request. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rcannon, this thread has received 1 replies and been viewed 622 times.
post #1 of 2 (permalink) Old 10-17-2007, 12:46 PM Thread Starter
is here and there.
Rcannon's Avatar
Images: 11
request.
Need to cover my bases...
1FTWX31P25EA88286
I appreciate it.:thanks:
Rcannon is offline
post #2 of 2 (permalink) Old 10-23-2007, 01:31 AM
Send a message via AIM to Powersmoker113
1FTWX31P25EA88286 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 23-SEP-2004 23-JUN-2005 148544 USA 0 6V01 011101 3C3Z 2503100 CB G02 34 5
AWS Claim Key: 149168 Trx Code: 1 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 02841 - * Name: BROOKLYN FORD Ph: 517-5922112 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:29-SEP-2004 Doc #:101739B
1FTWX31P25EA88286 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 23-SEP-2004 23-JUN-2005 148544 USA 0 5S01 030008 3C3Z 9G270 AA L69 D8 6
AWS Claim Key: 396894 Trx Code: S07 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 02841 - * Name: BROOKLYN FORD Ph: 517-5922112 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:26-JAN-2005 Doc #:105168A
1FTWX31P25EA88286 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 23-SEP-2004 23-JUN-2005 148544 USA 1 6B07 010102 4C3Z 25022A69 AAA B66 33 493
AWS Claim Key: 1224972 Trx Code: 2 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02672 - * Name: IMLAY CITY FORD LINCOLN MERCURY Ph: 810-7245900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:30-JUN-2005 Doc #:12891101
Cust Comments: RUBBER SEALS ON COWL BENEATH WINSHIELD WIPERS ARE MISSING; CHECK AND ADVISE
Tech Comments: R&I WIPER ARMS & ANTENNA MAST, REPLACE BOTH COWL PANELS.
1FTWX31P25EA88286 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 23-SEP-2004 23-JUN-2005 148544 USA 5 6N04 010802 5C3Z 16720 SA B66 33 4484
AWS Claim Key: 2372449 Trx Code: 2 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 02672 - * Name: IMLAY CITY FORD LINCOLN MERCURY Ph: 810-7245900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:03-NOV-2005 Doc #:00205424
Cust Comments: CUSTOMER STATES THAT THE RIGHT SIDE FRONT FENDER F 350 BADGE IS DELAMINATING. SOP PART IS IN. ORDERED BY REED.
Tech Comments: REPLACED PEELING NAME PLATE ON PS FRONT FENDER.
1FTWX31P25EA88286 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 23-SEP-2004 23-JUN-2005 148544 USA 9 * * * * * * * 6025
AWS Claim Key: 3743096 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 02672 - * Name: IMLAY CITY FORD LINCOLN MERCURY Ph: 810-7245900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:24-FEB-2006 Doc #:00551351
Cust Comments: PERFORM RECALL 05E15
Tech Comments: REPROGRAM PCM&REPLACE EBP SENSOR PER RECALL 05E15 OP M 1.0HR.
AWS Claim Key: 3743097 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02672 - * Name: IMLAY CITY FORD LINCOLN MERCURY Ph: 810-7245900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:24-FEB-2006 Doc #:00551352
Cust Comments: PERFORM RECALL 59B01
Tech Comments: PERFORM ROAD TEST PER 59B01 PROGRAM, .3HR.
AWS Claim Key: 3743098 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 02672 - * Name: IMLAY CITY FORD LINCOLN MERCURY Ph: 810-7245900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:24-FEB-2006 Doc #:00551353
Cust Comments: PERFORM RECALL 05B32
Tech Comments: INSTALL LABEL&ADJ COOLANT LEVEL PER RECALL 05B32, OP B .3HR.
1FTWX31P25EA88286 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 23-SEP-2004 23-JUN-2005 148544 USA 13 2H01 030008 4C3Z 6K682 BA D42 42 9432
AWS Claim Key: 5080264 Trx Code: S07 Labor Hrs: 7
Dlr Cd-Sub Cd: 02672 - * Name: IMLAY CITY FORD LINCOLN MERCURY Ph: 810-7245900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:19-JUN-2006 Doc #:00927124
Cust Comments: CUSTOMER STATES NO BOOST PRESSUE TO TURBO NO POWE AT ALL
Tech Comments: PERFORM PERFORMANCE DIAG PER SHEET, CODE P0299 PRESENT KOEC, MONITOR BOOST PSI, ABOVE SPEC OF 22 25 PSI AT 29 PSI. PERFORM PINPOINT TESTS KA1 KA11, REMOVE PIPE PLUG IN TOP OF TURBO TO VIEW VGT CAM WHILE AC TUATING WITH WDS, FOUND CAM&VANES BINDING. REPLACE TURBO ASSY, CLEAR CODE. ROAD TEST, BOOST NOW IN SPEC AT 24 PSI.
