Request Oasis Report - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jimcobra, this thread has received 3 replies and been viewed 739 times.
post #1 of 4 (permalink) Old 07-13-2007, 03:46 PM Thread Starter
1ftnx21p14ec38439 Oasis Report
jimcobra is offline
post #2 of 4 (permalink) Old 07-19-2007, 03:43 AM
Squatch's Avatar
Standard Claims List For Model Year 2004
1FTNX21P14EC38439 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 03-FEB-2004 06-MAY-2004 172919 USA 15 * * * * * * * 28330
AWS Claim Key: 5926971 Trx Code: 05S34 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 07780 - * Name: COUNTRY FORD TRUCKS Ph: 209-5753673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-JUN-2005 Doc #:117451A
Cust Comments: PERFORM 05S34 RECALL
Tech Comments: PERFORMED RECAL 05S34
1FTNX21P14EC38439 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 03-FEB-2004 06-MAY-2004 172919 USA 15 2H01 * * * * * * 28330
AWS Claim Key: 5926972 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 07780 - * Name: COUNTRY FORD TRUCKS Ph: 209-5753673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-JUN-2005 Doc #:117451B
Cust Comments: PERFORM 05B29 RECALL
Tech Comments: RECALL 05B29
1FTNX21P14EC38439 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 03-FEB-2004 06-MAY-2004 172919 USA 15 1H03 030008 4C3Z 9J460 A E29 01 28330
AWS Claim Key: 5926973 Trx Code: S07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 07780 - * Name: COUNTRY FORD TRUCKS Ph: 209-5753673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-JUN-2005 Doc #:117451C
Cust Comments: CHECK ENGINE LIGHT ON, INT. RUNS ROUGH AND SMOKES
Tech Comments: CK AND ORDERED THROTTLE PLATE, TO RESCHEDULE FO R ANOTHER DATE
1FTNX21P14EC38439 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 03-FEB-2004 06-MAY-2004 172919 USA 22 2G04 000615 * DIAG * E29 42 35239
AWS Claim Key: 8896310 Trx Code: S07 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 07780 - * Name: COUNTRY FORD TRUCKS Ph: 209-5753673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-FEB-2006 Doc #:122659A
Cust Comments: CUSTOMER STATES THAT THE CHECK ENGINE LIGHT IS ON AND VEHICLE RUNNING ROUGH, SPITS AND SPUTTERS
Tech Comments: CHECKED FOR CODES, HAS PO488 & P1334, PIN POINT TEST AX16, FOUND EGR T P SHORTED, ORDERED PART , CUSTOMER DID NOT RETURN
1FTNX21P14EC38439 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 03-FEB-2004 06-MAY-2004 172919 USA 22 * * * * * * * 35239
AWS Claim Key: 8896311 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07780 - * Name: COUNTRY FORD TRUCKS Ph: 209-5753673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-FEB-2006 Doc #:122659C
Cust Comments: RECALL 05E15
Tech Comments: PERFORMED 05E15 RECALL
AWS Claim Key: 8882656 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07780 - * Name: COUNTRY FORD TRUCKS Ph: 209-5753673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-FEB-2006 Doc #:122659D
Cust Comments: RECALL 59B01
Tech Comments: PERFORMED 59B01 RECALL, TEST DRIVE
1FTNX21P14EC38439 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 03-FEB-2004 06-MAY-2004 172919 USA 34 1A02 030102 * 6051 * D50 42 75283
AWS Claim Key: 11073160 Trx Code: E72 Labor Hrs: 7.7
Dlr Cd-Sub Cd: 07814 - * Name: LITHIA FORD LINCOLN MERCURY OF ROSEBURG Ph: 541-6734485 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:23-JAN-2007 Doc #:183915A
Cust Comments: CUST STATES THAT WHILE DRIVING THE VEHICLE STARTED BLOWING WHITE SMOKE
Tech Comments: 75283 VERFIY CONCERN.FOLLOW TSB 06 21 2,FOUND EGR COOLER LEAKING COOLANT.REMOVED EGR VALVE TO DIAG,FOUND VALVE & INTAKE ALL COVERED WITH BLACK GUE.REMOVED INTAKE AND REPLACED EGR COOLER AFTER CLEANING INTAKE,EGR VALVE,EGR TUBE & TURBO.REASSEMBLED AND RETESTED.OK AFTER REPAIR.
