oasis please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by imported_thnkfst, this thread has received 1 replies and been viewed 486 times.
post #1 of 2 (permalink) Old 09-20-2007, 10:08 PM Thread Starter
oasis please
Looking for the history of 1FTSW21P55EB18781
Thanks
imported_thnkfst is offline
post #2 of 2 (permalink) Old 09-26-2007, 09:17 PM
OASIS RESULT:
1FTSW21P55EB18781
09/26/2007
17:16:49
FCXWS446
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
5F710N0A
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-17-06
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/26/2005 BUILD DATE
10/28/2004 SALE MILEAGE
00050
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
07/05/2007
DEALER: Perry Ford Lincoln Mercury of
WARRANTY CLAIM NUMBER: 203852 ODOMETER: 045156M
LABOR OP
CONDITION CODE
CONDITION DESC
6C646 DUCT ASY-ENG CHG AIR 000 P101 01 BROKEN/CRACKED
PAINT 002 P8
000 MT16612
000 B
07/02/2007
WARRANTY CLAIM NUMBER: 203758 ODOMETER: 045156M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 6C646BA DUCT ASY-ENG CHG AIR 001 6646AC 42 DOES NOT OPERATE PROPERLY
2L1Z 9F479AA MAP SENSOR 001 12650D
3C3Z 14A099AA SHIELD WIRING 001 12650DX1
000 12650D13
000 MT14A099
06/08/2007
WARRANTY CLAIM NUMBER: 203015 ODOMETER: 044732M
LABOR OP
CONDITION CODE
CONDITION DESC
6051 GASKET CYL HEAD 000 12650D 42 DOES NOT OPERATE PROPERLY
5C3Z 6079D GASKET SET-VALVE GRI 001 12650DX1
6C3Z 8A080B COOLANT O/FLO BOTTLE 001 8005D
F6DZ 8100A CAP ASY RADIATOR 001 12650D81
3C3Z 9433AA GASKET SET-MANIFOLD 001 8100A
3C3Z 6731AA ELEMENT ASY OIL FILT 001 8080A
XO 15W40QSD 015 6051AT
VC 7B 002
YN 19 042
TSB 06-21-02 PERFORMED DIAG-MGP AT 26.3 PSI ON ACELL UP GRADE.AS PER HOT L INE,REMOVE AND REPLACED HEADGASKETS AND RETEST HEADGASKETS WERE NOT REPLACED OR NEEDED ON PREVIOUS REPAIR
04/30/2007
WARRANTY CLAIM NUMBER: 201619 ODOMETER: 043252M
LABOR OP
CONDITION CODE
CONDITION DESC
6051 GASKET CYL HEAD 000 MT062102 42 DOES NOT OPERATE PROPERLY
4C3Z 9P456AF COOLER - EGR 001
VC 7B 002
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001
W705589S 004
W302725 001
3C3Z 6750AA INDICATOR ASY OIL LE 001
PERFORMED DIAG,PERFORMED T.S.B.06-21-02-REPLACED EGR COOLER AND EGR VALVE,RE PLACED DIPSTICK AND RETEST PASS
04/10/2007
DEALER: Atascadero Ford
WARRANTY CLAIM NUMBER: 099749 ODOMETER: 042176M
LABOR OP
CONDITION CODE
CONDITION DESC
9E527 NOZZLE ASY-FUEL INJE 000 070504A 42 DOES NOT OPERATE PROPERLY
PERFORM DIAG AND REFER TO TSB 7-5-04 REPROGRAM PCM PER TSB 1
11/29/2006
WARRANTY CLAIM NUMBER: 097596 ODOMETER: 035824M
LABOR OP
CONDITION CODE
CONDITION DESC
5C4Z 9448A GSKT EXH MNFLD TO CY 002 9430AT D8 FAILED GASKET/SEAL
3C3Z 9S425AA BOLT - HEAD 016
OSP 004
OSP 004
PERF DIAG FND BOTH EXH MANIFOLD GASKETS BAD.R,R BOTH EXH MAN GSKTS OK NOW
11/29/2006
LABOR OP
CONDITION CODE
CONDITION DESC
NPF NO PROBLEM FOUND (NR 000 NPF 82 FREIGHT/POSTAGE/MAINTENANCE
PERF DIAG CK TIRE RUN OUT AND WEAR PATTERN OK.TST DROVE WITH NO VIBRATION.HO IST AND INSPECT DRIVESHAFT.ALL OK NO PROBLEM FOUND.
11/29/2006
LABOR OP
CONDITION CODE
CONDITION DESC
PERF ELECT TRANS DIAG.NO CODES.PERF ELECT BUZZ TST.NO CODES WIRING OK.TST DR OVE WITH NO PROBLEM FOUND.TSTED ON SEVERAL DIFFERENT RAOD CONDITIONS.NO PROB LEM FOUND
11/29/2006
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 2562901HAA COVER FRT ST CUSH 001 OSL D4 FLAW IN MATERIAL
PERF DIAG SUBLET AND REPLACE DRIVERS BOTTOM SEAT CVR.OK NOW.
| On-line 1878
END OF OASIS REPORT FOR 1FTSW21P55EB18781
STEVEASHCRAFT is offline
