OASIS Request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by midnight2004, this thread has received 1 replies and been viewed 915 times.
post #1 of 2 (permalink) Old 10-19-2007, 10:30 PM Thread Starter
Just about Broke
midnight2004's Avatar
OASIS Request
VIN 1FTNX21PX4EB24679
Thanks,
Chris
2004 F250 Lariat 6.0L
Torqueshift, 4x4, Supercab, Shortbox.
AEM Brute Force HD Intake, GT4088 VGT Turbo, Spearco Intercooler, Custom EGR Cooler Delete,
H11 Head Studs, Fass 150/180, Custom Fuel lines, Custom Coolant Filter, Single 6" Stack, 2.5" Lift. 35x13.5 on 20's
midnight2004 is offline
post #2 of 2 (permalink) Old 10-23-2007, 01:21 AM
Send a message via AIM to Powersmoker113
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
ARN MESSAGES
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/15/2004 BUILD DATE
10/27/2003 SALE MILEAGE
00010
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTNX21PX4EB24679 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-OCT-2003 15-APR-2004 141314 USA 0 3A11 070100 3C3Z 7000 GK P66 42 21
AWS Claim Key: 133400 Trx Code: 1 Labor Hrs: 13.7
Dlr Cd-Sub Cd: 01572 - * Name: SPRING HILL FORD INC Ph: 847-5513300 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:30-OCT-2003 Doc #:03667551
Cust Comments: CK TRANS HARSH ENGAUGEMENT WHEN SHIFTING
Tech Comments: REPORT #3J4HK023 ROADTEST VERIFY HARSH ENGAGEMENTS INTO RE.& DRIVE DELAY ENGAGEMENT ALSO PERFORM ELEC.TRANS DIAG.NO CODES REVERSE PRESS. FLUCTUATED MORE THAN NORMAL ADVISED TO REPLACE TRANS.ASSY.FLUSH EXTERNALLINES RETEST & ROADTEST CONCERN STILL PRESENT M TIME NEEDED FOR ADDTL & ABNORMAL DIAGNOSIS TIME CONTACT SHARONVILLE ADVISED TO REPL.PCA SOLENOID & WIRING HARNESS M TIME DUE TO TRANS REPL.OPE
1FTNX21PX4EB24679 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-OCT-2003 15-APR-2004 141314 USA 5 1H03 030008 3C3Z 9J460 AA D13 28 7966
AWS Claim Key: 1696079 Trx Code: S07 Labor Hrs: 4.6
Dlr Cd-Sub Cd: 06361 - * Name: SOERENS FORD, INC. Ph: 262-7819800 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:16-AUG-2004 Doc #:37652601
Cust Comments: DIESEL ENGINE PERFORMANCE TEST CUST STATES THAT ON FIRST START UP THE TRK SMOKES ALOT AND
Tech Comments: . DIESEL DIAG AND REPLACE EGR VALVE AND EBP SENSOR AND REPROGRAM PCM BP9J460 CC28 P0299
1FTNX21PX4EB24679 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-OCT-2003 15-APR-2004 141314 USA 14 2G02 180101 4C3Z 12A690 BA L65 42 16804
AWS Claim Key: 5172671 Trx Code: S07 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 06361 - * Name: SOERENS FORD, INC. Ph: 262-7819800 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:10-MAY-2005 Doc #:38939201
Cust Comments: DIESEL ENGINE PERFORMANCE TEST CUST STATES THAT THERE IS OIL LEAKING BY GLOW PLUGS SO PART ORDERED AND HERE PLEASE INSTALL
Tech Comments: . PER TECH HOT LINE REPLACED GLOW PLUG HARNESS, OIL WICKING THROUGH THE HARNESS CC 42 BP 12A690
1FTNX21PX4EB24679 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-OCT-2003 15-APR-2004 141314 USA 14 2G05 031405 * RECAL * D50 07 17201
AWS Claim Key: 5262396 Trx Code: E84 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 06361 - * Name: SOERENS FORD, INC. Ph: 262-7819800 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:16-MAY-2005 Doc #:38967401
