Oasis please Corey - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jennamax, this thread has received 1 replies and been viewed 433 times.
post #1 of 2 (permalink) Old 09-04-2007, 11:20 PM Thread Starter
Oasis please Corey
I posted a few weeks ago but did not get a response. I know you are busy so when you have time please.
Thanks.
VIN: 1FTSW31P64EA59969
2004 F350 Crew Cab 4X4 6.0 PSD
Lariat, Leather, Sunroof
4 1/2 inch Pro Comp lift
35X12.5X18 Pro Comp Extreme All Terrains
1000 Watt Sound System:Thumbup:
MBRP 4-in turbo back w/cat delete
SCT XCal-2 tuned by Innovative Diesel
Intake Elbow
Autometer Z-Series-pyro, tranny, boost on A-pillar
Zoodad
jennamax is offline
post #2 of 2 (permalink) Old 09-05-2007, 05:03 PM
Squatch's Avatar
OASIS RESULT:
1FTSW31P64EA59969
09/05/2007
12:02:41
FCXWS447
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
ARN MESSAGES
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/16/2003 BUILD DATE
08/31/2003 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
08/27/2007
DEALER: Simi Valley Ford
WARRANTY CLAIM NUMBER: 060805 ODOMETER: 054481M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6584BA GASKET VALVE ROCKER 001 6007D D8 FAILED GASKET/SEAL
000 6584AL
FOUND LEFT COVER GASKET LEAKING OIL REMOVED AND REPLACED GASKET ROAD TESTED OK
08/16/2007
WARRANTY CLAIM NUMBER: 060216 ODOMETER: 054417M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6D083AA GASKET-RR COVER 001 6007D D8 FAILED GASKET/SEAL
3C3Z 6020CA GASKET CYL TIMING GE 001 6007A
3C3Z 6710BA GASKET SET-OIL PAN 001 6007AZW
3C3Z 6710CA GASKET SET-OIL PAN 001 6007A38
XO 15W405QSD 003
3C3Z 6731AA ELEMENT ASY OIL FILT 001
VC 7B 003
3C3Z 9229B GASKET CARB FUEL INL 001
3C3Z 8575AA THERMOSTAT 001
3C3Z 9433AA GASKET SET-MANIFOLD 001
3C3Z 6701A CRANKSHAFT REAR SEAL 001
3C3Z 9F838EA SENSR ASY F/I TIMING 001
6C3Z 9448A GSKT EXH MNFLD TO CY 002
5C3Z 6710AA GASKET SET-OIL PAN 001
W302725 001
DYE TESTED FOUND BED PLATE LEAKING OIL REMOVED ENGINE INSPECTED FOUND EXHAUS T LEAK AT MANIFOLD REMOVE AND REOPLACE AND GASKET ALSO REPL INTAKE MANIFOLD GASKET CLEANED CARBON INSIDE AND CLEAN EGR ROADTESTED OK
08/16/2007
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 001 9527AL 42 DOES NOT OPERATE PROPERLY
MISFIRE CODES P0284 NO.8 INJECTORED FAILED SO I REPLACED IT AND NOW NO CODES
04/02/2007
WARRANTY CLAIM NUMBER: 053541 ODOMETER: 052243M
LABOR OP
CONDITION CODE
CONDITION DESC
PM 6 001 6005F 42 DOES NOT OPERATE PROPERLY
PM 17A MOTORCRAFT BATTERY 001 6005F1
3C3Z 9F838EA SENSR ASY F/I TIMING 001 6005F1X1
3C3Z 6K775AA COOLER ASSY 001 6005F2
000 6005F6
000 6005F8
000 6005F18
000 6005F22
000 6005F23
000 6005F39
000 12650D81
000 6005F45
000 6775A
000 9838A
000 VERIFY60
DIESEL ENGINE PERFORMANCE DIAGNOSTICS - DIESEL ENG INE - DIAGNOSIS
04/02/2007
LABOR OP
CONDITION CODE
CONDITION DESC
9E527 NOZZLE ASY-FUEL INJE 000 070504A 42 DOES NOT OPERATE PROPERLY
DIESEL RECALIBRATED MODULES
01/26/2007
DEALER: Galpin Ford
WARRANTY CLAIM NUMBER: 910268 ODOMETER: 051026M
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
CCB418 PERFORMED RECALL 59B01
01/26/2007
DEALER: Galpin Ford
WARRANTY CLAIM NUMBER: 910267 ODOMETER: 051026M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6K682BARM TURBO CHG-EXH DRIVE 001 062302A 42 DOES NOT OPERATE PROPERLY
3C3Z 9T516BA KIT-TUBE TRBCH OIL S 001 MTABNORMAL
W300012 002 12650D84
4C3Z 9F452A TRANSDCR-EGR BACK PR 001
3C3Z 6766BA CAP ASY OIL FILLER 001
3C3Z 6A603AA KIT - PVC FITTING 001
6C2Z 6K786AA CLAMP AIR COOLING 001
6C3Z 6C640B CONNECTION A/C DUCT 001
5C3Z 6K769AA DUCT A COOLER 001
6C3Z 6C640A CONNECTION A/C DUCT 001
6C3Z 6K786CA CLAMP AIR COOLING 002
6C3Z 6C640C CONNECTION A/C DUCT 001
CCB418/A601 DISASSEMBLED TURBO, REPLACED DAMAGED TURBO, REPLACED CRANKCASE, REPLACED CAC TUBE, RETEST.
01/26/2007
DEALER: Galpin Ford
LABOR OP
CONDITION CODE
CONDITION DESC
000 06E17B
CCB418 PERFORMED RECALL 06E17
| On-line 1878
END OF OASIS REPORT FOR 1FTSW31P64EA59969
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
