Oasis Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BogginF350, this thread has received 1 replies and been viewed 1449 times.
post #1 of 2 (permalink) Old 10-13-2007, 10:08 PM Thread Starter
BogginF350's Avatar
Talking Oasis Please
1FTSX31PX3EC33876
thanks!
Josh Davis
6.0L Ford
6.4L Ford
WWW.RIVERCITYDIESEL.COM
(309) 699-2488
BogginF350 is offline
post #2 of 2 (permalink) Old 10-15-2007, 11:49 AM
OASIS RESULT:
1FTSX31PX3EC33876
10/15/2007
07:48:05
FCXWS446
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 S/CAB PICKUP 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/24/2003 BUILD DATE
02/06/2003 SALE MILEAGE
59B01
ELIGIBLE FOR ONE-TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIONS RECALL 05E15 OR 06E17 FOR DETAILS.
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
06/29/2007
DEALER: Tom Peck Ford, Inc.
WARRANTY CLAIM NUMBER: 101065 ODOMETER: 084174M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6F089BA ACTUATOR ASSY 001 062302A 42 DOES NOT OPERATE PROPERLY
5C3Z 6K682CARM TURBO CHG-EXH DRIVE 001
REPAIR AS LISTED IN TSB 6 23 2
06/27/2007
DEALER: Central Ford Lincoln Mercury,
WARRANTY CLAIM NUMBER: 037666 ODOMETER: 084025M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9F838EA SENSR ASY F/I TIMING 001 6007D D8 FAILED GASKET/SEAL
OSP 004 9838A
DIANGOSIS OIL LEAK AT BACK OF ENGINE FOUND ICP SENSOR LEAKING THROUGH CONNEC TORR&R ICP SENSOR ROAD TEST OK ALSO NECESSARY TO REPLACE LOST SYNTHETIC OIL REQUESTING SYNTHETIC OIL OSP
| On-line 1878
END OF OASIS REPORT FOR 1FTSX31PX3EC33876
Standard Claims List For Model Year 2003
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 0 7S22 180106 F2UZ 14526 P L20 46 843
AWS Claim Key: 634819 Trx Code: S07 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 20074 - * Name: F E WELTERLEN MOTORS INC Ph: 563-9286613 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:20-FEB-2003 Doc #:02793001
Cust Comments: THE BRAKE LIGHT AND TURN SIGNALS DO NOT COME ON WHEN APPLIED.
Tech Comments: CHECKED CONNECTIONS AND FUSES. THE FUSE FOR THE TURN SIGNAL AND TRAILER TOW HAD BLOWN OUT. WE REPLACED THE FUSE.
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 1 2E06 030008 3C3Z 9E527 ABRM D42 X2 1012
AWS Claim Key: 650135 Trx Code: S07 Labor Hrs: 5.1
Dlr Cd-Sub Cd: 20074 - * Name: F E WELTERLEN MOTORS INC Ph: 563-9286613 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:28-FEB-2003 Doc #:02793301
Cust Comments: THE ENGINE LOST POWER AND RUN ROUGH.
Tech Comments: WE DIE THE ENGINE PERFORMANCE DIAGNOSTICS AS PER SERVICE MANUAL INSTRCTION. WE RECEIVED A TROUBLE CODE FOR NUMBER 2 INJECTOR. REMOVED INJECTOR ANDFOUND THE CONNECTION ON INJECTOR WAS BROKEN AND CRACKED. WE ALSO FOUND A SMALL SCREW IN NUMBER 2 CYLINDER. REMOVED SCREW AND INSTALLED NEW INJECTOR. RETEST FOR CODES AND ROAD TEST.
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 1 2G01 031401 3C3Z 12A650 BDJ P59 42 1012
AWS Claim Key: 658485 Trx Code: S07 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 20074 - * Name: F E WELTERLEN MOTORS INC Ph: 563-9286613 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:28-FEB-2003 Doc #:02793302
Cust Comments: THE TRANSMISSION WOULD NOT UPSHIFT.
