Oasis Report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Ice Cream Man, this thread has received 3 replies and been viewed 650 times.
post #1 of 4 (permalink) Old 10-02-2007, 09:31 PM Thread Starter
Oasis Report Please
I'm totally new to this site. I have been looking a 2006 that has "some" major issues and wanted an oasis report. I think the motor is toast and wondered about the tranmission/ tranfer case. I thank you in advance for your help. I know it gonna be a long one! The VIN is 1FDXW47P56EA42730 You guys Rock, if I'm ever in your neighborhood its free ice cream time. :Thumbup:
THANKS
The Ice Cream Man
Ice Cream Man is offline
post #2 of 4 (permalink) Old 10-02-2007, 10:37 PM
OASIS RESULT:
1FDXW47P56EA42730
10/02/2007
18:36:34
FCXWS447
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-450 CC CHASIS 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
4L ENGINE CALIBRATION
ARN MESSAGES
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-17-06
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/19/2006 BUILD DATE
06/23/2005 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
04/09/2007
DEALER: Fox Ford
WARRANTY CLAIM NUMBER: 540231 ODOMETER: 105881M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9433BE GASKET SET-MANIFOLD 002 8005D 01 BROKEN/CRACKED
W300013 004 6051AT
W300051 004 MT6049
VC 7B 003
XO 15W405QSD 003
3C3Z 9229AA GASKET CARB FUEL INL 007
3C3Z 6049CARM CYLINDER HEAD 002
3C3Z 9A375AA GSKT F/P DISC HOS RE 003
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 001
3C3Z 6731AA ELEMENT ASY OIL FILT 001
VC 7B 003
3C3Z 8255AA GASKET WATER OUTLET 001
6C3Z 6C640A CONNECTION A/C DUCT 001
6C2Z 6K786AA CLAMP AIR COOLING 001
F6DZ 8100A CAP ASY RADIATOR 001
6C3Z 8A080B COOLANT O/FLO BOTTLE 001
105881 DIAGNOSE FOR FUEL IN COOLING SYSTEM. VERIFIED CONCERN. PRESSURE TEST ED COOLING SYSTEM. DID NOT FIND ANY EXTERNAL LEAKS. CHECKED ENGINE OIL OK. CHECKED FOR COOLANT IN FUEL SYSTEM, OK CALLED HOTLINE, WAS TOLD PROBABLY HA D CRACKED CYLINDER HEADS DUE TO OVERHEATING CONCERN ON PREVIOUS REPAIR THA T WAS DONE ELSEWHERE. R&R BOTH CYLINDERS HEADS. REPLACED WITH REMAN CYL HEAD
03/07/2007
DEALER: Don Woodhams Inc
WARRANTY CLAIM NUMBER: 086800 ODOMETER: 101967M
LABOR OP
CONDITION CODE
CONDITION DESC
OSP 002 MT6A642 49 CONTAMINATED/FOREIGN
OSP 001
VC 7B 002
6A642 COOLER CRANKCASE OI 000
CHEMICALLY FLUSHED COOLING SYSTEM PER SSM 18942 TEST DROVE AND VEHICLE SEEMS OK
03/02/2007
DEALER: Barber Pauley Ford, LLC
WARRANTY CLAIM NUMBER: 019931 ODOMETER: 099251M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AF COOLER - EGR 001 6005F 42 DOES NOT OPERATE PROPERLY
3C3Z 6A642AA COOLER CRANKCASE OI 001 6005F1
3C3Z 9433BE GASKET SET-MANIFOLD 001 6005F1X1
6C3Z 8A080B COOLANT O/FLO BOTTLE 001 6005F2
F6DZ 8100A CAP ASY RADIATOR 001 6005F6
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001 6005F8
VC 7B 002 6005F9
3C3Z 6731AA ELEMENT ASY OIL FILT 001 6005F12
XO 15W40QSD 015 6005F13
000 6005F14
000 6005F20
000 6005F39
000 6005F45
000 8080A
000 6642A
000 6051A10
000 6051A11
000 6051A20
000 12650D30
RUNS ROUGH VERIFIED CUSTOMER CONCERN. PERFORMED DIESEL ENG. DIAG. PERFORMED KOEO, KOEO ING. TEST, KOER, LOW IDLE TEST, CRANKCASE PRESSURE TEST, BOOST TE ST, FUEL CONTAMINATION TEST-OK, INTAKE RESTRICTION TEST, EGR POSTION TEST, E GR SYSTEM TEST-PINPOINT DIAG, FOUND EGR COOLER LEAKING DUE TO OIL COOLEROVER HEATING ALSO OVERHEATING CRACKED COOLANT TANK & WARPED RADIATOR CAP SO IT WO