1FTNX21P14EC38439 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 03-FEB-2004 06-MAY-2004 172919 USA 34 2E03 030008 3C3Z 9E527 AE D42 42 75325
AWS Claim Key: 11080911 Trx Code: E72 Labor Hrs: 7.2
Dlr Cd-Sub Cd: 07814 - * Name: LITHIA FORD LINCOLN MERCURY OF ROSEBURG Ph: 541-6734485 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:25-JAN-2007 Doc #:184012A
Cust Comments: CUST STATES THAT THE VEHICLE RUNS ROUGH COLD,NO POWER
Tech Comments: 75325 VERFIY CONCERN,FOLLOW TSB 06 22 3.DID NOT FIX.FOLLOWED 6.0L DIAG SHEET. FOUND FUEL PUMP PRESSURE BELOW SPECS.R&R FUEL PUMP AND RETESTED.F OUND #2,#4 & #7 INJECTORS STILL NOT FIRING CORRECTLY.R&R INJECTORS AND RETEST. FOUND CAC TUBEBOOT AT TURBO RIPPED WHEN R&R INJECTORS. REPLACED BOOT. RETESTED. RUNS GOOD. NO CODES FOUND. VEHICLEOPERATING CORRECTLY AT THIS TIME.
1FTNX21P14EC38439 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 03-FEB-2004 06-MAY-2004 172919 USA 35 2H01 031202 6C3Z 6C640 C L65 42 79199
AWS Claim Key: 11286568 Trx Code: E72 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 07780 - * Name: COUNTRY FORD TRUCKS Ph: 209-5753673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:08-MAR-2007 Doc #:131280C
Cust Comments: OIL LEAK FROM ENGINE DURRING INSPECTION
Tech Comments: CK AND FOUND BLUE ELBOW HOSE LEAKING OIL, REMOV ED AND REPLACED AND RECHECKED OPERATION OK
1FTNX21P14EC38439 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 03-FEB-2004 06-MAY-2004 172919 USA 37 1H03 030008 * 9F452 * D42 55 82036
AWS Claim Key: 11555308 Trx Code: E72 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 07780 - * Name: COUNTRY FORD TRUCKS Ph: 209-5753673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:26-APR-2007 Doc #:132299A
Cust Comments: CUSTOMER STATES THAT THE VEHICLE RUNS ROUGH AT TIMES, CK AND ADVISE
Tech Comments: TESTED SYSTEM AS PER TSB 06 19 06. CODES P0404. TRIED TO CLEAN VALVE. STILL FAILED TEST . REPLACED AND RECHECKED, ALL OK.
1FTNX21P14EC38439 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 03-FEB-2004 06-MAY-2004 172919 USA 37 1B03 030204 3C3Z 6A642 AA L65 42 85124
AWS Claim Key: 11607340 Trx Code: E72 Labor Hrs: 11.5
Dlr Cd-Sub Cd: 03381 - * Name: MARYSVILLE FORD Ph: 360-6594000 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:11-MAY-2007 Doc #:04490401
Cust Comments: CUST STATES OIL COOLANT COMING FROM COLLANT RESERVIOR
Tech Comments: VERIFIED, RAN PINPOINT TESTING, FOUND OIL COOLER FAILED. REPLACED OIL COOLER, FOUND EGR COOLER CLOGGED WITH GOO, ATTEMPTED TO FLUSH OUT, BUT COULD GET NO FLOW, ALSO NOTED FILTER SCREEN TO HIG 1
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #3 of 4 (permalink) Old 01-18-2012, 09:26 PM
Oasis Report Please 2006 F250 1FTSW21P66EB65206
Thanks
fac2400 is offline
post #4 of 4 (permalink) Old 01-20-2012, 01:44 AM
Attached.
Stuntman8895 is offline