Tech Comments: PERFROM ELECTRONIC TRANSMISSION DIAGNOSIS. RECEIVED TROUBLE CODE PO657. THE CODE WAS NOT IN THE SERVICE MANUAL. CALLED FORD HOTLINE AND VERIFIED CS NOT LISTED. PERFORM EEC SYSTEM DIAGNOSTIC TEST. VOLTAGE TO CIRCUTS FORM PCM WAS BELOW SPECS. CHECKED CIRCUTS AND PCM. PCM NOT TRANSFERING CORRECT VOLTAGE TO CIRCUTS. REPLACE PCM AND RETEST. EXTRA TIME WAS NEEDED BECA
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 3 2E06 030008 3C3Z 9E527 AE D42 42 7304
AWS Claim Key: 1184633 Trx Code: S07 Labor Hrs: 5.7
Dlr Cd-Sub Cd: 20074 - * Name: F E WELTERLEN MOTORS INC Ph: 563-9286613 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:09-MAY-2003 Doc #:02798101
Cust Comments: THE ENGINE SURGES HAS LACK OF POWER.
Tech Comments: PERFORM ENGINE PERFORMANCE DIAGNOSTICS AND RECEIVED INJECTOR FAULT CODE. INSPECT AND TEST ICP SENSOR AS INSTRUCTED IN SSM 16791. REPLACED ICP SENS RETEST. CONTINUED TO RECEIVE FAULT CODE FOR NUMBER 3 INJECTOR. WE REPLACED NUMBER 3 INJECTOR AND RETEST. RO# 027933 CONTROL #1 WAS A REPAIR FOR NUMBER 2 INJECTOR. THIS REPAIR WAS FOR INJECTOR NUMBER 3 ON NUM
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 3 2G05 * * * * * * 7304
AWS Claim Key: 1171832 Trx Code: 03B06 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 20074 - * Name: F E WELTERLEN MOTORS INC Ph: 563-9286613 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:09-MAY-2003 Doc #:02798102
Tech Comments: REPROGRAM MULIPLE MODULES TO LATEST CALIBRATION LEVEL AS PER CUSTOMER SATISFACTION PROGRAM 03B06.
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 3 * * * * * * * 7304
AWS Claim Key: 1171833 Trx Code: 57B98 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 20074 - * Name: F E WELTERLEN MOTORS INC Ph: 563-9286613 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:09-MAY-2003 Doc #:02798103
Tech Comments: PERFORM OIL FILTER CHANGE AS PER CUSTOMER SATISFACTION PROGRAM 57B98.
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 6 1H03 030008 3C3Z 9F452 AC D41 42 14956
AWS Claim Key: 2198655 Trx Code: E84 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 20074 - * Name: F E WELTERLEN MOTORS INC Ph: 563-9286613 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:20-AUG-2003 Doc #:02704201
Cust Comments: ENGINE RUNNING ROUGH SURGES.
Tech Comments: PERFORM ENGINE PERFORMANCE TES WITH DATA LOGGER AND RECEIVED CONTINUOUS CODES FOR EGR BACK PRESSURE VALVE. CHECK AND REPLACE VALVE AND RETEST AFTER REPAIR. RECEIVED NO NEW CODES.
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 9 7S22 180106 F2UZ 14526 P L26 28 20868
AWS Claim Key: 3046644 Trx Code: S07 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 20074 - * Name: F E WELTERLEN MOTORS INC Ph: 563-9286613 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:23-OCT-2003 Doc #:02709401
Cust Comments: THE TRUN SIGNAL AND BRAKE LIGHTS ARE NOT WORKING.
Tech Comments: TEST LIGHTS AND FOUND NO POWER TO TURN SIGNAL/STOP RELAY. CHECK FUSES AND FOUND FUSE BLOWN, REPLACE FUSE.
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 9 2G04 031401 * 12A650 * E29 42 22158
AWS Claim Key: 3211289 Trx Code: S07 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 20074 - * Name: F E WELTERLEN MOTORS INC Ph: 563-9286613 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:04-NOV-2003 Doc #:02710501
Cust Comments: ROUGH/ROLING IDLE WHEN THE ENGINE IS WARM.
