Oasis request for 2008 F-350 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by DGGIORDANO, this thread has received 1 replies and been viewed 655 times.
post #1 of 2 (permalink) Old 10-07-2007, 04:50 PM Thread Starter
Can I please request a full Oasis report on my 2008 F-350. The VIN # is ;
1FTWW31R28EB23479. Thank You in advance for the information. DGG
DGGIORDANO is offline
post #2 of 2 (permalink) Old 01-06-2008, 01:13 AM
OASIS RESULT:
1FTWW31R28EB23479
01/05/2008
21:13:06
FCXWS446
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2008 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.4L TC DIESEL V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
8F716A0A
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/17/2007 BUILD DATE
05/03/2007 SALE MILEAGE
00004
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
10/30/2007
DEALER: Barber Ford, Inc.
WARRANTY CLAIM NUMBER: 069542 ODOMETER: 004695M
LABOR OP
CONDITION CODE
CONDITION DESC
8U7Z 12A650CB PROCESSOR ASSY 001 MT12650 42 DOES NOT OPERATE PROPERLY
NO CRANK THEFT LIGHT FLASHING,IDS NO COMM WITH PCM,WENT INTO PREVIOUS SESSIO N IN IDS FROM 10-8-07 AND PERFORMED PMI,PCM REPROGRAM VEHICLE NOW STARTS N ORMALLY,CALL HOTLINE 309595265 SPOKE WITH 2 HOTLINE TECHS BOTH SAID TO REPLA CE ECM INSP C140 AND C110 FOR PIN PROBLEMS ALL OK,REPLACED MODULE,PER FORMED PMI DATA TRANSFER,PERFORMED PARAMETER RESET START VEH ICLE ROAD TEST
10/08/2007
WARRANTY CLAIM NUMBER: 068959 ODOMETER: 004215M
LABOR OP
CONDITION CODE
CONDITION DESC
12A650 PROCESSOR ASSY 000 MT12A650 42 DOES NOT OPERATE PROPERLY
CONTACT # 113054536 NO COMM WITH ANY MODULES,CK RESISTANCE O F PIN 6 AND 14 60.3 OHMS OK,TYPE IN PCM PT # TO IDS AND SCAN TEST ALL MODS,U0100,U0115 P1 635,CALL HOTLINE AGAIN,STANDARD EQUIP FAIL PCM,CK V POWER PINS 1,3,5,12,NO P OWER WITH C1232A DISCONN,CALL HOTLINE 3RD TIME,TOLD TO DO PCM BLANK PATH REP R OGRAM,AFTER SEVERAL ATTEMPTS WORKED BUT NOW HAVE CEL WITH ENG RUNNING,CODE
07/26/2007
WARRANTY CLAIM NUMBER: 066793 ODOMETER: 001923M
LABOR OP
CONDITION CODE
CONDITION DESC
7C3Z 8620E BELT-W/PUMP FAN&GENE 001 MT6B209 42 DOES NOT OPERATE PROPERLY
7C3Z 6B209A TENSIONER FEAD ASSY 001
3C2Z 8678AA PULLEY ASY-BELT IDLE 001
CHECK ENGINE NOISE AFTER COLD SOAK,VERIFIED CONCERN PINPOINT NOISE TO ACCE SSORY DRIVE BELT AT IDLER PULLEY ON BELT FROM ALTERNATOR CHECK ALIGNMENT OF ALL PULLEYS NOTICED SCORING ON FACE OF IDLER PULLEY AND TENSIONE PULLEY REMO VE AND REPLA CE IDLER PULLEY TENSIONER AND SERPENTINE BELT REINSTALL ALL COM PONENTS
| On-line 1878
END OF OASIS REPORT FOR 1FTWW31R28EB23479
2006 F250 XLT 6.0 CC Shortbed auto with Leer cap and fire engine red. Stock everything but running a
SCT Xcal2 tuned by Innovative Diesel. :smoke
Gillagorilla is offline
