Oasis Please. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Adam, this thread has received 1 replies and been viewed 480 times.
post #1 of 2 (permalink) Old 10-03-2007, 02:47 PM Thread Starter
Oasis Please.
Vin #1ftsw21p65ed18858
THANK YOU!
Adam is offline
post #2 of 2 (permalink) Old 10-03-2007, 10:15 PM
OASIS RESULT:
1FTSW21P65ED18858
10/03/2007
18:13:51
FCXWS447
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
5F710C0A
WARNING MESSAGES
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-17-06
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/21/2005 BUILD DATE
04/17/2005 SALE MILEAGE
00008
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0701 - USA 2006 NEW 72/75,000 PREMIUMCARE W/ROADSIDE
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: ADAMD WIPFLI
OPTIONS:
EXPIRATION DATE: 07/21/2011
DISTANCE: 75,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 07900
ESP CONTRACT START DATE: 07/21/2005
0712 - EXPIRED
STANDARD DEDUCTIBLE: 0 USD
OWNER NAME: DAVID SMITH
OPTIONS:
EXPIRATION DATE: 07/21/2007
DISTANCE: 31,000
RENTAL: 0 UP TO 0 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 07820
WARRANTY REPAIR HISTORY
04/02/2007
DEALER: Ford of Dublin
WARRANTY CLAIM NUMBER: 066180 ODOMETER: 032170M
LABOR OP
CONDITION CODE
CONDITION DESC
F81Z 2625596AA W/STR-RR DR GLS 001 25556A 33 LOOSE PART
REPLACE WEATHERSTRIP
04/02/2007
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 7852124AAA RTNR-SLDG ROOF HD/LN 001 MT52124 07 IMPROPERLY ADJUSTED/FITS POORLY
REPLACE MOULDING
04/02/2007
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z25022A68AAA PNL COWL TOP VENT 001 MT022A68 07 IMPROPERLY ADJUSTED/FITS POORLY
4C3Z25022A69AAA PANEL ASY (COWL TOP 001
REPLACE COWLINGS
04/02/2007
LABOR OP
CONDITION CODE
CONDITION DESC
OSP 003 6007D D8 FAILED GASKET/SEAL
3C3Z 6619FA GASKET (OIL PUMP) 001 6007A
5C3Z 6710AA GASKET SET-OIL PAN 001 6007A38
3C3Z 6710CA GASKET SET-OIL PAN 001 MT6020
3C3Z 6710BA GASKET SET-OIL PAN 001 8005D
3C3Z 6D083AA GASKET-RR COVER 001
W300024 004
3C3Z 9T514AD KIT-HDW TRBCH MTNG 001
3C3Z 6020CA GASKET CYL TIMING GE 001
W302725 001
6C3Z 6C640A CONNECTION A/C DUCT 001
6C2Z 6K786AA CLAMP AIR COOLING 002
6C3Z 6C640B CONNECTION A/C DUCT 001
VC 7B 003
TA 29 MOTORCRAFT BATTERY 001
3C3Z 6731AA ELEMENT ASY OIL FILT 001
3C3Z 6734AA GASKET-ENG OIL PAN D 001
XO 15W40QSD 015
3C3Z 9229B GASKET CARB FUEL INL 002
3C3Z 6701AA CRANKSHAFT REAR SEAL 001
MTIME TO REPLACE FRONT AND REAR ENGINE COVER GASKETS AND REAR ENGINE SEAL WI TH SLEEVE, FRONT CRANK SEAL WITH SLEEVE AND CAM SENSOR ORINGS
04/02/2007
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 14D696B ELEM ASY-ST BK HT RH 001 OSL 42 DOES NOT OPERATE PROPERLY
OSL TO REPLACE PASS SIDE FRONT SEAT WARMER
12/26/2006
WARRANTY CLAIM NUMBER: 061121 ODOMETER: 029277M
LABOR OP
CONDITION CODE
CONDITION DESC
NPF NO PROBLEM FOUND (NR 000 NPF 82 FREIGHT/POSTAGE/MAINTENANCE
RAN QUICK TEST. MONITORED GLOW PLUG ON TIME AND IT WENT OFF.
12/26/2006
LABOR OP
CONDITION CODE
CONDITION DESC
YF1Z 14529ABA SWITCH ASY-WINDOW RE 001 ADD 42 DOES NOT OPERATE PROPERLY
000 14529A
VERIFIED CONCERN. SWITCH AND R/F WINDOW SWITCH FOUND IT NEED R/F WIDNOW SWIT CH. REPLACE REPLACED R/F WINDOW SWITCH AND RECK, OK.
| On-line 1878
END OF OASIS REPORT FOR 1FTSW21P65ED18858
STEVEASHCRAFT is offline