Tech Comments: PERFORM EEC SYSTEM DIAGNOSIS AND RECEIVED TROUBLE CODES. REPROGRAMMED POWERTRAIN CONTROL MODULE AS PER TSB 03 20 12. VERIFY CORRECT ENGINE LEVEL AND CONFIRMED PROPER OPERATION OF THE ICP/IPR.
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 18 2G01 * * * * * * 37500
AWS Claim Key: 7516869 Trx Code: 03L12 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 06235 - * Name: CENTRAL FORD LINCOLN MERCURY, INC. Ph: 815-3894500 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:23-JUL-2004 Doc #:01113550
Cust Comments: 03L12 ENGINE EMISSION CONTROL INFORMATION LABEL REPLACEMENT RECALL
Tech Comments: ONP PERFORMED RECALL
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 18 * * * * * * * 37500
AWS Claim Key: 7516870 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 06235 - * Name: CENTRAL FORD LINCOLN MERCURY, INC. Ph: 815-3894500 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:23-JUL-2004 Doc #:01113551
Cust Comments: 04S15 NEGATIVE BATTERY TERMINAL TO ENGINE BLOCK CONNECTION RECALL
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 18 1A02 030008 3C3Z 6051 BA L65 D1 37500
AWS Claim Key: 7668112 Trx Code: E72 Labor Hrs: 15
Dlr Cd-Sub Cd: 06235 - * Name: CENTRAL FORD LINCOLN MERCURY, INC. Ph: 815-3894500 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:23-JUL-2004 Doc #:01113552
Cust Comments: VECHILE HAS OIL LEAK ON RIGHT CYLINDER HEAD
Tech Comments: DIAG REPLACED HEAD GASKETS ALSO FOUND LEAK IN RADIATOR
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 18 6Y20 000001 * MISC * A98 82 37525
AWS Claim Key: 7382170 Trx Code: P01 Labor Hrs: 0
Dlr Cd-Sub Cd: 06235 - * Name: CENTRAL FORD LINCOLN MERCURY, INC. Ph: 815-3894500 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:12-AUG-2004 Doc #:01167551
Cust Comments: CUSTOMER STATES WANTS REFUND
Tech Comments: REFUND TO CUSTOMER
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 25 2E03 030402 3C3Z 9229 AA D02 D1 42679
AWS Claim Key: 9994734 Trx Code: S07 Labor Hrs: 7.3
Dlr Cd-Sub Cd: 06235 - * Name: CENTRAL FORD LINCOLN MERCURY, INC. Ph: 815-3894500 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:07-MAR-2005 Doc #:01627451
Cust Comments: CUSTOMER STATES WARMED VEHICLE UP STARTED DOWN DRIVEWAY VEHICLE DIED NOW NO START
Tech Comments: DIAGNOSE REMOVE VALVE COVER INSPECT REMOVE # 3 INJECTOR FOUND ORING CRACKED REPLACE ORING ON INJECTOR PUMP #3 CYLINDER REASSEMBLE TEST ALL OK
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 25 1H03 030008 3C3Z 9J460 AA E29 28 44002
AWS Claim Key: 10399331 Trx Code: S07 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 06235 - * Name: CENTRAL FORD LINCOLN MERCURY, INC. Ph: 815-3894500 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:07-MAR-2005 Doc #:01672351
Cust Comments: CHECK ENGINE ON WAS MAKING NOISE WHILE DRIVING
Tech Comments: DIAGNOSE CHECK TSBS AND SSMS REMOVE AND REPLACE EBP SENSOR AND REPROGRAM PCM TEST ALL OK
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 35 2H01 030008 3C3Z 6K682 AARM D36 42 62865
AWS Claim Key: 12825938 Trx Code: E72 Labor Hrs: 3.9
Dlr Cd-Sub Cd: 06235 - * Name: CENTRAL FORD LINCOLN MERCURY, INC. Ph: 815-3894500 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:19-DEC-2005 Doc #:02350151
Cust Comments: CUSTOMER STATES ENGINE SEEMS TO BUCK AT MED ACCELERATION
Tech Comments: ROAD TESTED VEHICLE TO VERIFY COMPLAINT PERFORMED ENGINE PERFORMANCE DIAGNOSTICS REPLACED EGR VALVE NOT SEATING REPLACE TURBO BOOST OUT OF SPEC ROAD TEST AFTER REPAIR ENGINE RUNS PROPERLY
