Oasis request please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Fireguy, this thread has received 1 replies and been viewed 497 times.
post #1 of 2 (permalink) Old 10-18-2007, 08:47 PM Thread Starter
Fireguy's Avatar
Vin# 1FTWW31P85EC62722
THANKS GUYS :
The beast- 2005, F250, EXT Cab, Long box, 4x4
Performance- AFE air-intake, 5" exhaust, SCT, Casserly 225 sticks, ATS fuel system, ATS Trany, ATS Aurora 5000 turbo, oh and a Banks inter-cooler (I wanted a spearco but got a good deal)
Exterior-aka the stuff that slows it down
BDS 6" lift, 35" tires sittin on the stock rims
Interior- Cobalt Gauges, Pyro, boost, tranny and fuel pressure, 13% window tint, oh and cant forget those floor mats...
Fireguy is offline
post #2 of 2 (permalink) Old 10-23-2007, 01:24 AM
Send a message via AIM to Powersmoker113
1FTWW31P85EC62722 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-MAR-2005 14-JUN-2005 156447 USA 13 5V09 120307 6C3Z 2A451 A C19 41 33084
AWS Claim Key: 5097241 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04128 - * Name: GARNSEY & WHEELER COMPANY Ph: *-* St:CO Ctry Cd: USA Reg Cd: NA Repr Date:23-JUN-2006 Doc #:31426803
Cust Comments: AC BLOWS THRU DEF VENTS ONLY
Tech Comments: DIAG AC REPL FAILED VAC PUMP RETEST
1FTWW31P85EC62722 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-MAR-2005 14-JUN-2005 156447 USA 13 * * * * * * * 33084
AWS Claim Key: 5097242 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04128 - * Name: GARNSEY & WHEELER COMPANY Ph: *-* St:CO Ctry Cd: USA Reg Cd: NA Repr Date:23-JUN-2006 Doc #:31426804
Cust Comments: 05B32 RECALL
Tech Comments: INSTALL DEGAS BOTTLE LABEL
AWS Claim Key: 5097243 Trx Code: 05B35 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04128 - * Name: GARNSEY & WHEELER COMPANY Ph: *-* St:CO Ctry Cd: USA Reg Cd: NA Repr Date:23-JUN-2006 Doc #:31426805
Cust Comments: 05B35 RECALL
Tech Comments: REPROGRAM MODULES
1FTWW31P85EC62722 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-MAR-2005 14-JUN-2005 156447 USA 16 7A01 140101 BXT 65 750 D02 46 40539
AWS Claim Key: 5944967 Trx Code: P01 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04128 - * Name: GARNSEY & WHEELER COMPANY Ph: *-* St:CO Ctry Cd: USA Reg Cd: NA Repr Date:21-SEP-2006 Doc #:32079505
Cust Comments: NO START NO CRANK DIESEL
Tech Comments: TEST BATTERIES TEST CHARGE SYST CHARGE BATTERIES REPL BOTH BATTERIES
1FTWW31P85EC62722 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-MAR-2005 14-JUN-2005 156447 USA 24 1H03 030008 * 9F452 * D03 55 84273
AWS Claim Key: 7785983 Trx Code: S07 Labor Hrs: 2
Dlr Cd-Sub Cd: 04128 - * Name: GARNSEY & WHEELER COMPANY Ph: *-* St:CO Ctry Cd: USA Reg Cd: NA Repr Date:14-MAY-2007 Doc #:33572402
Cust Comments: CUSTOMER FILLED WITH FUEL AND VEH WOULD NOT START HAD TO PRESS FUEL
Tech Comments: EEC SYST DIAG CK EGR SYST CLEAN EGR PER TSB 06 16 06
1FTWW31P85EC62722 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-MAR-2005 14-JUN-2005 156447 USA 24 2E04 03XXXX 4C3Z 9B246 A D03 42 84860
AWS Claim Key: 7821943 Trx Code: E72 Labor Hrs: 8
Dlr Cd-Sub Cd: 03192 - * Name: GARNSEY & WHEELER COMPANY Ph: 970-5063600 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:17-MAY-2007 Doc #:33605001
Cust Comments: TRUCK WILL NOT FIRE AFTER IT GETS WARM,WHEN IT IS SHUT OFF WILL TAKE 1 1 2 HRS TO START.CRANK NO FIRE
Tech Comments: VERIFIED CUSTOMERS CONCERN OF CRANK NO START HOT.EEC TEST FOUND P2291 ICP TOO LOW CRANKING.FOUND TSB 06 17 6 AIR TESTED HIGH PRESSURE OIL PUMP AND REPLACED STC CONNECTOR AND ADDED BRACKET.RE
1FTWW31P85EC62722 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-MAR-2005 14-JUN-2005 156447 USA 25 2H02 030008 * 6F089 * D42 42 88386
AWS Claim Key: 7966039 Trx Code: E72 Labor Hrs: 14.1
Dlr Cd-Sub Cd: 03176 - * Name: GREINER FORD LINCOLN MERCURY Ph: 307-2661680 St:WY Ctry Cd: USA Reg Cd: NA Repr Date:08-JUN-2007 Doc #:24684901
Cust Comments: CUSTOMER STATES THAT THE VEHICLE IS SMOKING BADLY AND HAS NO POWER AT ALL TOWED IN CHECK
Tech Comments: VERIFIED THE CONCERN. RETRIEVED CMDTC S. P0404 AND P0405. EGR VALVE RANGE PERFORMANCE. REFER TO TSB 06 19 06. THE VALVE IS STUCK AND WILL NOT MOVE. ATTEMPTED TO CLEAN. THE EGR TEST FAILED. REP
2000 PSD F250 Regular Cab. 221k miles, bb Garrett, Swamps Gen3, A1000 Pump, Complete fuel system, Mac Cold Air Intake, 230cc stage 3 single shots, big ol nozzles, Transmission Built from Twisted Diesel Performance, DPtuner, , 4 inch exhaust, 6 inch silverline Tip, Zoo-dad mod, t/c lockup switch, HX crossover line,Intake heater delete,3.73 w/ reworked limited slip, 4 inch hanger kit, 33x12.5 BFG m/ts , 16.5X12 C2's, 04 headlights, 05 grill.
Powersmoker113 is offline
