OASIS request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Hunting Labs, this thread has received 1 replies and been viewed 418 times.
post #1 of 2 (permalink) Old 06-11-2007, 02:57 AM Thread Starter
OASIS request
Could someone please run an OASIS report on this 2004 F150 VIN: 1FTPX14594NC20624 I know it is not a diesel, but I would really appreciate it. Thanks in advance.
Hunting Labs is offline
post #2 of 2 (permalink) Old 06-15-2007, 03:19 AM
Squatch's Avatar
Standard Claims List For Model Year 2004
1FTPX14594NC20624 T/F6 F T/BD T/AM T/E AR T/FV T/WX 17-MAY-2004 16-JUL-2004 148544 USA 7 7W15 011902 3F2Z 15K859 BA A85 42 16477
AWS Claim Key: 3608424 Trx Code: E83 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 02672 - * Name: IMLAY CITY FORD LINCOLN MERCURY Ph: 810-7245900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:25-JAN-2005 Doc #:12274401
Cust Comments: CUSTOMER STATES REV SENSOR INOP, WHEN GOING IN REV ALARM GOING OFF, SOMETHING HANGING IN THE REAR, CK AND ADVISE.
Tech Comments: 15K867 42 RENTAL CONTRACT NO. 6411 VERIFIED CONCERN, TEST PARK AID MODULE, C 1701, PERFORM PINPOINT TEST C1 C5, PID VALUE 30, REMOVE REAR BUMPER
1FTPX14594NC20624 T/F6 F T/BD T/AM T/E AR T/FV T/WX 17-MAY-2004 16-JUL-2004 148544 USA 7 5B04 050306 2L1Z 3C247 AA N50 41 16477
AWS Claim Key: 3608423 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 02672 - * Name: IMLAY CITY FORD LINCOLN MERCURY Ph: 810-7245900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:25-JAN-2005 Doc #:12274403
Cust Comments: CUSTOMER STATES HAVING A FRONT END GRIND, SEEMS LIKE AXLE ENGAGES WHEN STOPPING, CLUNKS, WHEN YOU MANUAL SHIFT INOT
Tech Comments: 3N247 41 ROAD TEST SEVERAL TIMES, SYMPTOM INTERMITTANT, DIAG ELECTRONIC SHIFT, NO CODES, MONITOR PID DATA, SYSTEM
1FTPX14594NC20624 T/F6 F T/BD T/AM T/E AR T/FV T/WX 17-MAY-2004 16-JUL-2004 148544 USA 31 5N01 110201 4L3Z 3A130 CA C50 42 58557
AWS Claim Key: 11050482 Trx Code: 0736D Labor Hrs: 1.8
Dlr Cd-Sub Cd: 04634 - * Name: MIKE RAISOR FORD Ph: 765-4479444 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:17-JAN-2007 Doc #:07062304
Cust Comments: OUTER TIE ROD ENDS COVERED BY WARR
Tech Comments: THE OUTER TIE ROD ENDS WERE LOOSE REPLACED OUTER TIE ROD ENDS AND CHECKED AND RESET TOE BY DAN HANTHORNE
1FTPX14594NC20624 T/F6 F T/BD T/AM T/E AR T/FV T/WX 17-MAY-2004 16-JUL-2004 148544 USA 31 5B03 050300 2L1Z 3N134 AA L88 42 58557
AWS Claim Key: 11050483 Trx Code: 0736D Labor Hrs: 1.4
Dlr Cd-Sub Cd: 04634 - * Name: MIKE RAISOR FORD Ph: 765-4479444 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:17-JAN-2007 Doc #:07062305
Cust Comments: FRONT PINION SEAL COVERED BY WARR
Tech Comments: THE FRONT PINION SEAL IS LEAKING REPLACED THE FRONT PINION SEAL
1FTPX14594NC20624 T/F6 F T/BD T/AM T/E AR T/FV T/WX 17-MAY-2004 16-JUL-2004 148544 USA 31 1G04 03XXXX 1L2Z 6C348 AA N12 42 58557
AWS Claim Key: 11050484 Trx Code: P05 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 04634 - * Name: MIKE RAISOR FORD Ph: 765-4479444 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:17-JAN-2007 Doc #:07062352
Cust Comments: CUSTOMER STATES THERE IS A BEARING TYPE GROWL NIOSE FROM THE ENGINE AREA; CAN HEAR INSIDE CAB.
Tech Comments: CONFIRMED PROBLEM FOUND IDLER PULLEY,BELT TENSIONER , AND A C COMPRESSOR PULLEY NOISEY REPLACED ALL THREE NOISE IS GONE
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