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 35 1H03 030804 4C3Z 9J460 A D41 42 62875
AWS Claim Key: 12825939 Trx Code: E72 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 06235 - * Name: CENTRAL FORD LINCOLN MERCURY, INC. Ph: 815-3894500 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:29-DEC-2005 Doc #:02374851
Cust Comments: RECHECK BUCKED 3 TIMES 20 MILES AGO
Tech Comments: VERIFIED CONCERN ON MONITORED ROAD TEST DIAGNOSE CONCERN TO EBP SENSOR REPLACE SENSOR RE TEST OK
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 37 2E05 100106 6C3Z 9B249 A E68 42 64987
AWS Claim Key: 13215177 Trx Code: E72 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 06235 - * Name: CENTRAL FORD LINCOLN MERCURY, INC. Ph: 815-3894500 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2006 Doc #:02494451
Cust Comments: CHECK FOR FUEL LEAK
Tech Comments: DIAGNOSED FUEL LEAK REMOVED AND REPLACED FUEL PUMP DRAIN **** RETEST ALL OK AT THIS TIME
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 41 * * * * * * * 70125
AWS Claim Key: 14070532 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 06235 - * Name: CENTRAL FORD LINCOLN MERCURY, INC. Ph: 815-3894500 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2006 Doc #:02856151
Cust Comments: 06E17 CONTROL MODULE RECLIBRATION
Tech Comments: REPROGRAM PCM
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 41 2E06 030008 3C3Z 9E527 AE D42 42 70125
AWS Claim Key: 14070533 Trx Code: E72 Labor Hrs: 3
Dlr Cd-Sub Cd: 06235 - * Name: CENTRAL FORD LINCOLN MERCURY, INC. Ph: 815-3894500 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2006 Doc #:02856152
Cust Comments: CUSTOMER STATES SPUTTERS AND RUNS ROUGH ANY SPEEDS
Tech Comments: CHECK ENGINE PERFORMANCE PER DIAG GUIDE REPLACE #8 INJECTOR RE TEST OK
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 41 1H03 030008 4C3Z 9F452 A D42 D8 70125
AWS Claim Key: 14070534 Trx Code: E88 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 06235 - * Name: CENTRAL FORD LINCOLN MERCURY, INC. Ph: 815-3894500 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2006 Doc #:02856153
Cust Comments: CHECK ENGINE PERFORMANCE
Tech Comments: EEC TEST EGR HAS INTERNAL VACUUM LEAK AT O RINGS O RINGS NOT SERVICED NEC TO REPLACE ASSY
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 53 2E06 030008 3C3Z 9F838 EA L65 D8 84025
AWS Claim Key: 15333132 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 06235 - * Name: CENTRAL FORD LINCOLN MERCURY, INC. Ph: 815-3894500 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2007 Doc #:03766652
Cust Comments: CUSTOMER STATES OIL LEAK PLEASE CHECK
Tech Comments: DIANGOSIS OIL LEAK AT BACK OF ENGINE FOUND ICP SENSOR LEAKING THROUGH CONNECTORR&R ICP SENSOR ROAD TEST OK ALSO NECESSARY TO REPLACE LOST SYNTHETIC OIL REQUESTING SYNTHETIC OIL OSP
1FTSX31PX3EC33876 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-FEB-2003 24-FEB-2003 141696 USA 53 2H02 030407 5C3Z 6F089 BA D21 42 84174
AWS Claim Key: 15392141 Trx Code: E72 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 06160 - * Name: TOM PECK FORD, INC. Ph: 608-6762273 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:29-JUN-2007 Doc #:10106501
Cust Comments: NO POWER ON ACL RUNS ROUGH COLD STARTS STUMBLES
Tech Comments: REPAIR AS LISTED IN TSB 6 23 2
STEVEASHCRAFT is offline