Cust Comments: DIESEL ENGINE PERFORMANCE TEST CUST STATES THAT ONCE ENGINE IS AT OPERATING TEMP WHEN ACCELERATING FROM A STOP LIGHT A PUFF OF BLACK SMOKE COMES OUT OF TAIL PIPE ALSO WHEN AT EPRESSWAY S
Tech Comments: . KOEF PASS, NO DTCS, EGR TEST .7V CLOSED 4.5 OPEN, FUEL PRESS 50, ALL READING NORMAL, CONTACT TECH HOT LINE, PER HOT LINE ADVISE CUSTOMER CONDITION IS NORMAL AND CUSTOMER SHOULD TRY A DIFFERENT FUEL SOURCE, ALSO UPDATED PROCESSOR TO LATTEST CALIBRATION CC 82 BP RECAL
1FTNX21PX4EB24679 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-OCT-2003 15-APR-2004 141314 USA 16 * * * * * * * 19507
AWS Claim Key: 6293347 Trx Code: 05S34 Labor Hrs: 1
Dlr Cd-Sub Cd: 06361 - * Name: SOERENS FORD, INC. Ph: 262-7819800 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:01-AUG-2005 Doc #:39350501
Cust Comments: CERTAIN 2004 MODEL YEAR F250 350 450 550, EXCURSION, AND E350 450 VEHICLES FUEL INJECTOR CONTROL MODULE WIRING
Tech Comments: 1 F SUPER DUTY AND EXCURSION 05S34D 1.0 INSPECT FICM WIRE HARNESS FOR PART NUMBER, CHAFING, AND
AWS Claim Key: 6293346 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 06361 - * Name: SOERENS FORD, INC. Ph: 262-7819800 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:01-AUG-2005 Doc #:39350502
Cust Comments: CUSTOMER ASSURANCE TEST DRIVE POSTREPAIR TEST DRIVE LABOR OPERATION AND LABOR TIME MAY
Tech Comments: 1 59B01A .3 TEST DRIVE IS TO VERIFY THAT THERE ARE NO OTHER ENGINE RELATED CONCERNS
1FTNX21PX4EB24679 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-OCT-2003 15-APR-2004 141314 USA 17 5V09 120307 6C3Z 2A451 A C20 42 23246
AWS Claim Key: 6686478 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 06361 - * Name: SOERENS FORD, INC. Ph: 262-7819800 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:30-AUG-2005 Doc #:39503501
Cust Comments: C20 CUST STATES THAT NO MATTER WHAT SETTING YOU SET IT ON IT WILL ONLY BLOW ON DEFROST PLEASE ADVISE
Tech Comments: DIAGNOSE AND REPLACE VACUUME PUMP CC 42 BP 2A451
1FTNX21PX4EB24679 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-OCT-2003 15-APR-2004 141314 USA 18 * * * * * * * 25754
AWS Claim Key: 7121505 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 06361 - * Name: SOERENS FORD, INC. Ph: 262-7819800 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:30-SEP-2005 Doc #:39650301
Cust Comments: CERTAIN 2004 MODEL YEAR F250 350 450 550, EXCURSION, AND E350 450 VEHICLES EQUIPPED WITH 6.0L DIESEL ENGINES
Tech Comments: 1 05E15F 1.0 2004 F SUPER DUTY AND EXCURSION REPLACE EP SENSOR, EP CONNECTOR, AND RECALIBRATE CONTROL
1FTNX21PX4EB24679 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-OCT-2003 15-APR-2004 141314 USA 19 1F88 000615 * NPF * L87 82 26482
AWS Claim Key: 7563684 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 06361 - * Name: SOERENS FORD, INC. Ph: 262-7819800 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:31-OCT-2005 Doc #:39806101
Cust Comments: L87 CUST STATES THAT THE COOLANT RESIVOR KEEPS GETTING LOW PLEASE CHECK FOR POSSIBLE COOLANT LEAK
Tech Comments: INSPECT COOLING SYSTEM FOR LEAKS NO PROBLEM FOUND CC 82 BP NPF OASIS 511 583 175
