Oasis report....Please! Por Favor? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dpsammy, this thread has received 2 replies and been viewed 647 times.
post #1 of 3 (permalink) Old 09-25-2007, 05:31 AM Thread Starter
Hi, I just joined this site as I am looking into buying an '05 Excursion with the 6.0. I would like an Oasis report if possible. The VIN is 1FMSU45P15EA44878. I already ran a Carfax report, which came back clean.
Thanks!
Sammy
dpsammy is offline
post #2 of 3 (permalink) Old 09-29-2007, 04:22 PM
not trying to step on any toes...thought i could help out though
OASIS RESULT:
1FMSU45P15EA44878
09/29/2007
12:20:53
FCXWS446
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 EXCURSION BODY STYLE
4 DR EDDIE BAUER 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
5L110N0A
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
12/30/2004 BUILD DATE
08/25/2004 SALE MILEAGE
02856
59B01
ELIGIBLE FOR ONE-TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIONS RECALL 05E15 OR 06E17 FOR DETAILS.
05B32
DE-GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
09/10/2007
DEALER: Downey Ford Lincoln Mercury
WARRANTY CLAIM NUMBER: 008165 ODOMETER: 038707M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 6K682CBRM TURBO CHG-EXH DRIVE 001 6005F 42 DOES NOT OPERATE PROPERLY
5C3Z 6F089BA ACTUATOR ASSY 001 6005F1
F81Z 8287EA CLAMP ASY-RAD HOSE 001 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F13
000 6005F18
000 6005F21
000 6005F23
000 6005F25
000 6005F39
000 6005F19
000 9438A
PERFORMED SYS TEST KOEO, KOER, INJ, ICP, FUEL CONTAMINATION PASSED FUEL PRES S 55 PSI, ROAD TESTED VEHICLE FOR LACK OF POWER, NO SMOKE, DTC'S. CK OASIS F OUND TSB 071601 NO APLY NO DTC'S,REMOVED TURBO AND INSP FOUND NOT OPERATING PROPERLY,REPLACED TURBOCHARGER AND VGT VALVE DUE TO LEAKING AIR EXTERNAL.ROA DTESTED VEHICLE OK,CK T/BOOST 26 PSI OK AT THIS TIME,SPW REFER TO RO 005706
09/05/2007
DEALER: Fiesta Ford, Inc.
WARRANTY CLAIM NUMBER: 041980 ODOMETER: 038498M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001 061906C 42 DOES NOT OPERATE PROPERLY
000 6005F2
000 6005F11
000 6005F13
000 6005F18
PERFORM VISUAL INSP-OIL LEVEL OK,QUALITY FUEL OK,FUEL PRESSURE 48PSI,PERFORM EEC TEST IDS DISPLAY NO CODES,REMOVE EGR FOR INSP. PE RFORM NORMAL EGR DIAG,PERFORM EGR POSITION TEST AND REPLACE FAILED EGR VALVE RETEST EGR OK.ADD TO PROGRAM PCM #5U7A-12A650-AXF,ADD TO RESET KAMMADD 6 MI LES ROADTEST OK.ADD TO CLEAN IAT SENSOR.
07/02/2007
WARRANTY CLAIM NUMBER: 004888 ODOMETER: 035222M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9229AA GASKET CARB FUEL INL 000 6005E 42 DOES NOT OPERATE PROPERLY
000 6005E45
000 6005F
000 6005F18
000 6005F19
000 9527AT
CRANK NO START NO PWER ECC TEST NO DTC PERFORMED CYLINDER CONTRIBUTION TEST ON CYLINDERS 2-3 IT SHOWS 30% AND 35% LOW INTERMITTENT CK FUEL PRESSURE AND OIL PRESSURE MONITORS ICP WITH WDS FOUND 410PSI AT TIMES REMOVED INJECTORS IN CYLINDER 2-3 AND REPLACE INJECTOR SEALS REASSEMBLE INJECTORS RETEST NOW A T 550 PSI AT ALL TIMES ROAD TEST OK
07/02/2007
WARRANTY CLAIM NUMBER: 005706 ODOMETER: 035222M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 6K682CBRM TURBO CHG-EXH DRIVE 001 062302A 42 DOES NOT OPERATE PROPERLY
PERFORMED EEC TEST RETRIEVED CODES P0299 P0404 REMOVED TURBO AND DIAG PER TS B 06-23-2 R7R TURBO CHARGER AND ERASED CODES
07/02/2007
