Oasis please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by pickit, this thread has received 1 replies and been viewed 347 times.
post #1 of 2 (permalink) Old 09-20-2007, 01:37 AM Thread Starter
Oasis please
Hello -
I am new here and looking at buying a diesel. I have been reading a bunch of helpful information on the site. There are two trucks I am looking at a would like to get an Oasis report for each one. Thanks for the help!
04 - 1FTNW21P34ED84327
05 - 1FTWW30P05EC50260
Thanks - Shaun
pickit is offline
post #2 of 2 (permalink) Old 09-26-2007, 09:22 PM
OASIS RESULT:
1FTNW21P34ED84327
09/26/2007
17:20:37
FCXWS447
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
ARN MESSAGES
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/06/2004 BUILD DATE
06/20/2004 SALE MILEAGE
00044
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0709 - EXPIRED
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: MICHAEL MORRISON
OPTIONS:
EXPIRATION DATE: 08/06/2007
DISTANCE: 75,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 04511
ESP CONTRACT START DATE: 08/06/2004
WARRANTY REPAIR HISTORY
04/30/2007
DEALER: Mac Haik Ford
WARRANTY CLAIM NUMBER: 023349 ODOMETER: 091613M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 061906C 55 PLUGGED/RESTRICTED
3C3Z 9P455AB SE E/G/R VLV 001
91615 55.9F452 RETRIEVED DTCS, FOUND P0281,P0401,P0404,P1335. PERFORMED TSB 06-19-6. REMOVED EGR VALVE, FOUND STUCK OPEN. CLEANED VALVE PER TSB. PERFO RMED EGR TEST AFTER CLEANING VALVE, FAILED POSITION TEST AGAIN. REPLACED VA LVE PER TSB. REASSEMBLED UNIT, CLEARED CODES. ROAD TESTED. UNIT NO LONGE R BLOWS BLACK SMOKE. UNIT STILL HAS MISS AND WH ITE SMOKE TO BE REPAIRED ON O
04/30/2007
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 002 6007A 42 DOES NOT OPERATE PROPERLY
W302725 001 6005F
3C3Z 6710BA GASKET SET-OIL PAN 001 6005F13
3C3Z 6710CA GASKET SET-OIL PAN 001 6005F1
3C3Z 6626AA SCREEN OIL PUMP 001 6005F2
3C3Z 6200AARM CONNECTING ROD ASY 001 6007A24
4C3Z 6051EA GASKET CYL HEAD 001 6051A11
3C3Z 9229AA GASKET CARB FUEL INL 004 MT6200
XO 15W40QSD 015
3C3Z 6731AA ELEMENT ASY OIL FILT 001
W300965 004
4C3Z 6148AA RING SET 001
4C3Z 6108AA PISTON & PIN ASY 001
3C3Z 6211AA BEARING ROD 001
3C3Z 9433BE GASKET SET-MANIFOLD 001
91618 42.6200,6211,6710,W300965,6626,9229,67110,9E527 ,9433,W302725,1848285C 2 VISUAL INSPECTION, OK. CLEAN FUELLL, OK. OIL LE VEL, OK. ODDTCS, NO DTC. CONT, P0281,P0401,P040 4,P1335. INJECTOR SELF TEST, NO DTC. POWER BALA NCE , #5 AND 7. FUEL PRESSURE, 52 PSI. RAN RELAT IVE COMPRESSION TEST, CYL #7 FA ILED WITH 10% DROP FROM OTHER CYLINDERS. REMOVED ENGINE AND REMOVED RIGHT HE
04/16/2007
WARRANTY CLAIM NUMBER: 022741 ODOMETER: 090820M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 001 9527AR 42 DOES NOT OPERATE PROPERLY
PM 15 001 6005F
6C3Z 6C640C CONNECTION A/C DUCT 001 6005F13
000 6005F1
000 6005F2
000 12650D84
000 6646AT
90822 42.6C640,42.9E527 VERIFIED CONCERN, UNIT SMOKED WHITE. VEISUAL INSPEC TION, OK. CLEAN FUEL, OK. FUEL PRESSURE, 52 PSI. OIL LEVEL, OK. ODD, NO DTCS . CONT, P028 1,P0401. ELEC INJECTOR SELF TEST, NO DTC. POWER BALANCE, #7 NO T CONTRIBUTING. FOUND UPPER CHARG E AIR HOSE ELBOW HAD A HOLE IN IT. REPLLA CED ELBOW. RAN PINPOINT P. REPLACED INJECTOR #7 PER PINPOINT TEST. RECALIBR
04/16/2007
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 002 ADD 42 DOES NOT OPERATE PROPERLY
000 9527AT
90835 42.9E527 VERIFIED ENGINE RUNS ROUGH AND SMOKES. SMOKE SMELLED OF FUEL . RAN POWER BALANCE, FOUND CYL 7 NOT CONTRIBUTING. SERVICE PART #7 INJECTOR . REMOVED VALVE COVER AND REPLACED #7 INJECTOR. REASSEMBLED. RAN ENGINE, RE RAN POWER BALANCE, FOUND CYL 2 WOULD NOT FULLY CUT OUT AND WAS OVE R COMPI NSATING. REMOVED LEFT VALVE COVER AND RE PLACED #2 INJECTOR. REASSEMBLED. C
| On-line 1878
END OF OASIS REPORT FOR 1FTNW21P34ED84327
05
OASIS RESULT:
1FTWW30P05EC50260
09/26/2007
17:21:35
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 CREW CAB 4X2 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-17-06
WARRANTY START DATE
03/29/2005 BUILD DATE
02/22/2005 SALE MILEAGE
00199
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
| On-line 1878
STEVEASHCRAFT is offline
