Oasis Request Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Zurler, this thread has received 1 replies and been viewed 494 times.
post #1 of 2 (permalink) Old 10-05-2007, 01:07 PM Thread Starter
I am seeking an Oasis Report for the following VIN.
1FTSW21P95ED10995
2005 F-250
Thanks in advance for your help.
Zurler is offline
post #2 of 2 (permalink) Old 10-05-2007, 08:46 PM
OASIS RESULT:
1FTSW21P95ED10995
10/05/2007
16:45:51
FCXWS446
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-17-06
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/14/2005 BUILD DATE
04/04/2005 SALE MILEAGE
00025
05B32
DE-GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
EXTENDED COVERAGES
0701 - USA 2006 NEW 48/100,000 EXTRACARE W/ROADSIDE
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: JAY CURRY
OPTIONS:
EXPIRATION DATE: 05/14/2009
DISTANCE: 100,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 01472
ESP CONTRACT START DATE: 05/14/2005
WARRANTY REPAIR HISTORY
10/01/2007
DEALER: Gullo Ford Mercury of Conroe
WARRANTY CLAIM NUMBER: 579197 ODOMETER: 069222M
LABOR OP
CONDITION CODE
CONDITION DESC
ESPRCR ESP RENTAL COUPON 001 RC207009679 82 FREIGHT/POSTAGE/MAINTENANCE
ESP RENTAL
07/31/2007
WARRANTY CLAIM NUMBER: 579197 ODOMETER: 069221M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AF COOLER - EGR 001 8005D 42 DOES NOT OPERATE PROPERLY
3C3Z 9P455AB SE E/G/R VLV 001 MT6642A
VC 7B 002 061706A
3C3Z 6731AA ELEMENT ASY OIL FILT 001
W302725 001
XO 15W40QSD 016
3C3Z 6A642AA COOLER CRANKCASE OI 001
3C3Z 6C683AA FLTER-ENG OIL 001
TA 29 MOTORCRAFT BATTERY 001
4C3Z 9B246A KIT-FUEL SYSTEM SERV 001
VC 7B 002
5C4Z 9A543B PUMP ASY-FUEL INJECT 001
5C3Z 9C968CA FUEL PRESSURE REG 001
69221 6A642,9A456 -42 8005D.4,6642A 5.3 VERIFY CONCERN,PRESSURE TEST SYSTEM, FOUND EOT AND ECT TEMPS 80 DEGRESS DIFFERENCE.REPLACE RESTRICTED OIL COOLE R AND DAMAGED EGR COOLER. REFILL AND ENG DIED DURING ROAD TEST, FOUND NO IC P PRESSURE R AND R INJ PUMP TO INSTALL BRACKET, FOUND HOLE INIPR VALVE R AND R AND REPLACED PUMP AND IPR VALVE INSTALLED BRACKET REASSEMBLE AND ROAD TES
07/31/2007
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6N640AA GASKET TURBO TO MANI 001 9438A 42 DOES NOT OPERATE PROPERLY
W300006 004 9438A2
W300013 004
W300050 004
5C3Z 6K854CA PIPE (TURBO INLET LO 001
69221 UP-PIPE SEALFAILURE 9438A 2.0,9438A2 1.6 VERIFY REPLACE LEAKING TURBO SUPPLY PIPES. ROAD TEST.
07/31/2007
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AF COOLER - EGR 001 9456A 42 DOES NOT OPERATE PROPERLY
69221 MISBUILT EGR COOLER 9456A 5.0 REPLACE EGR COOLER.WOULD NOT LINE UP PR OPERLY WITH UP- PIPES.
06/11/2007
WARRANTY CLAIM NUMBER: 574846 ODOMETER: 066289M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 3B239A BAR ASY F/AXLE TRACK 001 1007D 42 DOES NOT OPERATE PROPERLY
000 3239A
| On-line 1878
END OF OASIS REPORT FOR 1FTSW21P95ED10995
STEVEASHCRAFT is offline
