Oasis report please, Thanks In Advance! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by parasail, this thread has received 1 replies and been viewed 527 times.
post #1 of 2 (permalink) Old 08-27-2007, 02:48 PM Thread Starter
1FMSU45P63ED13681
:thanks:
parasail is offline
post #2 of 2 (permalink) Old 09-03-2007, 11:53 PM
Squatch's Avatar
Standard Claims List For Model Year 2003
1FMSU45P63ED13681 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-APR-2003 07-AUG-2003 152467 USA 33 2E05 100106 6C3Z 9B249 A B43 42 40200
AWS Claim Key: 13575156 Trx Code: E72 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 06844 - * Name: THORNHILL FORD-MERCURY Ph: 972-9380444 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:11-APR-2006 Doc #:074241A
Cust Comments: WATER IN FUEL LIGHT IS ON
Tech Comments: PERFORMED ELECTRICAL DIAG AND REPLACED WIF SENSOR RETESTD ALL OK
1FMSU45P63ED13681 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-APR-2003 07-AUG-2003 152467 USA 33 * * * * * * * 40200
AWS Claim Key: 13575154 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 06844 - * Name: THORNHILL FORD-MERCURY Ph: 972-9380444 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:11-APR-2006 Doc #:074241B
Cust Comments: RECALL 59B01
Tech Comments: COMPLETED RECALL
AWS Claim Key: 13575155 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 06844 - * Name: THORNHILL FORD-MERCURY Ph: 972-9380444 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:11-APR-2006 Doc #:074241C
Cust Comments: RECALL 06E17
1FMSU45P63ED13681 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-APR-2003 07-AUG-2003 152467 USA 38 5V09 120307 6C3Z 2A451 A B43 42 46301
AWS Claim Key: 14434481 Trx Code: 0710D Labor Hrs: 0.8
Dlr Cd-Sub Cd: 06844 - * Name: THORNHILL FORD-MERCURY Ph: 972-9380444 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:16-SEP-2006 Doc #:077832C
Cust Comments: A C BLOWING THREW DEFROST
Tech Comments: PERFORMED ELECTRICAL PPTESTED REPLACED SHORTED VAC PUMP AND REPLACED BLOWN MINI FUSE RETESTED ALL OK
1FMSU45P63ED13681 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-APR-2003 07-AUG-2003 152467 USA 41 2B01 030706 3C3Z 6C315 AA B43 42 51371
AWS Claim Key: 14686038 Trx Code: E72 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 06844 - * Name: THORNHILL FORD-MERCURY Ph: 972-9380444 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:02-DEC-2006 Doc #:079573A
Cust Comments: OIL LEAK OR SOME SORT OF FLUID LEAK COMING FROM PASSNGER SIDE OF VEHICLE
Tech Comments: PERFORMED OIL LEAK DIAG REPLACED LOW PRESSURE OIL REGULATOR ORING AND LEAKING CRANK SENSOR RETESTED OIL LEAK IS GONE
1FMSU45P63ED13681 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-APR-2003 07-AUG-2003 152467 USA 41 1D02 031001 3C3Z 9433 AA B43 42 51808
AWS Claim Key: 14707180 Trx Code: E72 Labor Hrs: 4.9
Dlr Cd-Sub Cd: 06844 - * Name: THORNHILL FORD-MERCURY Ph: 972-9380444 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-DEC-2006 Doc #:079812A
Cust Comments: OIL LEAK FROM REAR OF ENGINE
Tech Comments: PERFORMED COOLANT DIAG FOUND ORANGE HOSE AT EGR COOLER LEKAING REPLACED INTAKE GASKETS AND ORANGE HOSE RETESTED LEAK IS GONE
1FMSU45P63ED13681 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-APR-2003 07-AUG-2003 152467 USA 41 2H02 030407 5C3Z 6F089 BA B43 42 51808
AWS Claim Key: 14707181 Trx Code: E72 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 06844 - * Name: THORNHILL FORD-MERCURY Ph: 972-9380444 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-DEC-2006 Doc #:079812B
Cust Comments: CHECK ENGINE LIGHT ON
Tech Comments: PERFORMED DIESEL DIAG FUEL AND OIL IN SPECS VGT DIAG REPLACED VGT SOLENOID RETESTED ALL OK
1FMSU45P63ED13681 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-APR-2003 07-AUG-2003 152467 USA 49 1H03 030804 4C3Z 9J460 A E29 42 56870
AWS Claim Key: 15390919 Trx Code: E72 Labor Hrs: 4.2
Dlr Cd-Sub Cd: 02617 - * Name: BIRD/KULTGEN INC Ph: 254-6662473 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:23-JUL-2007 Doc #:33681901
Cust Comments: CHECK ENGINE LIGHT HAS BEEN ON
Tech Comments: REPLACE EBP SENSOR AND WATER SEPERATOR
1FMSU45P63ED13681 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-APR-2003 07-AUG-2003 152467 USA 49 2H02 030008 * 6F089 * D42 42 56870
AWS Claim Key: 15387160 Trx Code: E72 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 02617 - * Name: BIRD/KULTGEN INC Ph: 254-6662473 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:23-JUL-2007 Doc #:33681903
Cust Comments: TURBO DOES NOT BOOST CORRECTLY
Tech Comments: CHECK AND REPLACE TURBOCHARGER ASSEMBLY
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