1FTWX31P25EA88286 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 23-SEP-2004 23-JUN-2005 148544 USA 13 6N04 010802 5C3Z 16720 SA B66 81 9432
AWS Claim Key: 5080265 Trx Code: 2 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 02672 - * Name: IMLAY CITY FORD LINCOLN MERCURY Ph: 810-7245900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:19-JUN-2006 Doc #:00927128
Cust Comments: CUSTOMER STATES DS FENDER BADGE PAINT OFF
Tech Comments: REMOVE OLD EMBLEM, ABNORMAL TIME TO REMOVE OLD ADHESIVE. INSTALL NEW EMBLEM.
1FTWX31P25EA88286 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 23-SEP-2004 23-JUN-2005 148544 USA 13 2H01 030008 4C3Z 6K682 BA N11 30 9432
AWS Claim Key: 5159175 Trx Code: S07 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 02672 - * Name: IMLAY CITY FORD LINCOLN MERCURY Ph: 810-7245900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:19-JUN-2006 Doc #:00927129
Cust Comments: SERVICE PART CUST STATES TURBO NOISY
Tech Comments: NOTICED AFTER ROAD TEST THAT WHEN YOU SHUT ENGINE OFF TURBO WOULD MAKE A TICKING NOISE AS IT SLOWED DOWN PULL INLET HOSE OFF AND FOUND INLET IMPELLOR CONTACTING HOUSING REPLACE TURBO AND ROAD TEST OK
1FTWX31P25EA88286 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 23-SEP-2004 23-JUN-2005 148544 USA 20 2G05 031405 * RECALEM * D03 42 15887
AWS Claim Key: 7233224 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 02672 - * Name: IMLAY CITY FORD LINCOLN MERCURY Ph: 810-7245900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:12-FEB-2007 Doc #:01623427
Cust Comments: CUSTOMER STATES TROUBLE STARTING, CK AND ADVISE MORE WHEN WARM, EXCESSIVE CRANK
Tech Comments: REPROGRAM PCM, ROAD TEST&COLD START NEXT MORNING, OK. PER TSB 06 22 03 OP A 1.0HR.
1FTWX31P25EA88286 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 23-SEP-2004 23-JUN-2005 148544 USA 25 2E03 030008 * 9E527 * D13 42 19547
AWS Claim Key: 8182390 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02672 - * Name: IMLAY CITY FORD LINCOLN MERCURY Ph: 810-7245900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:02-JUL-2007 Doc #:02006924
Cust Comments: CUSTOMER STATES RUNS ROUGH ON START UP SMOKES
Tech Comments: CK FOR DTCS, SYSTEM PASS IN ALL MODES, REPROGRAM MULTIBLE MODULES TO LATEST CALIBRATION PER TSB 07 05 04 OP A .7HR.
1FTWX31P25EA88286 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 23-SEP-2004 23-JUN-2005 148544 USA 26 2B01 030707 8C3Z 12K073 A D02 42 20887
AWS Claim Key: 8420247 Trx Code: S07 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 02672 - * Name: IMLAY CITY FORD LINCOLN MERCURY Ph: 810-7245900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:30-JUL-2007 Doc #:02080625
Cust Comments: CUSTOMER STATES DOES NOT START, WILL CRANK BUT WILL NOT START
Tech Comments: UNABLE TO VERIFY CONCERN, PERFORM EEC TEST, DTC P2614 PRESENT KOEC. PERFORM PINPOINT TESTS V1 V3, PERFORM WIGGLE TEST OF HARNESS, NO FAULTS FOUND. REPLACE CAM SENSOR PER SYMPTOM.
1FTWX31P25EA88286 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 23-SEP-2004 23-JUN-2005 148544 USA 27 7S06 180101 5C3Z 12B637 AA D03 42 21703
AWS Claim Key: 8732731 Trx Code: S07 Labor Hrs: 5.8
Dlr Cd-Sub Cd: 02672 - * Name: IMLAY CITY FORD LINCOLN MERCURY Ph: 810-7245900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:29-AUG-2007 Doc #:02174525
Cust Comments: CUSTOMER STATES EXCESSIVE CRANK BEFORE IT WILL START, CK AND ADVISE
Tech Comments: STATOR, DEGAS BOTTLE, AIR FILTER&INLET,, CAC TUBES TO ACCESS&REPLACE HARNESS. CLEAR CODE, ROAD TEST, RETEST,OK.
2000 PSD F250 Regular Cab. 221k miles, bb Garrett, Swamps Gen3, A1000 Pump, Complete fuel system, Mac Cold Air Intake, 230cc stage 3 single shots, big ol nozzles, Transmission Built from Twisted Diesel Performance, DPtuner, , 4 inch exhaust, 6 inch silverline Tip, Zoo-dad mod, t/c lockup switch, HX crossover line,Intake heater delete,3.73 w/ reworked limited slip, 4 inch hanger kit, 33x12.5 BFG m/ts , 16.5X12 C2's, 04 headlights, 05 grill.
Powersmoker113 is offline
