OASIS Request please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by prosat, this thread has received 1 replies and been viewed 506 times.
post #1 of 2 (permalink) Old 06-10-2007, 10:28 PM Thread Starter
could i get a report on this one 1FTWX33P64ED86755
prosat is offline
post #2 of 2 (permalink) Old 06-15-2007, 03:31 AM
Squatch's Avatar
Standard Claims List For Model Year 2004
1FTWX33P64ED86755 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 17-JUN-2004 24-AUG-2004 174542 USA 7 6Q06 011902 F81Z 17B807 AB B07 02 2413
AWS Claim Key: 4324872 Trx Code: 1 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08621 - * Name: SEEKINS FORD/LINCOLN-MERCURY, INC. Ph: 907-4594000 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:16-MAR-2005 Doc #:25098101
Cust Comments: BUMPER APPEARS TO BE HIGHER ON PASSENGER SIDE T90
Tech Comments: INSPECT FRT BUMPER, OK. INSPECT REAR BUMPER, FOUND MOULDING BENT. REPL BUMPER TRIM MOULDING
1FTWX33P64ED86755 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 17-JUN-2004 24-AUG-2004 174542 USA 7 7D08 170101 2C3Z 13008 AB L22 42 2413
AWS Claim Key: 4324871 Trx Code: 1 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 08621 - * Name: SEEKINS FORD/LINCOLN-MERCURY, INC. Ph: 907-4594000 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:16-MAR-2005 Doc #:25098102
Cust Comments: DRIVERS HEADLIGHT LOOSE T90
Tech Comments: INSPECTED AND REPALCED DRIVERS HEADLIGHT.
1FTWX33P64ED86755 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 17-JUN-2004 24-AUG-2004 174542 USA 8 6F18 010702 3C3Z 2820708 AB R22 07 2503
AWS Claim Key: 4687322 Trx Code: 1 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 08621 - * Name: SEEKINS FORD/LINCOLN-MERCURY, INC. Ph: 907-4594000 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:07-APR-2005 Doc #:25244001
Cust Comments: AIR LEAK AT PASSENGER DOOR, AT ONE POINT HAD AIR AND SNOW COME THROUGH
Tech Comments: INSTALLED SOP PASS DOOR WEATHER STRIPPING OK NOW.
1FTWX33P64ED86755 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 17-JUN-2004 24-AUG-2004 174542 USA 8 7D08 170101 * 13007 * L22 07 2503
AWS Claim Key: 4687321 Trx Code: 1 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 08621 - * Name: SEEKINS FORD/LINCOLN-MERCURY, INC. Ph: 907-4594000 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:07-APR-2005 Doc #:25244003
Cust Comments: DRIVERS SIDE HEADLIGHT MOUNT APPEARS TO BE LOOSE, REVIEW HISTORY.
Tech Comments: ADJUSTED HEADLIGHT LOCK TABS, TESTED OK NOW.
1FTWX33P64ED86755 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 17-JUN-2004 24-AUG-2004 174542 USA 10 6O05 010203 * 16005 * B02 07 2745
AWS Claim Key: 5459012 Trx Code: 1 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 08621 - * Name: SEEKINS FORD/LINCOLN-MERCURY, INC. Ph: 907-4594000 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:23-MAY-2005 Doc #:25559301
Cust Comments: RT FT DOOR MIS ALIGNED
Tech Comments: FRONT BODY SHEET METAL OUT OF ALIGNMENT R&I COWL VENT GRILLES, UPPER RADIATOR AIR DEFLECTOR, GRILLE, PARK LAMPS. LOOSEN HEADLAMP MOUNTING PANEL. ALIGN RT< FENDERS, HOOD, CORE SUPPORT.
1FTWX33P64ED86755 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 17-JUN-2004 24-AUG-2004 174542 USA 13 6Y05 000001 * MAINT * A96 82 7349
AWS Claim Key: 6767843 Trx Code: 0784S Labor Hrs: 1.5
Dlr Cd-Sub Cd: 08621 - * Name: SEEKINS FORD/LINCOLN-MERCURY, INC. Ph: 907-4594000 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:30-AUG-2005 Doc #:26201401
Cust Comments: LOF,12 POINT CHECK 5000 MILE SERVICE
Tech Comments: COMPLETED ABOVE WORK
1FTWX33P64ED86755 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 17-JUN-2004 24-AUG-2004 174542 USA 14 6Y05 000001 * MAINT * A96 82 8496
AWS Claim Key: 7267908 Trx Code: 0784S Labor Hrs: 1.5
Dlr Cd-Sub Cd: 08621 - * Name: SEEKINS FORD/LINCOLN-MERCURY, INC. Ph: 907-4594000 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:11-OCT-2005 Doc #:26459102
Cust Comments: LOF,12 POINT CHECK 10,000 MILE SERVICE
1FTWX33P64ED86755 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 17-JUN-2004 24-AUG-2004 174542 USA 20 * * * * * * * 9392
AWS Claim Key: 9023597 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 08621 - * Name: SEEKINS FORD/LINCOLN-MERCURY, INC. Ph: 907-4594000 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:04-APR-2006 Doc #:27590401
Cust Comments: RECALL 05E15
Tech Comments: REPLACED EBP SENSOR & REFLASHED PCM ,FICM & TCM W 4U7A.EGG CALIB PER 05E15.
AWS Claim Key: 9023596 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08621 - * Name: SEEKINS FORD/LINCOLN-MERCURY, INC. Ph: 907-4594000 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:04-APR-2006 Doc #:27590402
Cust Comments: 59B01 RECALL
Tech Comments: PERFORM QUALITY ASSURANCE ROAD TEST PER 59B01.
1FTWX33P64ED86755 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 17-JUN-2004 24-AUG-2004 174542 USA 33 6Y05 000001 * MAINT * A96 82 13100
AWS Claim Key: 11609738 Trx Code: 0784S Labor Hrs: 1.8
Dlr Cd-Sub Cd: 08621 - * Name: SEEKINS FORD/LINCOLN-MERCURY, INC. Ph: 907-4594000 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:18-APR-2007 Doc #:29910201
Cust Comments: PERFORM LOF QCM INSPECTION
Tech Comments: PERFORM 15000 MILE SERVICE
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