1FTNX21PX4EB24679 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-OCT-2003 15-APR-2004 141314 USA 19 2A01 031202 * 6C646 * L65 42 26482
AWS Claim Key: 7563683 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 06361 - * Name: SOERENS FORD, INC. Ph: 262-7819800 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:31-OCT-2005 Doc #:39806102
Cust Comments: DIESEL ENGINE PERFORMANCE TEST CUST STATES THAT THERE IS A OIL DRIP FROM THE INTERCOOLER TUBE
Tech Comments: . REPLACED SIDE AIR CHARGE COOLER CLAMPS AND HOSE TO TURBO INLET CC 42 BP 6C646 TSB 05 13 05
1FTNX21PX4EB24679 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-OCT-2003 15-APR-2004 141314 USA 21 2H01 031202 YC3Z 6C640 KA L65 D8 28723
AWS Claim Key: 8041687 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 06361 - * Name: SOERENS FORD, INC. Ph: 262-7819800 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:19-DEC-2005 Doc #:40040401
Cust Comments: DIESEL ENGINE PERFORMANCE TEST OIL LEAK
Tech Comments: . REPLACED CAC TUBE AND CLAMPS CC D8 BP 6C640
1FTNX21PX4EB24679 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-OCT-2003 15-APR-2004 141314 USA 21 7N02 011103 * 2823201 * L08 33 28723
AWS Claim Key: 8049690 Trx Code: E83 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 06361 - * Name: SOERENS FORD, INC. Ph: 262-7819800 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:19-DEC-2005 Doc #:40040402
Cust Comments: L08 CUST STATES THAT WHEN YOU CLOSE THE DRIVERS DOOR THERE IS A KLUNK IN IT
Tech Comments: R&R DOOR TRIM AND TIGHTEN WINDOW REGULATOR CC 33 BP 23201
1FTNX21PX4EB24679 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-OCT-2003 15-APR-2004 141314 USA 22 1H03 030008 4C3Z 9P456 AC L87 D8 29403
AWS Claim Key: 8393645 Trx Code: S07 Labor Hrs: 7.1
Dlr Cd-Sub Cd: 06361 - * Name: SOERENS FORD, INC. Ph: 262-7819800 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:16-JAN-2006 Doc #:40159301
Cust Comments: DIESEL ENGINE PERFORMANCE TEST CUSYT STATES THAT THERE IS A COOLANT LEAK BUT HE CANNOT FIND IT NO DRIPS ETC BUT HAS HAD THE COOLANT BOTTLE RUN COMPLETELY EMPTY IN 1 MONTHS TIME PLEAS
Tech Comments: . COOLING SYSTEM PRESSURE TEST R&R TURBO AND INTAKE TO ACCESS AND REPLACE EGR COOLER CC D8 BP 9P456
1FTNX21PX4EB24679 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-OCT-2003 15-APR-2004 141314 USA 22 7H06 030306 3C3Z 19E672 CA D13 01 30336
AWS Claim Key: 8411767 Trx Code: E83 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 06361 - * Name: SOERENS FORD, INC. Ph: 262-7819800 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:27-JAN-2006 Doc #:40212002
Cust Comments: DIESEL ENGINE PERFORMANCE TEST CUST STATES THAT THE AIR FILTER HOUSING INDUCTION SYSTEM HAS A CRACK IN IT AS DOES THE ENGINE COVER SO PARTS ORDERED AND HERE PLEASE INSTALL
Tech Comments: . REPLACED MAIN WIRE HARNESS PLASTIC LOOM AND FAN SHROUD COVER CC 33 BP 16E672
1FTNX21PX4EB24679 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-OCT-2003 15-APR-2004 141314 USA 22 2E03 100106 3C3Z 9A214 AB L65 05 30336
AWS Claim Key: 8411766 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 06361 - * Name: SOERENS FORD, INC. Ph: 262-7819800 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:27-JAN-2006 Doc #:40212006
