Thinking of buying-Oasis Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Mustang42, this thread has received 3 replies and been viewed 563 times.
post #1 of 4 (permalink) Old 09-21-2007, 05:09 PM Thread Starter
Addicted to Money
Could some please give me an oasis report on the following VIN:
1FTSW31P84EB89624
I am thinking of buying this truck.
2004 F-350 Crewcab. Bunch of stuff done.
Mustang42 is offline
post #2 of 4 (permalink) Old 09-26-2007, 09:15 PM
OASIS RESULT:
1FTSW31P84EB89624
09/26/2007
17:15:03
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
4F710N0A
WARNING MESSAGES
ARN MESSAGES
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/05/2004 BUILD DATE
01/07/2004 SALE MILEAGE
00005
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
02/21/2007
DEALER: Future Ford
WARRANTY CLAIM NUMBER: 635253 ODOMETER: 051091M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9C623AA AIR CLEANER OUTLET T 001 8005D D8 FAILED GASKET/SEAL
6C3Z 8A080B COOLANT O/FLO BOTTLE 001 8080A
390018S 001 8575B1
3C3Z 8575AA THERMOSTAT 001
REPLACED BOTH HEAD GASKETS, REPLACED EGR COOLER REPLACED EGR VALVE, REPLACE D SPLIT AIR INLET PIPE. INSTALLED NEW DE-GAS BOTTLE TRIED TO CLEAN OLD ONE BUT COULD NOT GET OIL WATER MIX OUT, REPLACED THERMOSTAT, ADDED NEW COOLAN T TO SYSTEM, TECH 189 PERFORMED COOLING SYSTEM TESTS WITH BRIAN TENNEL AND FOUND THE EGR COOLER LEAKING.
02/21/2007
DEALER: Future Ford
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 8146AJ SHROUD FAN 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F45
000 6005F1
000 6005F6
000 6005F11
000 6005F12
000 6005F14
000 6005F20
000 6005F25
000 6005F1X1
TECH 189 PERFORMED ENGINE DIAG AND FOUND CODE P0401. PERFORMED DIESEL PERF DIAG AND FOUND ALL SENSORS WITHIN PERAMETERS. FOUND 24 PSI OF BOOST. FOUND THE VGT FUNCTIONS OK. FOUND THE EGR PASSED FUNCTION TESTS JUST AT LOW LEVEL S. REMOVED THE EGR AND COOLANT IN THE EGR PASSAGE FURTHER TESTED AND FOUND FAILED EGR COOLER AND HEAD GASKETS.
02/21/2007
DEALER: Future Ford
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6020CA GASKET CYL TIMING GE 001 6007D D8 FAILED GASKET/SEAL
5C3Z 6710AA GASKET SET-OIL PAN 001 6007A
3C3Z 6D083AA GASKET-RR COVER 001 6007A38
3C3Z 6701AA CRANKSHAFT REAR SEAL 001
3C3Z 6710BA GASKET SET-OIL PAN 001
3C3Z 6710CA GASKET SET-OIL PAN 001
3C3Z 6731AA ELEMENT ASY OIL FILT 001
XO 15W40QSD 015
3C3Z 6619FA GASKET (OIL PUMP) 001
4C3Z 9F452A TRANSDCR-EGR BACK PR 001
4C3Z 9P456AF COOLER - EGR 001
VC 7B 003
XT 2QDX MOTORCRAFT BATTERY 002
4C3Z 6051EA GASKET CYL HEAD 002
3C3Z 6N640AA GASKET TURBO TO MANI 001
3C3Z 9E933AA GSKT-EGR TO-TH-BDY 001
W300013 004
W300050 004
3C3Z 6766BA CAP ASY OIL FILLER 001
XT 6QSP 001
REPLACED BED PLATE SEALS REPLACED REAR MAIN SEAL REPLACED FRT CRANK SEAL, C LEANED OFF OIL RESIDUE NOTE TRUCK IS EQUIPPED WITH AFTERMARKET WELDED EXHA UST PIPE AND AFTERMARKET FOG LAMPS TECH 189 PERFORMED OIL LEAK DIAG AND FOU D THE BED PLATE LEAKING.
| On-line 1878
END OF OASIS REPORT FOR 1FTSW31P84EB89624
STEVEASHCRAFT is offline
post #3 of 4 (permalink) Old 09-26-2007, 09:22 PM Thread Starter
Addicted to Money
Thanks!!
post #4 of 4 (permalink) Old 09-26-2007, 09:25 PM
Your welcome.