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15M
05E15 RECALL CALIBRATION UPDATE
07/02/2007
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6D083AA GASKET-RR COVER 001 6007D D8 FAILED GASKET/SEAL
TA 29 MOTORCRAFT BATTERY 001 6083A
OSP 001
INSPECTED AND VERIFIED BAD OIL LEAK BETWEEN ENGINE AND TRANS WITH DYE AND R& R TRANS AND RESEALED LEAKING BED
05/04/2007
WARRANTY CLAIM NUMBER: 002441 ODOMETER: 033922M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 7153AD GASKET TRANSMISSION 001 7000F 30 CHAFED,EXCESSIVE WEAR,FRAYED
5C3Z 7B442AA PLATE-REAR CLUTCH DR 005 7000A
5C3Z 7B164BA PLT ASY-CLTCH IN SPL 005 7000AXQ
3C3Z 7A098AA SCREEN ASY - OIL PAN 001 7000AZJ
XT 6QSP 016 7000A2
000 7000A2ZG
000 7000A4
000 7000A11
000 7000A13
ROADTESTED VEHICLE AND VERIFIED CONCERN, FOUND TRANSMISSION SLIPPING IN 1ST AND 2ND GEAR, PERFORMED EEC TEST AND RETRIVE CODE P0730 PERFORMED TEARDOWN
END OF OASIS REPORT FOR 1FMSU45P15EA44878
Matt99DECH is offline
post #3 of 3 (permalink) Old 09-29-2007, 04:26 PM
1FMSU45P15EA44878 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 25-AUG-2004 30-DEC-2004 156009 USA 3 6Y05 000001 * MAINT * A96 82 5840
AWS Claim Key: 486014 Trx Code: 0712S Labor Hrs: 1.2
Dlr Cd-Sub Cd: 03134 - * Name: PHIL LONG FORD OF CHAPEL HILLS Ph: 719-5722200 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:04-MAR-2005 Doc #:40347001
Cust Comments: QCM NORMAL 7.5K LOF ROT INSP
Tech Comments: 1 COMPLETE PER QCM NORMAL MAINT
1FMSU45P15EA44878 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 25-AUG-2004 30-DEC-2004 156009 USA 5 6Y05 000001 * MAINT * A96 82 13661
AWS Claim Key: 983797 Trx Code: 0712S Labor Hrs: 1.5
Dlr Cd-Sub Cd: 03170 - * Name: GO COURTESY FORD Ph: 303-7944343 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:27-MAY-2005 Doc #:613788A
Cust Comments: QCM NORMAL 7.5 SERVICE
Tech Comments: 13661 SERVICE MB7500 SERVICE PERFORMED SERVICE
1FMSU45P15EA44878 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 25-AUG-2004 30-DEC-2004 156009 USA 20 7W15 131302 1L1Z 15K859 AA A85 42 23080
AWS Claim Key: 5525697 Trx Code: E83 Labor Hrs: 1
Dlr Cd-Sub Cd: 03170 - * Name: GO COURTESY FORD Ph: 303-7944343 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:10-AUG-2006 Doc #:655767A
Cust Comments: BACK UP CHIME IS ALWAYS ON WHEN IN REVERSE
Tech Comments: 23080 TESTED PARK AID W WDS & PERF PINPOINT TEST & FOUND FAILED LRI & RRI SENSORS. REPLACED BOTH SENSORS & RETESTED TO VERIFY REPAIR
1FMSU45P15EA44878 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 25-AUG-2004 30-DEC-2004 156009 USA 29 3A02 0701XX 5C3Z 7B164 BA G29 30 33922
AWS Claim Key: 7719953 Trx Code: E84 Labor Hrs: 13
Dlr Cd-Sub Cd: 02262 - * Name: DOWNEY FORD Ph: 562-8616771 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:04-MAY-2007 Doc #:00244109
Tech Comments: ROADTESTED VEHICLE AND VERIFIED CONCERN, FOUND TRANSMISSION SLIPPING IN 1ST AND 2ND GEAR, PERFORMED EEC TEST AND RETRIVE CODE P0730 PERFORMED TEARDOWN
1FMSU45P15EA44878 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 25-AUG-2004 30-DEC-2004 156009 USA 31 2E03 030402 3C3Z 9229 AA D42 42 35222
AWS Claim Key: 8102348 Trx Code: S07 Labor Hrs: 0
Dlr Cd-Sub Cd: 02262 - * Name: DOWNEY FORD Ph: 562-8616771 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:02-JUL-2007 Doc #:00488801
Cust Comments: CUST STATES VEHIVLE HAS NO POWER
