Oasis Report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by imca35, this thread has received 1 replies and been viewed 642 times.
post #1 of 2 (permalink) Old 08-06-2007, 02:59 PM Thread Starter
Oasis Report Please
2004 F350 VIN 1FTSW31P94EB96808
I've had the truck 3 months and just blew my 2nd egr valve...
Thank You for all your help!
imca35 is offline
post #2 of 2 (permalink) Old 08-16-2007, 05:44 AM
Squatch's Avatar
Standard Claims List For Model Year 2004
1FTSW31P94EB96808 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2003 27-JAN-2004 152058 USA 1 7S02 180102 * 14401 * A85 46 68
AWS Claim Key: 363798 Trx Code: 2 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:29-JAN-2004 Doc #:07538051
Cust Comments: CUSTOMER STATES TURN SIGNALS AND HAZARD FLASHERS KEEP BLOWING FUSES
Tech Comments: RUN PIN POINT TEST TRACED PROBLEM TO HARNESS SHORTED AT REAR BUMPER ASSY, REMOVE BRACKET TO BUMPER, LFT REAR, TO ACCESS HARNESS & REPAIR WIRE
1FTSW31P94EB96808 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2003 27-JAN-2004 152058 USA 4 2G05 031405 * RECAL * D50 42 14487
AWS Claim Key: 956501 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:18-MAY-2004 Doc #:08817551
Cust Comments: ENG RUNNING ROUGH AT IDLE
Tech Comments: NOT OPERATING PROPERLY PCM REPROGRAMMING TEST
1FTSW31P94EB96808 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2003 27-JAN-2004 152058 USA 6 2G02 030008 4C2Z 12A690 AB D50 D1 19120
AWS Claim Key: 1277729 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:28-JUN-2004 Doc #:09328751
Cust Comments: OIL LEAK AT LEFT REAR OF ENG
Tech Comments: POROSITY ENGINE OIL LEAKS DIAGNOSIS REPLACED GLOW PLUG HARNESS
1FTSW31P94EB96808 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2003 27-JAN-2004 152058 USA 6 2G05 031405 * RECAL * D13 42 19120
AWS Claim Key: 1287914 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:28-JUN-2004 Doc #:09328752
Cust Comments: HAS A ROUGH IDLE STILL
1FTSW31P94EB96808 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2003 27-JAN-2004 152058 USA 7 2B01 0300XX * 12K073 * D21 46 22795
AWS Claim Key: 1515185 Trx Code: S07 Labor Hrs: 3.8
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:31-JUL-2004 Doc #:09748951
Cust Comments: TRUCK DIES WHILE DRIVING DIFFERANT SPEEDS
Tech Comments: WDS HOOKUP CODES P2614, P2617, REMOVE AIR FILTER & COOLANT RESERVOIRTO ACCESS, REMOVE PLASTIC CONDUIT FROM ENGINE WIRE HARNESS & INSPECT ELECTRICAL WIRES TO CAM SENSOR & CRANK SHAFT SENSOR, BARE WIRE SHORT ING OUT CAUSING STALL CONDITION, REINSULATE WIRES AND WRAP IN PLASTIC CONDIOT, CLEAR CODES & ROAD TEST SHORTED WIRES
1FTSW31P94EB96808 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2003 27-JAN-2004 152058 USA 9 2H02 030008 3C3Z 6F089 AA D21 42 32000
AWS Claim Key: 2333582 Trx Code: S07 Labor Hrs: 5.5
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-OCT-2004 Doc #:01689351
Cust Comments: VEH DIEING OUT AT STOPS, WHILE MAKING TURNS, WHEN SLOWING DOWN
Tech Comments: WDS DIESEL DIAG, RETRIEVE CODE P0299, REPLACE VGT, EBP AND EGR VALVE, REPLACE WIRE HARNESS CONNECTORS FOR EBP AND ICP SENSORS, CLEAR CODES AND ROAD TEST
1FTSW31P94EB96808 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2003 27-JAN-2004 152058 USA 19 2H01 * * * * * * 51270
AWS Claim Key: 6375121 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:09-AUG-2005 Doc #:05200851
Cust Comments: RECALL 05B29:CHARGE AIR COOLER DUCT REPLACEMENT
Tech Comments: RECALL 05B29 CHARGE AIR COOLER DUCT REPLACE
1FTSW31P94EB96808 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2003 27-JAN-2004 152058 USA 19 * * * * * * * 51270
AWS Claim Key: 6375122 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:09-AUG-2005 Doc #:05200852
Cust Comments: RECALL 05S34:FUEL INJECTOR CONTROL MODULE WIREING HARNESS REPAIR
Tech Comments: RECALL 05S34 RECALL 05S34
1FTSW31P94EB96808 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2003 27-JAN-2004 152058 USA 19 2G05 031405 * RECAL * D50 42 51270
AWS Claim Key: 6375123 Trx Code: E72 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:09-AUG-2005 Doc #:05200853
Cust Comments: IDLE GOES UP AND DOWN AT A STOP
Tech Comments: INOP HARD START NO START DIAGNOSTICS DIESEL ENGINE DIAGNOSI
AWS Claim Key: 6375124 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:09-AUG-2005 Doc #:05200855
Cust Comments: RECALL 59B01
Tech Comments: RECALL 59B01 RECALL 59B01
