oasis please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TAZO, this thread has received 1 replies and been viewed 637 times.
post #1 of 2 (permalink) Old 09-26-2007, 06:18 PM Thread Starter
oasis please
Vin# 1ftwx31p75ec72459
Thank You!
2005 F350 lariat lb sc 6.0 PSD ZF 6 speed
Mods:BD exhaust brake
Dura flap's
Splitz lift hoist
Piaa rear lights
Isspro EV pyro guage
Mid West short throw shifter
TAZO is offline
post #2 of 2 (permalink) Old 09-26-2007, 09:10 PM
here yea go man.
OASIS RESULT:
1FTWX31P75EC72459
09/26/2007
17:09:02
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 S/CAB PICKUP 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
ZF M6HD-W 6-SPEED AXLE CODE
3L ENGINE CALIBRATION
5F720F0A
WARNING MESSAGES
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-17-06
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/17/2005 BUILD DATE
04/24/2005 SALE MILEAGE
00004
05B32
DE-GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
08/28/2007
DEALER: Novato Ford Lincoln Mercury
WARRANTY CLAIM NUMBER: 076729 ODOMETER: 043195M
LABOR OP
CONDITION CODE
CONDITION DESC
XO 15W40QSD 003 9543A 07 IMPROPERLY ADJUSTED/FITS POORLY
4C3Z 9B246A KIT-FUEL SYSTEM SERV 001 9968B
W301727 OIL PUMP FITTING 001 12650D
5C4Z 9A543B PUMP ASY-FUEL INJECT 001 12650DX1
5C3Z 9C968CA FUEL PRESSURE REG 001 12650D45
F81Z 8287EA CLAMP ASY-RAD HOSE 001
OSP 003
VC 7B 002
TECH TRACED THE PROBLEM TO THE THE PUMP AND IPC NEEDING TO BE REPLACED TEC H REPLACED THE PUMP AND THE SENSOR STILL NO START... TECH CALLED TECH LINE A ND THEY RECOMMEND REPLACING THE PUMP AGAIN
08/28/2007
LABOR OP
CONDITION CODE
CONDITION DESC
5C4Z 9A543B PUMP ASY-FUEL INJECT 001 9543A 42 DOES NOT OPERATE PROPERLY
TECH REPLACED THE PUMP AND RESTORE TRUCK RETESTED ALL OK AT THIS TIME
02/13/2007
DEALER: San Francisco Ford Lincoln Mer
WARRANTY CLAIM NUMBER: 447249 ODOMETER: 033009M
LABOR OP
CONDITION CODE
CONDITION DESC
DIAG DIAGNOSIS 000 12650D 42 DOES NOT OPERATE PROPERLY
000 12650D80
HOOK UP IDS AND PERF KOEO ON DEMAND SELF TEST. CLEARED DTCS AND RELEASE VEH BACK TO CUST.
SYMPTOM CODE INFORMATION
590000 - DRIVELINE PUBLICATION REVISIONS/UPDATES
SPECIAL SERVICE MESSAGES
18871 MULTIPLE VEHICLES - AXLE GEAR MARKING COMPOUND 'XG-14'
MOTORCRAFT HAS RELEASED XG-14 MOTORCRAFT HIGH CONTRAST HYPOID GEAR MARKING COMPOUND FOR USE IN AXLE REPAIRS. CHECKING GEAR SET CONTACT TOOTH PATTERN CAN BE VERIFED EASIER WITH THE USE OF MOTORCRAFT GEAR MARKING COMPOUND. XG-14 WILL BE REFERENCED IN THE AXLE REPAIR SECTION OF FUTURE SHOP MANUALS. THE FEATURES OF THIS NEW PRODUCT INCLUDE: SPECIALLY FORMULATED TO BE NON-DAMAGING TO AXLE BEARINGS; COMPATIBLE WITH ALL FORD/MOTORCRAFT HYPOID GEAR LUBRICANTS; BRUSH-ON APPLICATION.
EFFECTIVE DATE: 10/11/2005
18104 1999-2005 SUPER DUTY F-SERIES AND 2000-2005 EXCURSION 4X4 - TRANSFER CASE SHIFT ISSUES - SERVICE TIP
SOME 1999-2005 SUPER DUTY F-SERIES AND 2000-2005 EXCURSION VEHICLES WITH AN ELECTRONIC SHIFT ON THE FLY (ESOF) TRANSFER CASE MAY EXHIBIT TRANSFER CASE SHIFTING CONCERNS. TO SERVICE, FOLLOW NORMAL DIAGNOSTIC PROCEDURES IN WORKSHOP MANUAL SECTION 308-07, PAYING CLOSE ATTENTION TO THE 4X4 SHIFT RELAYS. THE RELAYS ARE LOCATED ON THE DRIVER'S SIDE INNER FENDER AND CAN BECOME DISLODGED CAUSING THEM TO BE EXPOSED TO WATER AND CORRODE. IF THIS CONDITION IS FOUND, REPAIR AS NECESSARY AND RE-EVALUATE THE VEHICLE FOR PROPER OPERATION.
EFFECTIVE DATE: 08/30/2004
THERE ARE NO TSBS FOR SYMPTOM ENTERED
Request Hotline Assistance | Powertrain Prior Approval | On-line 1878
END OF OASIS REPORT FOR 1FTWX31P75EC72459
STEVEASHCRAFT is offline