Tech Comments: CRANK NO START NO PWER ECC TEST NO DTC PERFORMED CYLINDER CONTRIBUTION TEST ON CYLINDERS 2 3 IT SHOWS 30% AND 35% LOW INTERMITTENT CK FUEL PRESSURE AND OIL PRESSURE MONITORS ICP WITH WDS FOUND 410PSI AT TIMES REMOVED INJECTORS IN CYLINDER 2 3 AND REPLACE INJECTOR SEALS REASSEMBLE INJECTORS RETEST NOW AT 550 PSI AT ALL TIMES ROAD TEST OK
1FMSU45P15EA44878 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 25-AUG-2004 30-DEC-2004 156009 USA 31 * * * * * * * 35222
AWS Claim Key: 8102349 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 02262 - * Name: DOWNEY FORD Ph: 562-8616771 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:02-JUL-2007 Doc #:00488803
Tech Comments: 05E15 RECALL CALIBRATION UPDATE
1FMSU45P15EA44878 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 25-AUG-2004 30-DEC-2004 156009 USA 31 2H01 030407 4C3Z 6K682 CBRM D41 42 35222
AWS Claim Key: 8255730 Trx Code: S07 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 02262 - * Name: DOWNEY FORD Ph: 562-8616771 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:02-JUL-2007 Doc #:00570601
Cust Comments: CUST STATES VEHICLE HAS NO POWER CK ENGINE LIGHT IS ON
Tech Comments: PERFORMED EEC TEST RETRIEVED CODES P0299 P0404 REMOVED TURBO AND DIAG PER TSB 06 23 2 R7R TURBO CHARGER AND ERASED CODES
1FMSU45P15EA44878 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 25-AUG-2004 30-DEC-2004 156009 USA 31 1D05 031004 3C3Z 6D083 AA L65 D8 35222
AWS Claim Key: 8255731 Trx Code: E84 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 02262 - * Name: DOWNEY FORD Ph: 562-8616771 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:02-JUL-2007 Doc #:00570603
Tech Comments: INSPECTED AND VERIFIED BAD OIL LEAK BETWEEN ENGINE AND TRANS WITH DYE AND R&R TRANS AND RESEALED LEAKING BED
1FMSU45P15EA44878 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 25-AUG-2004 30-DEC-2004 156009 USA 33 1H03 030008 5C3Z 9F452 AA D02 42 38498
AWS Claim Key: 8575001 Trx Code: S07 Labor Hrs: 3.3
Dlr Cd-Sub Cd: 05439 - * Name: FIESTA FORD, INC. Ph: 760-7728000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:05-SEP-2007 Doc #:04198051
Cust Comments: CRANK NO START TOWED IN
Tech Comments: PERFORM VISUAL INSP OIL LEVEL OK,QUALITY FUEL OK,FUEL PRESSURE 48PSI,PERFORM EEC TEST IDS DISPLAY NO CODES,REMOVE EGR FOR INSP. PERFORM NORMAL EGR DIAG,PERFORM EGR POSITION TEST AND REPLACE FAILED EGR VALVE RETEST EGR OK.ADD TO PROGRAM PCM #5U7A 12A650 AXF,ADD TO RESET KAMMADD 6 MILES ROADTEST OK.ADD TO CLEAN IAT SENSOR.
1FMSU45P15EA44878 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 25-AUG-2004 30-DEC-2004 156009 USA 33 2H01 030407 4C3Z 6K682 CBRM D42 42 38707
AWS Claim Key: 8581396 Trx Code: E91 Labor Hrs: 6.9
Dlr Cd-Sub Cd: 02262 - * Name: DOWNEY FORD Ph: 562-8616771 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:10-SEP-2007 Doc #:0081651
Cust Comments: CUSTOMER STATES VEHICLE HAS NO POWER ON ACCEL, RUNS ROUGH
Tech Comments: PERFORMED SYS TEST KOEO, KOER, INJ, ICP, FUEL CONTAMINATION PASSED FUEL PRESS 55 PSI, ROAD TESTED VEHICLE FOR LACK OF POWER, NO SMOKE, DTC'S. CK OASIS FOUND TSB 071601 NO APLY NO DTC'S,REMOVED TURBO AND INSP FOUND NOT OPERATING PROPERLY,REPLACED TURBOCHARGER AND VGT VALVE DUE TO LEAKING AIR EXTERNAL.ROADTESTED VEHICLE OK,CK T/BOOST 26 PSI OK AT THIS TIME,SPW REFER TO RO 005706 7/200/7 MILES 35839
