMES ON
Tech Comments: VERIFY CONCERN SELF TEST PINPOINT TEST ICP SENSOR BAD SHOWED HIGHER PR
1FTSX31F03EA07756 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 19-JUL-2002 26-JUL-2003 158015 USA 8 1A88 000615 * NPF * L65 82 24744
AWS Claim Key: 5140160 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 09491 - * Name: SWANT GRABER FORD Ph: 715-5379500 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:10-MAR-2004 Doc #:05936502
Cust Comments: OIL LEAK ON ENGINE
Tech Comments: OIL LEAK COMING OUT OF VALLEY CHECK O RING CHECK HIGH PRESSURE OIL PUM
1FTSX31F03EA07756 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 19-JUL-2002 26-JUL-2003 158015 USA 9 7S02 180102 * 14401 * E29 30 26728
AWS Claim Key: 5429071 Trx Code: E83 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 09441 - * Name: BOYER FORD TRUCKS, INC. Ph: 612-3786000 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:02-APR-2004 Doc #:260243A
Cust Comments: INTERMITTENT YELLOW ENGINE WARNING LIGHT COMES ON, ENGINE WILL RUN ROUGH, MISS BUCK JERK, STALL, ALL INTERMITTENT
Tech Comments: TEST DROVE TRUCK FOR SEVERAL MILES AND VARIFIED CONCERN. KOEO SYS PASS. PULLED CODES 1209, 1882 , 1211, ALL ICP CODES. INSPECTED IPR WIRING AND FOUND WIRE RUBBED THROUGH ON IPR NUT. CUT WIRE , SAULDERED AND HEAT SHRANK. INSTALLED PLASTIC CONDUIT AND WRAPPED WITH ELEC TAPE. CLEARED COD ES AND TEST DROVE, OK. KOEO AND KOER SYS PASS. NO CODES PRESANT AT THIS TIME. TRUCK NOW OK.
1FTSX31F03EA07756 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 19-JUL-2002 26-JUL-2003 158015 USA 9 6L88 000615 * NPF * N33 82 26728
AWS Claim Key: 5546525 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 09441 - * Name: BOYER FORD TRUCKS, INC. Ph: 612-3786000 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:02-APR-2004 Doc #:260243B
Cust Comments: WHINE NOISE FROM UNDER DASH AREA, INTERMITTENT. ELECTRICAL TYPE WHINE BUZZ
Tech Comments: DROVE TRUCK LISTENING FOR NOISE AND COULD NOT HEAR IT. RAN BLOWER MOTOR IN ALL SPEEDS AND TRY ED IN ALL BLOWING POSITIONS. BUMPED DASH WITH MY PALM REPEATEDLY AND BOULD STILL HEAR NO NOI SE. RAN TRUCK DOWN VERY BUMPY ROAD AND STILL NOTHING. CUST COULD POSABLY BE HEARING TURN SIG AND FLASHER RELAY THAT MIGHT CLICK OR BUZZ. NEED MORE INFO. NO PRBLEM FOUBND AT THIS TIME
1FTSX31F03EA07756 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 19-JUL-2002 26-JUL-2003 158015 USA 10 6Q05 011901 * 17757 * F41 P3 30752
AWS Claim Key: 6155006 Trx Code: E84 Labor Hrs: 4.3
Dlr Cd-Sub Cd: 09372 - * Name: TOUSLEY FORD, INC. Ph: 651-4847231 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:13-MAY-2004 Doc #:534197A
Cust Comments: PEELING PAINT FRONT BUMPER
Tech Comments: REMOVED LIC PLATE AND BRACKET AND VALANCE REFINISHED BUMPER REINSTALLED PARTS
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
