Oasis report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bushpilot, this thread has received 1 replies and been viewed 439 times.
post #1 of 2 (permalink) Old 10-02-2007, 04:01 PM Thread Starter
bushpilot's Avatar
Oasis report Please
1FTWW31P95EA10865
Thanks !
Don R.
Truck Audio,
bushpilot is offline
post #2 of 2 (permalink) Old 10-02-2007, 09:03 PM
OASIS RESULT:
1FTWW31P95EA10865
10/02/2007
17:02:08
FCXWS447
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-17-06
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/31/2005 BUILD DATE
07/28/2004 SALE MILEAGE
05189
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
07/23/2007
DEALER: Barber Ford, Inc.
WARRANTY CLAIM NUMBER: 066726 ODOMETER: 027592M
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 7A103A FRONT PUMP ASY-TRANS 001 7000F 42 DOES NOT OPERATE PROPERLY
3C3Z 7A098AA SCREEN ASY - OIL PAN 001 7000F2
XT 6QSP 016 7000A
3C3Z 7B164DA PLT ASY-CLTCH IN SPL 004 7000AXQ
5C3Z 7B442CA PLATE-REAR CLUTCH DR 004 7000AZJ
3C3Z 7A248BA OIL SEAL FRT OIL PUM 001 7000A2
3C3Z 7A136AA GASKET - FRT PUMP TO 001 7000A4
3C3Z 7N134BA BLT ASY-TRANS BREA 009 7000A11
3C3Z 7C155DA GSKT CONTROL VALVE 001 7000A43
2W4Z 7B155E FLTR&HD ASY TRNS OIL 001 MT7000
7000 TRANSMISSION ASY-AUT 000
04/09/2007
WARRANTY CLAIM NUMBER: 063754 ODOMETER: 023867M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 7J136AA SOL ASY-TRANS DIR EL 001 7000F 42 DOES NOT OPERATE PROPERLY
4C3Z 7G383AA EPC SOLENOID 001 7000F2
3C3Z 7A098AA SCREEN ASY - OIL PAN 001 7000A
XT 6QSP 016 7000AXQ
5C3Z 7A130AA SUPPORT ASY-PLANETAR 001 7000AZJ
3C3Z 7B164DA PLT ASY-CLTCH IN SPL 004 7000A2
5C3Z 7B442CA PLATE-REAR CLUTCH DR 004 7000A4
3C3Z 7H359AA PST-TRANS DIR CL BAL 001 7000A11
3C3Z 7A262BA PISTON-TRANSMISSION 001 7000A43
7C3Z 7B070A DISC SPRING-F/CLUTCH 001
5C3Z 7F283AA DIRECT CLTCH CLY ASY 001
378941S441 006
CONCERN VERIFIED REMOVE TRANS MOUNT ON BENCH TEAR DOWN FOUND DIRECT CLUTCH BURNT,REPLACE CENTER SUPPORT,DIRECT CLUTCHES AND PLATES,ALSO 2 SOLENOIDS OV ERHAUL TRANS AS NECES FLUSH LINES AND COOLERS INSTALL INFLOW FILTER FILL TO LEVEL AND RETEST
02/05/2007
DEALER: Gibbons Ford
WARRANTY CLAIM NUMBER: 214819 ODOMETER: 022125M
LABOR OP
CONDITION CODE
CONDITION DESC
BXT 65750 MOTORCRAFT BATTERY 001 10654CA 42 DOES NOT OPERATE PROPERLY
000 MT10654
REPLACE MAIN BATTERY BAD CELL
01/15/2007
WARRANTY CLAIM NUMBER: 214018 ODOMETER: 021703M
LABOR OP
CONDITION CODE
CONDITION DESC
14A107 WIRING R/AXLE CONTRL 000 MT060706 42 DOES NOT OPERATE PROPERLY
6L3Z 9E731A SENSOR SPEED ASY 001
DIAG CONCERN. HAD CODE C1175 AND C1236 FOR REAR WHEEL SPEED SENSOR. REPLACED SENSOR. TSET DROVE. CLEARED CODE. VERIFIED REPAIR.
11/29/2006
WARRANTY CLAIM NUMBER: 211158 ODOMETER: 020926M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 7210BAB LEVER GEAR SHIFT 001 7000F 42 DOES NOT OPERATE PROPERLY
000 7000F2
000 7210A
CHECKED TOW HAUL BUTTON INOP, CHECKED OASIS AND NO SSM OR TSB FOUND. CHECKED FUSE 24 IN CJB, OK. CHECKED TOW HAUL BUTTON, OK. CHECKED TOW HAUL AND FOUND IR WORKED IN PARK BUT NOT IN ANY OTHER GEAR RANGE. REMOVED STEERING COULUM COVER AND INSPECTED WIRING WHILE PUSHING BUTTON, WORKS. REPLACED SHIFT LEVER ASSEMBLY AND VERIFIED TOW HAUL
| On-line 1878
STEVEASHCRAFT is offline