Cust Comments: L85 CUST STATES THAT THE DRAIN PLUG UNDER TRK BY DRIVERS SEAT IS CORRODED AWAY
Tech Comments: REPLACED FUEL WATER SEPERATOR DRAIN PLUG CC D7 BP 9A214
1FTNX21PX4EB24679 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-OCT-2003 15-APR-2004 141314 USA 27 5B04 050306 1C3Z 3B396 CB N58 42 36527
AWS Claim Key: 9612454 Trx Code: P01 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 06360 - * Name: GRIFFIN FORD LINCOLN MERCURY Ph: 262-5425781 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:06-JUN-2006 Doc #:05520051
Cust Comments: RIGHT FRONT HUB HARD TO TURN
Tech Comments: REPLACE RIGHT FRONT HUB LOCK ASSY
1FTNX21PX4EB24679 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-OCT-2003 15-APR-2004 141314 USA 27 5G03 050301 5C3Z 3050 A N50 42 37090
AWS Claim Key: 10288819 Trx Code: P01 Labor Hrs: 3.4
Dlr Cd-Sub Cd: 06360 - * Name: GRIFFIN FORD LINCOLN MERCURY Ph: 262-5425781 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:15-JUN-2006 Doc #:05581051
Cust Comments: CK FOR CLUNKING SOUND OVER BUMPS
Tech Comments: DIAG AND REPLACE LF POWER BALL JOINT,LF AXLE DUST SEAL,CK ALIGNMENT AND SET CAMBER,CASTER AND TOE
1FTNX21PX4EB24679 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-OCT-2003 15-APR-2004 141314 USA 33 2H01 030407 4C3Z 6K682 CBRM D36 42 45233
AWS Claim Key: 10832947 Trx Code: S07 Labor Hrs: 7.6
Dlr Cd-Sub Cd: 06212 - * Name: BADGER TRUCK CENTER, INC. Ph: 414-3449500 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:05-DEC-2006 Doc #:804556A
Cust Comments: STALLS WHEN DRIVING RESTARTS TURBO LOUDER LOW POWER
Tech Comments: 45233 5122 PERFORM DIAG. SHEET. PULL CODES, CK EGR, OK CLEAN. PULL TURBO, PULL APART, FOUND VANES CHEWED AND PITTED, EXHAUST SIDE WHEEL CHEWED UP ALSO, NEED NEW TURBO. 5122 ISNTALL NEW O RINGS ON TURBO TRANSFER PIPE, ISNTALL NEW TURBO, FOUND HOT SIDE CAC TUBE LEAKING AT PIPE TO TURBO REPLACE. PUT ALL BACK TOGHEHER. CLEAN AND ISNTALL NEW O RINGS ON EGR, START AND RUN TO
1FTNX21PX4EB24679 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-OCT-2003 15-APR-2004 141314 USA 34 1A01 030008 3C3Z 6049 AA E23 42 46758
AWS Claim Key: 11051413 Trx Code: E72 Labor Hrs: 17.7
Dlr Cd-Sub Cd: 06212 - * Name: BADGER TRUCK CENTER, INC. Ph: 414-3449500 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:02-JAN-2007 Doc #:805449A
Cust Comments: CHECK FOR COOLANT LEAK
Tech Comments: 46763 HEAD BOLTS. 7185 CHECK OVER, WATER IS COMEING OUT OF SURGE CAP, CHECKED OASIS, CHECKED CAP OK, NEEDS HEADS OFF & CHECKED. 7185 REMOVED ENG., STAND & DRAIN. 7185 START REMOVEING HEADS. 7185 REMOVED BOTH HEADS, CLEAN BLOCK & HEADS, CK FLATNESS BOTH HEADS ARE MORE THAN 0045 IN DIFFERENT PLACES. 7185 CLEANED INJS., BOTH EXH. MANIFOLDS & REMOVED EGR COOLER. 7185
2000 PSD F250 Regular Cab. 221k miles, bb Garrett, Swamps Gen3, A1000 Pump, Complete fuel system, Mac Cold Air Intake, 230cc stage 3 single shots, big ol nozzles, Transmission Built from Twisted Diesel Performance, DPtuner, , 4 inch exhaust, 6 inch silverline Tip, Zoo-dad mod, t/c lockup switch, HX crossover line,Intake heater delete,3.73 w/ reworked limited slip, 4 inch hanger kit, 33x12.5 BFG m/ts , 16.5X12 C2's, 04 headlights, 05 grill.
Powersmoker113 is offline