1FTSW31P94EB96808 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2003 27-JAN-2004 152058 USA 29 1H03 030008 4C3Z 9F452 A D50 42 66675
AWS Claim Key: 9513442 Trx Code: E72 Labor Hrs: 5.1
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:01-JUN-2006 Doc #:08670351
Cust Comments: 6.0L DIESEL CHECK VEHICLE SEEMS TO MISFIRE WHEN DRIVING OCCURS MORE 70 80 MPH BEFORE DOWN SHIFT OCCURS UNDER LOAD THROTTLE APPLICATION REPORT
Tech Comments: INOP ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
1FTSW31P94EB96808 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2003 27-JAN-2004 152058 USA 29 * * * * * * * 66675
AWS Claim Key: 9513443 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:01-JUN-2006 Doc #:08670352
Cust Comments: RECALL 05E15 EXHAUST PRESSURE SENSOR
Tech Comments: RECALL 05E15 EP SENSOR, CONNECTOR, AND RECALIBRATION
AWS Claim Key: 9513444 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:01-JUN-2006 Doc #:08670353
Cust Comments: RECALL 59B01 ONE TIME TEST DRIVE
Tech Comments: RECALL 59B01 CUSTOMER ASSURANCE TEST DRIVE REPLACE
1FTSW31P94EB96808 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2003 27-JAN-2004 152058 USA 32 2E06 030008 4C3Z 9F838 A D50 42 72223
AWS Claim Key: 10472657 Trx Code: E72 Labor Hrs: 3.7
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:29-AUG-2006 Doc #:09744051
Cust Comments: LOSS OF POWER AND THE VEHICLE IS SURGING AT IDLE WITH FOOT ON BRAKE AND WHILE DRIVING AT ALL SPEEDS
Tech Comments: INOP RD TESTED VEHICLRE UNABLE TO VERIFY CONCERN AT THIS TIME CKD OASIS FOR SYMPTOM PREL. CKS OK EEC TEST, PERFORMED PINPOINT TEST A01 A08 UNABLE TO DUPLICATE RERD TESTED MONITORED PIDS ICP, IPR, MGP. RPM, LOAD FOUND ICP VOLTAGE & PRESSURE DROPPING CONTACT HOTLINE 6IOFB4004 REPLACED ICP SENSOR & CONNECTOR RERD TESTED WHILE MONITORING PIDS ICP, IPR, MGP, RPM, RETESTED SYSTEM CKS OK AT
1FTSW31P94EB96808 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2003 27-JAN-2004 152058 USA 34 1B03 030204 3C3Z 6A642 AA L65 D1 75425
AWS Claim Key: 10562743 Trx Code: E72 Labor Hrs: 7.8
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-OCT-2006 Doc #:01629051
Cust Comments: 6.0L DIESEL CHECK VEHICLE LEAKING OIL AND HAS OIL IN COOLANT REPORT
Tech Comments: VERIFY CONCERN,OIL IS MIXING WITH COOLANT,R I TURBO,INTAKE AND EGR CO OLER TO GAIN ACCESS TO OIL COOLER,REPLACE OIL COOLER,PERFORMED COOLANTFLUSH WITH WATER AND AND SOAP 5 TIME TO CLEAN OUT ENGINE,FILL WITH CO OLANT,CHANGE OIL AND RETEST OK
1FTSW31P94EB96808 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2003 27-JAN-2004 152058 USA 38 1B03 030204 3C3Z 6A642 AA D50 42 82762
AWS Claim Key: 11362881 Trx Code: E72 Labor Hrs: 26
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:19-FEB-2007 Doc #:02901051
Cust Comments: 6.0L DIESEL CHECK VEHICLE OVERHEATING BLEW WHITE SMOKE AND WILL NOT RESTART REPORT VEHICLE DID START ON SERVICE DRIVE
Tech Comments: KETS PER TSB,CK CYL HEADS FOR STRAIGTNESS HEADS ARE WITHIN SPECS,INSTALLED NEW HEADGASKETS AND HEAD BOLTS,REASSEMBLED AND REINSTALLED ENGINE,FILLED FLUIDS,RD TEST OK
1FTSW31P94EB96808 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2003 27-JAN-2004 152058 USA 42 1H03 030804 4C3Z 9P456 AF D50 55 87500
AWS Claim Key: 11774834 Trx Code: E72 Labor Hrs: 9.1
Dlr Cd-Sub Cd: 06889 - * Name: EXPRESSWAY FORD Ph: 915-8342800 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-JUN-2007 Doc #:92532701
Cust Comments: CUSTOMER STATES INSPECT HEAD GASKET OR EGR COOLER. VEHICLE SPOUTING WHITE SMOKE. CHECK AND ADVISE.
Tech Comments: P404 P269 P275 COOLER LEAKING INJS INOP PRESSURE TESTED COOLING SYST REPLACED EGR COOLER PERFORMANCE TESTS PINPOOINT TESTS COMPRESSION TEST REPLACED#3#5 INJS
1FTSW31P94EB96808 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2003 27-JAN-2004 152058 USA 43 1B03 030204 3C3Z 6A642 AA D50 42 90406
AWS Claim Key: 11950324 Trx Code: E72 Labor Hrs: 8.7
Dlr Cd-Sub Cd: 04424 - * Name: JENNINGS ANDERSON FORD Ph: 830-7553673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:06-AUG-2007 Doc #:03705651
Cust Comments: COOLANT AND SMOKE FROM EXHAUST
Tech Comments: CROSS CONTAMINTAION 60L DIAG CHART FOUND NO COOLANT IN ENGINE OIL PERFORMED TSB 07 14 5 R&I INTAKE REPLACED THE ENGINE OIL COOLER ALSO EGR COOLER CLEANRED AND INSPECTED EGR VALCE CHANGED OIL AND FILTER FLUSHED THE COOLING SYSTEM REPLACED THE DEGAS BOTTLE ADDED COOLANT PERFORMED A PID MONITOR TEST CHECKED ROAD TESTED PROBLEM CORRECTED
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
