Oasis Please! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by RockStar, this thread has received 1 replies and been viewed 375 times.
post #1 of 2 (permalink) Old 09-19-2007, 09:46 PM Thread Starter
RockStar's Avatar
Send a message via MSN to RockStar
Oasis Please!
VIN: 1FTSX31P54ED51044
Thanks
RockStar is offline
post #2 of 2 (permalink) Old 09-26-2007, 09:23 PM
OASIS RESULT:
1FTSX31P54ED51044
09/26/2007
17:22:48
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 S/CAB PICKUP 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
ARN MESSAGES
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/08/2004 BUILD DATE
05/22/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
06/08/2007
DEALER: Stanley Ford, Inc.
WARRANTY CLAIM NUMBER: 600850 ODOMETER: 021609M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 3A131AD KIT SPINDLE CON ROD 001 3001A1T 42 DOES NOT OPERATE PROPERLY
4C3Z 3049DB JOINT ASY-FRT SUSP L 002 3049AT
5C3Z 3050AB KIT-FRT SUSP LWR SPD 002 3130AA
F81Z 4228BA WASHER-DIFF SIDE GR 001
CHECK OUT FRONT END LOOSE FOND UPPER AND LOWER BALL JOINTS LOOSE AND RIGHT O UTER TIE ROD END LOOSE R&R UPPER AND LOWER BALL JOINTS BOTH SIDES R&R RIGHT OUTER TIE ROD END LONG CHECK ALIGNMENT ALIGNED FRONT END CHANGED CAMBER BOTH SIDES SET TOE CENTER STEERING WHEEL ROAD TEST OK
STEVEASHCRAFT is offline