01/24/2007
DEALER: Fox Ford
WARRANTY CLAIM NUMBER: 534975 ODOMETER: 085000M
LABOR OP
CONDITION CODE
CONDITION DESC
MISC FOR REPAIRS NOT COVE 000 82 FREIGHT/POSTAGE/MAINTENANCE
85000 REFUND FOR $1536.44 TO BE APPLIED TO CUSTOMERS ACCOUNT WITH FORD MOTO R CREDIT.
12/27/2006
DEALER: Fox Ford
WARRANTY CLAIM NUMBER: 533053 ODOMETER: 081551M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 002 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F2
000 6005F6
000 6005F13
000 6005F18
000 6005F20
000 9527AL
000 6005F1X1
000 VERIFY60
81551 VERIFIED ENGINE RUNS ROUGH. PERFORMED DIESEL DIAG PERFORMANCE GUIDE. PERFORMED ALL VISUAL INSPECTS. KOEO. PASS. KOEC. P0278 AND P0284. KOEO INJ ECTOR CLICK TEST. PERFORMED POWER BALANCE. FOUND CYLINDERS 6 AND 8 MISFIRE. CHECKED FUEL PRESSURE. PERFORMED RELATIVE COMPRESSION TEST. VEHICLE HAS LA TEST CALIBRATION TO BUZZ INJECTORS AFTER SHUTDOWN. R-R LEFT VALVE COVER.
12/04/2006
WARRANTY CLAIM NUMBER: 085100 ODOMETER: 075391M
LABOR OP
CONDITION CODE
CONDITION DESC
W301386 001 VERIFY60 42 DOES NOT OPERATE PROPERLY
W301390 001 6005F
W302209 001 062203A
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 002 9527AR
TESTED AND FOUND CODE P0266 P0272 P0284 FOUND VEHICLE NEEDS 2 4 INJECTORS R EMOVED AND REPLACED 2 4 INJECTORS ALSO REPROGRAMED PCM TCM AND FICM RETESTED AND ALL OK
11/20/2006
DEALER: Babbitt Ford
WARRANTY CLAIM NUMBER: 224208 ODOMETER: 071444M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 004 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F1X1
000 6005F2
000 6005F8
000 6005F11
000 6005F12
000 6005F13
000 6005F18
000 6005F19
000 6005F20
000 9527AR
000 VERIFY60
000 12650D80
000 12650D81
000 12650D45
CHECK ENGINE OPS. PULLED CODES P0275, P115A. PO WER BALANCE FLAGGED #1,3,5, 7. REPLACE INJECTORS . TEST DROVE OK
10/10/2006
DEALER: Fox Ford
WARRANTY CLAIM NUMBER: 527845 ODOMETER: 055816M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9P455AB SE E/G/R VLV 001 8005D 01 BROKEN/CRACKED
4C3Z 9P456AF COOLER - EGR 001 9456A
VC 7B 001
55816 DIAGNOSE FOR SMOKE FROM EXHAUST. HAS COOLANT IN EXHAUST. PRESSURE TES TED COOLING SYSTEM. R&R EGR VALVE, FOUND COOLANT IN INTAKE MANIFOLD REPLAC ED EGR COOLER. REPLACED EGR VALVE O-RINGS REFILLED COOLING SYSTEM. MONITERE D DATA PIDS EOT AND ECT. TEMPS STAY WITHIN 10 DEGREES OF EACH OTHER. VERIFI ED REPAIR. 6.0 ENGINE. CODE 01
| On-line 1878
END OF OASIS REPORT FOR 1FDXW47P56EA42730
STEVEASHCRAFT is offline
post #3 of 4 (permalink) Old 10-03-2007, 12:25 AM Thread Starter
Cool Thanks
Thank You Sir!!! I'm from KY too.
post #4 of 4 (permalink) Old 10-03-2007, 12:38 AM
Sweet. I'm in Louisville.....
